Question Simtools does not send a new signal after 1 minute of operation.
Discussion in 'SimTools DIY Version' started by Luu Vy, Jul 15, 2025.
  1. Luu Vy
    Luu Vy New Member
    12Coins
    I have a 2 dof simulator project using Simtools to send signals to Arduino but when playing or testing in output testing, the signal can only be sent for about 1 minute then simtools does not send any new signals to Arduino anymore, but when I check the LCD displaying the Pitch, Roll, etc. values, Arduino is still connected but all data freezes at the last values it received before stopping.
    153,371Coins
    +11,137 / 57 / -2
    Can you please specify what code you are using with the Arduino.
  3. Luu Vy
    Luu Vy New Member
    12Coins
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    #include <PID_v1.h>
    #define MP1 10 // PWM CW
    #define MP2 11 // PWM CCW
    #define ML1 6 // PWM CW
    #define ML2 9 // PWM CCW
    #define POT_R A0
    #define POT_L A1
    char buffer_data = 0;
    int buffercount = -1;
    byte commandbuffer[7] = {0};
    int pitch = 0, sway = 0, roll = 0;
    double err_L, err_R, err_sway, err_roll, err_pitch;
    double motor_R = 100;
    double motor_L = 100;
    // -------------------- LCD ------------------------------
    LiquidCrystal_I2C lcd(0x27,20,4);
    // -------------------- PID ------------------------------
    double inputR, outputR, setpointR;
    double input, output, setpoint;
    double kp = 2.8, ki = 20 , kd = 0;
    PID pidRight(&inputR, &outputR, &setpointR, kp, ki, kd, DIRECT);
    PID pidL(&input, &output, &setpoint, kp, ki, kd, DIRECT);
    void setup() {
    Serial.begin(115200);
    lcd.init();
    lcd.backlight();
    lcd.setCursor(0,0);
    pinMode(POT_R, INPUT);
    pinMode(MP1, OUTPUT);
    pinMode(MP2, OUTPUT);
    pinMode(POT_L, INPUT);
    pinMode(ML1, OUTPUT);
    pinMode(ML2, OUTPUT);
    pidL.SetMode(AUTOMATIC);
    pidL.SetSampleTime(10);
    pidL.SetOutputLimits(-255, 255);
    pidRight.SetMode(AUTOMATIC);
    pidRight.SetSampleTime(10);
    pidRight.SetOutputLimits(-255, 255);
    void loop(){
    readSimTools();
    process_signal();
    MotorLeft();
    MotorRight();
    showLCD();
    void readSimTools()
    while(Serial.available())
    if(buffercount==-1)
    buffer_data = Serial.read();
    if(buffer_data =='S')
    {// Start game
    buffercount=-1;
    else if(buffer_data =='E')
    { //End game
    buffercount=-1;
    else if(buffer_data =='P')
    { //"P" is the marquer. If we read P, the next data is pitch
    buffercount=0;
    else // if(buffercount>=0)
    commandbuffer[buffercount]=buffer_data; // The first value next to "P" is saved in commandbuffer in the place "buffercount"
    buffercount++;
    if(buffercount > 6)
    if(commandbuffer[6]=='C') // If the third data is "C", then commandbuffer is full, we can use it
    pitch=(commandbuffer[0])*256+commandbuffer[1];
    sway=(commandbuffer[2])*256+commandbuffer[3];
    roll=(commandbuffer[4])*256+commandbuffer[5];
    //ma
    sway=map(sway,0,1023,0,200);
    pitch=map(pitch,0,1023,0,200);
    roll=map(roll,0,1023,0,200);
    buffercount=-1; // Re-initialize buffercount.
    void process_signal()
    err_pitch = pitch-100; //pitch = len doc
    err_sway = sway-100; //sway = trai phai
    err_roll = roll-100; //roll = xoay vong
    //truyen dong co
    err_R= 2*err_pitch - 3*err_sway + err_roll;
    err_L= 2*err_pitch + 3*err_sway - err_roll;
    motor_R=100 + err_R;
    motor_L=100 + err_L;
    if(motor_R>160) motor_R=160;
    else if(motor_R<40) motor_R=40;
    if(motor_L>160) motor_L=160;
    else if(motor_L<40) motor_L=40;
    void MotorLeft(){
    int rawPotL = analogRead(POT_L);
    input = map(rawPotL, 0, 1023, 0, 360);
    setpoint = motor_L;
    pidL.Compute();
    if(output > 10){
    analogWrite(MP1, output);
    analogWrite(MP2, 0);
    } else if(output < -10){
    analogWrite(MP1, 0);
    analogWrite(MP2, abs(output));
    } else {
    void MotorRight(){
    int rawPotR = analogRead(POT_R);
    inputR = map(rawPotR, 0, 1023, 0, 360);
    setpointR = motor_R;
    pidRight.Compute();
    if(outputR > 10){
    analogWrite(ML1, outputR);
    analogWrite(ML2, 0);
    } else if(outputR < -10){
    analogWrite(ML1, 0);
    analogWrite(ML2, abs(outputR));
    } else {
    // =========== 3. Hiển thị LCD =========================
    void showLCD(){
    lcd.setCursor(0,0);
    lcd.print("P:"); lcd.print(pitch); lcd.print(" S:"); lcd.print(sway);
    lcd.setCursor(0,1);
    lcd.print("R:"); lcd.print(roll); lcd.print(" Pot:"); lcd.print((int)inputR);lcd.print("/");
    lcd.setCursor(0,2);
    lcd.print("SP:"); lcd.print((int)setpointR);lcd.print("/"); lcd.print(" "); lcd.print((int)outputR);lcd.print("/");
    lcd.setCursor(0,3);
    lcd.print("MR:"); lcd.print(analogRead((int)POT_R)); lcd.print(" ML:"); lcd.print(analogRead((int)POT_L));
    Serial.print(setpointR);
    Serial.print(" ");
    Serial.print(inputR);
    Serial.print(" ");
    Serial.println(outputR);
    153,371Coins
    +11,137 / 57 / -2
  5. yobuddy
    51,458Coins
    How fast are you sending the packets to the Arduino? My guess is the LCD takes a bit of time to update and when it gets behind it stops working. Please try an output rate of 50ms from the interface and see what happens.
  6. Jacob Riis-Jacobsen
    Jacob Riis-Jacobsen New Member
    51Coins
    Hey yobuddy
    Thanks for that answer. That worked like a charm on my setup. Guest the stream was getting clugged up?
  7. yobuddy
    51,458Coins
    Basically we are sending commands to the Arduino faster than it can process the data and it all falls over.
