Assetto Corsa Evo
Discussion in 'DIY Motion Simulator Projects' started by pikky, Aug 28, 2025.
  1. pikky
    pikky New Member Gold Contributor
    24Coins
    Hello everyone, My name is Pikky and I am from Thailand. I am using SimTools v2 Pro with my DIY motion rig. I enjoy Assetto Corsa and ACC, and I am excited to try Assetto Corsa Evo with motion. Happy to join this community and
    153,758Coins
  3. pikky
    24Coins
    Hello, I am using a motion rig from DXSIM. The controller that comes with it only supports SimTools v2, not SimTools v3. That’s why I cannot upgrade to v3 at the moment. Is there any solution or community plugin for Assetto Corsa Evo that can work with SimTools v2? Thank you!
  4. pikky
    24Coins
    What should I do? Please help.
    153,758Coins
    I know nothing about DXSIM, please post some specific details.
    But if a rig works with SimTools 2 then I expect it just needs to be configured for v3 unless there are some weird control board shenanigans, perhaps the SimTools dev @yobuddy can comment further.
  6. pikky
    24Coins
    This is my controller.
      306 KB
      115
      365.3 KB
      125
      340.5 KB
      125
      284.4 KB
      122
    153,758Coins
    I am presuming this is some sort of commercial rig, if so do you have a link to the actual product page and specs?
  8. yobuddy
    51,525Coins
    Can I see your interface settings for SimTools 2 please?
  9. pikky
    24Coins
    Hello, I’m using a motion rig from DXSim. The controller that comes with it only supports SimTools v2. The rig works fine with other games (AC, ACC, Dirt Rally 2, F1, etc.), but I can’t get motion working with Assetto Corsa Evo. Here are my Interface Settings for SimTools v2 (COM13, 115200, <Axis1a><Axis2a><Axis3a>): [attach screenshots] Do I need to adjust the output string, interface type, or any other settings to make Evo work with SimTools v2? simtoo inter.jpg
  10. pikky
    24Coins
    1. Hello, I’m using a motion rig from DXSim. The controller that comes with it only supports SimTools v2. The rig works fine with other games (AC, ACC, Dirt Rally 2, F1, etc.), but I can’t get motion working with Assetto Corsa Evo. Here are my Interface Settings for SimTools v2 (COM13, 115200, <Axis1a><Axis2a><Axis3a>): [attach screenshots] Do I need to adjust the output string, interface type, or any other settings to make Evo work with SimTools v2? [​IMG]
      pikky, Yesterday at 07:56EditDeleteReportStart a conversation (Send PM)
      #9+ QuoteReply
    153,758Coins
    As far as I can recall there is no Evo for v2, but as previously advised there is a Evo plugin for v3, so it is really a case of figuring out why your rig works with v2 but not v3. What control board does your rig use?
  12. pikky
    24Coins
    I don't know what model it is. It uses LAN to connect to the router as the source.
      284.4 KB
      96
  13. yobuddy
    51,525Coins
    The interface shown in the pic above is using the serial interface configured for com port 13. So it connects thru a usb connection, not a LAN network connection correct? Simtools v3 has the same serial interface, so I don't see why it would not work when configured the same way is all.
  14. pikky
    24Coins
    I don't understand. I tried to do it but I couldn't.
  15. yobuddy
    51,525Coins
    May I see your SimTools v3 interface settings? Maybe I can spot a problem and we can get you up and running.
    Chat soon!
  16. pikky
    24Coins
    This is it, as shown in the picture.
  17. yobuddy
    51,525Coins
    The serial plugin settings for v3 is missing an axis <Axis4a> that is shown in the v2 settings.
  18. pikky
    24Coins
    Thank you. I'll try it.
  19. pikky
    24Coins
    I've tried adding <Axis4a> but it still doesn't work.
  20. yobuddy
    51,525Coins
    After you get it all setup just like SimTools v2, click save and then test settings on the interface setup page.
    Does it move correctly?
