2dof Questions and Problems
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Giuseppe1, Sep 13, 2025.
  1. Giuseppe1
    Giuseppe1 New Member
    42Coins
    Hello, reading the forum I am trying to assemble my station. Everything works for now. The problem I can't solve is this: when the system is turned off, the lever arms point to the floor.So when I turn on the PC the arms do not return to horizontal position.this makes it impossible for me to sit because the seat remains tilted forward!! now I ask, how can I do to lock the arms in the starting position? For now I block the position at the front with two large wooden blocks.
    I attach some explanatory photos. Thank you.
  2. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    From memory, you correct this in the SMC3 profile. Basically, you must be exceeding the sinusoidal signal in SMC 3 in some way.
    You need to review the settings so that when you turn on your chair, SMC3 can find the position of your motor.
    To do this, check when you start it in the SMC software. If, when you turn on your motor, it exceeds the upper or lower limit, you have an incorrect gear/motor potentiometer ratio. This should create a continuous sinusoidal wave that alternates between high and low.
    I'm not sure I explained this correctly...
    153,818Coins
    +11,150 / 57 / -2
    Yours are obviously motors that can be back driven, meaning they can be moved when unpowered.
    The wooden chocks you are already using are the easiest solution and many before you have done the same.
    Keep in mind the controllers shutting off if out of range is a safety feature, for you and your rig.
  4. Giuseppe1
    42Coins
    Thank you for your comments. I apologize if I worried about one obvious thing but, not being a native English speaker, I definitely missed this thing. I'm glad it's normal, so I found a more elegant locking system than wedges!! finally, I decreased a little bit max limit So as to resume the engines without getting up to move the station. Thank you very much, if other problems arise
  5. Giuseppe1
    42Coins
    Good morning guys, I have another doubt. As you know I built a 2dof + TL using 3 wheelchair motors. Specifications are 24v, 250 W, 120 rpm, 13,4 amp. I used 3 ibt-2 and 3 arduino. The power supplies are 3 set to 18v.The power supplies are 3 set to 18v. Everything works regularly but I have seen that the 3 engine (right) and its ibt heat up even if the simulator is not used. I have read the forum and I can rule out engine and ibt problems because I have already tried to interchange them, to no avail. could it be an arm centering problem with respect to motor 2 (left)? I measured the angle of 90 of the levers by eye. Or maybe, since I used 2 arms of my car that have the ball joint, the position of the resting station is never centered right / left and the engine struggles! Dunno. i attach setting Smc3. Thank you
    153,818Coins
    +11,150 / 57 / -2
    How well balanced is your rig, fore and aft, plus side to side, with you in it and all peripherals attached: https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
  7. Giuseppe1
    42Coins
    Thanks noorbeast for the clarification. In my time I followed all the instructions found on the forum and balanced to the cm following the link. today I leveled the corner and added a heatsink to the ibt. It won't do anything but it won't hurt! I'll see what happens and say
  8. Giuseppe1
    42Coins
    Yesterday I played for 2 hours and the engine was only slightly lukewarm. I also let it rest half a day to see if it warmed up but no longer warms up thankfully. Only the annoyance remains that, every now and then, an engine scales and goes off scale, and then deactivates. I have very limited the angles of use so as not to have a too aggressive movement response and I have decreased in smc3 the PWMmax to prevent the levers from exceeding the Max Limit.Can I do something about this?
    153,818Coins
    +11,150 / 57 / -2
    Sounds like the Clip Limit in SMC3 may need adjusting,as if it exceeds the target range SMC3 will attempt to brake the motors hard by driving them in reverse until they are back out of this limit zone.
  10. Giuseppe1
    42Coins
    Thanks for the answer. I tried and tried again and found that I had enlarged the installation position of the motors too much. this is probably the problem of imbalance.I placed the engines closer together so as to bridge the difference between the bases and, by trying the lateral movement (roll) by hand, it would seem that I lost every game. Tomorrow i'll try movements with smc3.
    EDIT: I tried the simulator and it seems that this annoyance is solved too! We'll see with practice. Thank you
  11. Giuseppe1
    42Coins
    Good morning, everybody. Today something strange happened to me, that is, an arduino and its ibt2 burned out! I replaced the pieces and, shortly after, the same thing happened on another arduino and its ibt2! I do not know why it happens but, first I lowered the voltage of the power supplies that feed the motors bringing them from 18v to 15v. Has it already happened to any of you? What can you do to avoid burning the next ones? I add that the burned arduino lights up the LEDs ON, rX;The pc however does not see these in any com port(tried with other PCs but nothing). Thank you
