Python, VisualStudio,Processsing and plugins
Discussion in 'Miscellaneous' started by accelero, Sep 15, 2025.
  1. accelero
    accelero Member
    france
    287Coins
    2DOF, AC motor, Arduino
    Hi guys , is there somewhere on the forum ( huge maze) a python plugin to send data from python to simtools for example a sin wave on roll axis to test the movements of a platform following changes on amplitude and frequency?
    153,830Coins
    +11,151 / 57 / -2
  3. accelero
    accelero Member
    france
    287Coins
    OK , thanks a lot.
    I am on writing my own plugin, using the example you give for simtools2, so I was asking myself when going along the job, is it right to write something like (MyPath&"\mySketch.py" ).... or is it better to turn first "mySketch.py" into an exe, because the plugin has patched properly but I can't recieve any data, despite the chceking of the 4123 port with WireShark
    here is the way my data come out mySketch:
    # Map to OutSim fields
    sngOrientation2 = values.get("Roll", 0.0) * math.pi # Roll
    sngOrientation1 = values.get("Pitch", 0.0) * math.pi # Pitch
    sngOrientation0 = values.get("Yaw", 0.0) * math.pi # Yaw
    sngAcceleration2 = values.get("Heave", 0.0) * 10.0 # Heave
    sngAcceleration0 = values.get("Surge", 0.0) * 10.0 # Surge
    sngAcceleration1 = values.get("Sway", 0.0) * 10.0 # Sway
    # Pack into struct (6 floats)
    packet = struct.pack(
    "<6f",
    sngOrientation0,
    sngOrientation1,
    sngOrientation2,
    sngAcceleration0,
    sngAcceleration1,
    sngAcceleration2,
  4. accelero
    accelero Member
    france
    287Coins
    For those who ask themselves same kind of questions,
    Yes it seems obvious now that you have to turn any self written sketch, whatever software your are using , into an .exe
    Next big step for me is , as I'm not a specialist , to find out which data format is preferable.....
    ex : recieving ( Text as String ) and splitting it to CDbl for each roll,pitch .....that seems pretty simple ( C silva's method )
    or recieving (Text as String) and converting it to byte and copy to a byte array and then
    Get Proper Data With "MyOutsim_Internal" to get after calculation something like
    Roll_Output = ((.sngOrientation2 * 180 / 3.14159) - 90) which seems a bit more clever ( yobuddy' s method)
    trying out both and let you know :):)
  5. accelero
    accelero Member
    france
    287Coins
    last hours work:
    Writing a basic UDP listener in visual Studio to recieve and process data with a "yobuddy like" method, printing the recieved values ( if recieved and well processed) to the console.
    Writing a basic UI that sends data for all six axes in the proper format to be read by the visual studio previous app.
    Next step turning the UI to an exe , expecting it is written with proper functions, and patching all the stuff to Simtools and perhaps getting the new five actuators platform moving .
    It already works fine with UI generated movements imported in VideoRide Player ......very smooth and fun :p
  6. accelero
    accelero Member
    france
    287Coins
    written a UDP sniffer displaying what it recieves , using the same function than plugins. Have sent data in the dedicated format from an exe
    Everything works fine.
    BUT seems like the plugin does't open 4123 port or not allows reading the port, or not calculating from the data because simtools never displayed the values sent by the different exe files neither in Processing, neither in Python, neither in VB .....the plugin seems to be ok, it is displayed in game manager properly, the patch indicator turns green.......
    Remebered about simtools reluctant to work under French region, but despite french location and keyboard and so on, able to use output testing properly,so the problem is still there.......
    SOLVED
