Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.2.0 Pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,238Coins
  2. Wagnard
    Wagnardsoft
    5,238Coins
    4.1.3.0 pointer update
  3. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    929Coins
    3DOF, Arduino, Motion platform, 6DOF
    Aw no, the elite vanguards update today has killed the motion.
    Hopefully @Wagnard can work his magic again
  4. Wagnard
    Wagnardsoft
    5,238Coins
    Its there !
    Pointer update 4.2.0.0
  5. Wagnard
    Wagnardsoft
    5,238Coins
  6. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    @Wagnard wow that was quick - thank you so much. I hope you are well my friend :thumbs
  7. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Damn - they patched the update....
    If you have time mr @Wagnard
  8. Wagnard
    Wagnardsoft
    5,238Coins
    I'll do it this morning after breakfast.
  9. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Thanks for your time @Wagnard
    Now that I have retired from working I'm trying to learn to use CE to find pointers etc (in case, God forbid, anything happens to you). I've looked back at the vids on page 1 and yours on page 4.
    Is roll still 1.77 (for counter-clockwise) and -1.77 for CW. Your vid on page 4 is quite old now and I believe was back in Horizons days.
    Would be good to see a new process vid from start to finish for finding just roll settings. I looked back at all the XML's for last 5 game updates since Dec 2024 (for ship moves) and only offset_0 changes (i.e 19th August it was 05DA18EO). All other offsets (1 to 4) for all ship moves are identical.
    I understand the hex subtractions of last offset_4 for pitch, heave etc and I can see they are in place on each .xml.
    Just need to be sure I can find the correct address for roll, do several pointer maps to find the correct pointer and offsets to match what you find for a working .xml
  10. Wagnard
    Wagnardsoft
    5,238Coins
    Yep it is still 1.77
    But it's way easier to find the pitch with the SRV because they show it on screen. That's how I did it today. I use the training with SRV, once found the address, I pointer search if the last offset I knew before and it usually return 1 result. I then took the updated (Base offset) 05Da... and replaced it for everything (including the ship).
    Usually this work. On big update, it's possible the offset changes, but then it's more complicated to find them.
    Happily the offsets rarely change; But when they do, it's harder to find them.
    I know I found the goods one or almost when the same (base offset) work for everything.
    I'll maybe try to redo another vid.
  11. Wagnard
    Wagnardsoft
    5,238Coins
    4.2.0.1 update
  12. Wagnard
    Wagnardsoft
    5,238Coins
  13. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Success @Wagnard - I sent you a PM
  14. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    I sent you a new PM @Wagnard . I have more success with CE and pointers
  15. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Heads-up. Odyssey Vanguards Patch 2 update tomorrow folks......
  16. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi @Wagnard - I sent you a PM for Vanguards Patch 2
  17. Wotever
    Wotever New Member Gold Contributor
    - 261Coins
    In the wait of Wagnard experienced pointer seeking, this is just the Odyssey update ;)
  18. Wagnard
    Wagnardsoft
    5,238Coins
    4.2.0.2 pointer update. + legacy Horizon update. tx to @kev b
  19. Wagnard
    Wagnardsoft
    5,238Coins
  20. Random Noise
    Random Noise New Member
    16Coins
    3DOF, Motion platform
    Thank you Wagnard for your continuous work on this plugin.
    Since SimHub integrated it into the motion, I am enjoying Elite Dangerous more than ever!!!!
    But I am missing some haptic feedback from FSD supercruise and hyperspace. (almost nothing is happening)
    how to add some special haptic or motion effects for those specific actions?
