LeaderDream 6DOF
Discussion in 'Commercial Simulators and Peripherie' started by Gerrit Bijlsma, Sep 21, 2025 at 11:55.
  1. Gerrit Bijlsma
    Gerrit Bijlsma New Member
    Saturday
    Phuket, Thailand
    29Coins
    My name is Gerrit and I live in Phuket, Thailand.
    I am too old to build a simulator so I bought a big 6dof one from a Chinese Alibaba firm called LeaderDream that is actually made for amusement halls.
    It came with its own proprietary menu system and a set of racing games with a very good overall quality and performance. I was very impressed with the whole purchase and delivery process of this 450kg package too.
    I did not know much (and still don't) about simulators but after digging around in the internet I found out that this machine actually works pretty well with Simtools V3 so I bought a pro license.
    My first problem with SimTools V3 was that it does not save parameters for the MBOX interface if you select [6 Axis]. So now I have to fill these parameters in every time after a PC reboot.
    Did anybody of you know about this?
    152,183Coins
    +11,064 / 56 / -2
    Can you please share sequence pictures of your setting process that fails.
    Hopefully @yobuddy can chime in when he has a spare moment and consider what is going on with v3 in your specific circumstances.
  3. Gerrit Bijlsma
    Saturday
    Phuket, Thailand
    29Coins
    I noticed that the parameters are actually saved as you can see in the last picture where I scanned for the port number as text in files from the AppData\Local\SimTools3 files.
    It does save the parameters if you leave the [MBox Type] to [3 Axis] but NOT when you use [6 Axis] instead.
  4. Gerrit Bijlsma
    Saturday
    Phuket, Thailand
    29Coins
    Just to follow up on this problem,
    I contacted Rich at simtools about this problem too and he solved this problem quickly by issuing an updated version of the MBOX plugin.
    Thank you Rich.
    152,183Coins
    +11,064 / 56 / -2
    The SimTools dev team is awesome, and we all need to be grateful for them being this responsive to our community needs!
