6DOF platform with Syntron MDBOX
Discussion in 'New users start here - FAQ' started by Victor Urnes, Sep 17, 2019.
  1. Victor Urnes
    Victor Urnes New Member
    113Coins
    Motion platform, 6DOF
    Hi!
    We are building a really nice 6DOF platform with a 2pcs Syntron MDBOX.
    The actuator is 1000mm stroke length.
    What is the best method to control the Syntron MDBOX?
    Victor
    153,770Coins
    +11,149 / 57 / -2
  3. Thanos
    Electronics Engineer
    2,907Coins
    The question is not what is the best method but how to interface it with Simtools.
    You will need one of my AMC controllers for that. Send me message for details.
    Thanos
  4. Victor Urnes
    113Coins
    Ok, thanks Thanos. I have sent you an PM
  5. linken
    linken New Member
    10Coins
    Hello,I am from Shenzhen China.I am building a 6DOF platform too.I used 2pcs NV3030ED from Syntron MDBOX . I have install simtools v3 and MDBOX interface plugin on my PC 微信图片_20250828213854.jpg .But it did not work.Would you please tell me how to setup the Syntron MDBOX.
    153,770Coins
    +11,149 / 57 / -2
    Please see here re @Thanos advice that unfortunately the Syntron MDBOX ethernet interface protocol is unknown, instead recommending replacement with the
    AASD-15A servos with the AMC-AASD15A motion controller: https://www.xsimulator.net/community/threads/how-to-interface-an-sc-mbox-v3.17113/#post-228753
    You can check that alternative out in the FAQs:
    https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  7. linken
    linken New Member
    10Coins
    Hello,Thanks for your reply.I am not good at English.I have found the UDP protocol for the Syntron MDBOX ethernet interface.Please check the attache file.Would you please help us to run the MDBOX as a interface via ethernet in simtools,Let's try togethter.
  8. linken
    linken New Member
    10Coins
    Thank you for your quick response and the time you spend with me.I made you a diagram representing my installation.
      21.5 KB
      96
  9. Gerrit Bijlsma
    Gerrit Bijlsma New Member
    Phuket, Thailand
    53Coins
    I bought an Alibaba LeaderDream 6DOF with UDP communication with a STABLECU JS-9D.
    I used the same documentation as you showed to use SimTools V3 with the DBox interface (from @yobuddy)
    My settings for the MBOX interface are: Mbox type [6 Axis], Max Axis Value [400000] (for safety), Ip address [192.168.15.201], Port [7408], Output Rate [2]ms, and Axis4a-Axis3a-Axis2a-Axis1a,Axis6a,Axis5a.
    I can use several games like MSFS2020, XPlane12, and all car racing games.
    I hope this will help you if you haven't figured it out yourself yet.
  10. peteny
    peteny New Member
    2Coins
    ( have an sc-mdox V3-A6 im my sim but I can not get it to link to my pc. i can get the servos to move if i play with the setting. but communicating with Sim tools is an issue. if you can help, I would appreciate it.
  11. Gerrit Bijlsma
    Phuket, Thailand
    53Coins
    I am a bit confused because you mentioned wifi and the ethernet cable in one sentence while they are different animals.
    I don't know your knowledge of internet and LAN and I am sorry if this sounds like a lesson but if you can't ping to the Mbox, that should be your focus.
    You did not mention what the internet address is of the LAN card in the pc that will be controlling the Mbox.
    But because you mentioned that you pinged addresses with different subnets, I suggest that you check the ip address of that LAN card in the controlling pc.
    This address should have the same subnet as your Mbox
    In my case, the Mbox and pc are in the bottom part of the Motion Platform and are connected to each other
    through a single LAN cable so there are only 2 nodes (no router or network switch is connected to that LAN). The address of my Mbox has 192.168.15.201 and the LAN card in the pc is 192.168.15.101. From the pc I can ping to the Mbox (192.168.15.201)
    My Motion Platform came as a (more or less) complete turnkey set .
    Assuming that the manufacturer of the Mbox has all Mboxes default set to 192.168.15.201 and yours have not been changed, you should have your pc LAN adaptor set to 192.168.15.101 (or anything but 201 (or 1 or 255)) with subnet-mask 255.255.255.0 manually because there is no DHCP in that LAN section.
    Than you should be able to ping 192.168.15.201.
    After that you can start setting up the SimTools V3 using the Dbox interface from @yobuddy
    I hope this helps you solve your problems a bit.
