Compact 2 DOF using Actuators for Prepar3D Flight Simming
Discussion in 'DIY Motion Simulator Projects' started by SimbaFlyer, Aug 8, 2025.
  1. SimbaFlyer
    SimbaFlyer New Member
    19Coins
    Hi Guys! Long time, first time, coming in live from Southern California!
    I read a lot of great posts on this website and looking to jump in and build a motion Flight Simulator sim. I got my Thrustmaster Joystick, Rudder Pedals and Throttle and having some good fun on Prepar3D general aviation airplanes. But something is missing :grin
    Reading the forums, many smart guys have had good experiences with the 24V 75RPM wheelchair motors. What are your thoughts on motorized Actuators? I have attached the datasheet of the PC-09-HALL linear actuator from Progressive Automation ($174 each, 8" stroke) and a picture of the inspiration model. This also comes with the Hall effect sensors built in. I would be using the usual hardware; IBT2's, Arduino UNO3 and 24V power supplies.
    Looking at the SimCalcs software, it seems the Linear Actuator button is greyed out. I have attached a screenshot of calcs of a similar seat mover using motors.
    Any feedback is appreciated regarding the use of these actuators. Thanks!
    154,849Coins
    +11,228 / 57 / -2
  3. SimbaFlyer
    19Coins
    Hi Guys, so I decided to build the design by @pmvcda at :
    https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/
    and the circuit board design by @fcppenta at:
    https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-38#post-218195
    I am using only 3 level shifters, and soldered the 6 jumpers together as per the conversation in the above threads.
    EDIT:
    Bills of Material:
    ESP32 Board:
    https://a.co/d/atVcDkZ
    Logic Level Converter Bi-Directional 3.3V-5V Shifter Module:
    https://a.co/d/eZeJeT5
    Brushless DC Motor 57BLF03 188W 24V 3000RPM, & Driver BLDC-8015A:
    https://ebay.us/m/fx0dsb
    24V 25A 600W Power Supply:
    https://a.co/d/fLkukQH
    Micro Limit Switch:
    https://a.co/d/9mMQhza
    10A10 Rectifier Diode 10A 1000V:
    https://a.co/d/8HGDJbY
    10K Ohm Carbon Film Fixed Resistor:
    https://a.co/d/dxbDQil
    WM686 4 Terminal DC 24V 200A Universal Car Vehicle Motor Fuse Relay Switch Power:
    https://ebay.us/m/Rs8bN8
    Red Mushroom Emergency Stop Shut Off Push Button Switch:
    https://ebay.us/m/pF9DFn
    Aluminum Shaft Coupling 8mm to 10mm:
    https://ebay.us/m/VALlGE
    The ESP32 Board communicates with the computer via USB. You will need to install the driver that will allow this communication to take place. The driver "CP210x Universal Windows Driver" will need to be installed and is located at:
    https://www.silabs.com/software-and-tools/usb-to-uart-bridge-vcp-drivers?tab=downloads
    When using the Arduino IDE software to install the Serial Sketch onto the ESP32 board, the Board Manager versions have been updated. You will need to use an older version, "ESP32 by Espressif Systems Ver 2.0.17" If you don't use this and use a latest version, then you will get a compilation error. Once Board Manager is installed, you can then choose "DOIT ESP32 DEVKIT V1" as the board name. Initially I had a problem connecting with the board, since not all USB cables are equal. Some are only for charging batteries, while others are for data transmission. Once I got the right cable, I was able to connect to the board and install the Sketch.
    In the Sketch, change the "#define SERIAL_SPEED 921600" to "#define SERIAL_SPEED 500000" and the "#define NUMBERACTUATORS 1" to "#define NUMBERACTUATORS 2" for a 2DOF system.
    Once the Sketch is compiled and loaded onto the board, I plugged the board with the USB cable, the blue light flashes 5 times and both motors start moving, looking for the Max Limit switch first. I press those microswitches and the motors turn direction, this time looking for the Min Limit switch. After I press those, the motors come to a stop, waiting for serial input from the Mover software and Simulator game.
    As a noob I have gotten this far. Before I start work on building the actuators and printing 3D parts for the 2DOF Rig, I wanted to bench test this setup. I have installed Live For Speed on the laptop and tried to understand the logic behind FlyPT to make this work. The serial port is visible and connected in FlyPT. I do understand that there is a learning curve for FlyPT, but those who have mastered it love it.
    My intention is to build a compact 2DOF rig using DIY actuators using PVC pipe, and will document the build together with all the STL files for anyone else to build the same.
    Thanks!
  4. SimbaFlyer
    19Coins
    With guidance from @GruntyPig and @smitty the bench test has moved forward now. I am using FlyPT 3.5.3. The serial port "Send" info is <255><255><Axis1a><Axis2a>. In the Arduino sketch, I changed the serial Baud rate to 500000. As the "Source" signal, I used "Loop" to generate the Sine Wave, and that made the motors spin clockwise and counterclockwise. The motors must spin smoothly without and clicking and stuttering noises. I had that issue, but when I changed the "Interval Loop" setting in the "Serial Output" from 1 to 4, this noise was no more. More info later as I progress.
  5. SimbaFlyer
    19Coins
    I have created a quick guide on setting up FlyPT 3.5.3 so that it can help another noob move ahead a little faster. If you see anything that can be changed for clarity, let me know. I have also attached a Test mover file just to play around with. Rename the file by removing the .TXT extension so that the file name is Test.Mover
    Edit:
    Here is a link to a tutorial playlist of videos created by Hexago-Motion to explain the mechanics behind Filters and how they affect the Motion Simulator :
    Here is a link from FlyPT's youtube page showing how he updates the filters on the fly. The video helps provide understanding of the use of the Filters:
    More detailed information for each of the items is located here:
    https://www.xsimulator.net/community/threads/flypt-mover-3-5-3.13464/
  6. SimbaFlyer
    19Coins
  7. SimbaFlyer
    19Coins
