Peacemakers 6dof Unicorn Build
Discussion in 'DIY Motion Simulator Projects' started by Peacemaker105, Oct 5, 2018.
  1. Thanos
    Electronics Engineer
    2,901Coins
    Yes, you already quoted the previous message that says exactly that.
  2. Mclain
    Mclain New Member
    Transmission Specalist
    Hulsberg NL
    59Coins
    Got allot of reading up to do.
    Looking into the option of Building a 6Dof system, and This Actuator Design is pretty much in the same line i was thinking, so i might just go with this design instead of drawing up everything myself and ending up with pretty much the same thing.
    Only one question. Would it benefit the Actuator if the Motor was actually on the Side using a Belt. This way the actuator is a little shorter and you could change the gearing to suit the rigs intention. Or would it just create more potential issues
    153,039Coins
    +11,116 / 56 / -2
    That configuration is viable, it really depends on the core design objectives, and the associated tradeoffs of somewhat greater complexity.
  4. Arta Yasa
    Arta Yasa Member
    968Coins
    Hi mate,
    How about if i put the actuactor is like that?? ( same like hexapod 6dof) but my motion is 3fof 4 actuactor. The position of actuactor is not upside down, so the motor on the bottem, not like sfx 100. Is posible mate?? Because if i put upside down. That more heavy around 40kg of 4 actuactor. Ty.
