I need help picking out right motor and platform layout
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Oskyhan, Jul 10, 2025.
Tags:
  1. Oskyhan
    Oskyhan New Member
    16Coins
    hi,
    So I am trying to plan out my sim design for iracing and I am split between going to build a full motion platform or just a seat mover any suggestions because I feel like the seat mover would be disorienting with vr
    also I would like to use these motors are they good enough ?
    They are geared motors with 85rpm
    250w
    21.5 n
    Brushed
    153,710Coins
    If you anticipate a future upgrade then I would suggest motors and controllers that would be suitable, like the @Thanos controller and servo motors: https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
    Alternatively you could choose hardware that may be cheaper but serve a recyclable simple future use, like using the motors and controllers of a 2DOF for a telemetry driven harness in some future 6DOF rig: https://www.xsimulator.net/community/faq/harness-tensioner-simulation.361/
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    Write exactly what you want to build, only then can a correct answer be given
    - 2DOF or more
    - racing or flighsim
    - Are you aware that cheap motors like the one you showed have a noticeable gear backlash, of course you can have great fun on DOF with such motors
  4. james wheeler
    - 143Coins
    I have used Ford wiper motors for my builds. Once I tried 250w motors and they sucked by comparison. Gutless and don't stop well. The wiper motors are worm Gear which inherently stop and lock.
    These are the motors I use and why.
    1.Worm geared.
    2. Small in size but pack a punch
    3. The wiper mounts are easy to modify with just a grinder and a drill
    4 the wiper mounts are bolted in with a 6mm bolt which make coupling to a potentiometer easy. Which wonderfully enough have a 6mm shaft. Just cut off the head of the bolt and couple them together using a 6mm to 6mm coupler.
    5 the 3 point motor mounts fit perfectly into a over the counter mount you can buy at a hardware store.
    CANNONBALL Offset/Adjustable Sliding Door Stay Roller
    A-Premium Windshield Wiper Motor Front Compatible with Ford E-150
  5. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    I can only confirm
