Jabiru 55 motion sim
Discussion in 'DIY Motion Simulator Projects' started by 450caveman, Sep 25, 2025.
  1. 450caveman
    450caveman New Member Gold Contributor
    138Coins
    3DOF, SCN5, SCN6, 6DOF
    Hello evryone,
    I'm after a few ideas on the best way to turn this Jabiru 55 minus the main wings into a motion rig without changing the overall look of the aircraft.
    I'm going to take it to the Air force Cadets and other events for people to use and enjoy, so from the help of the community i would like any input, to help get this project up and running.
    Cheers
    Noel from Australia.
    152,700Coins
    +11,092 / 56 / -2
  3. 450caveman
    138Coins
    I’m confused by the comment “ It is important to further detail and be up front about the intended use” when I detailed the use ?
    The Jabiru 55 i have bought is
    • Length: 5.04 meters (16 ft 5 in)
    • Empty Weight: Approximately 170kg without the engine
    • when i put two POB at a maximum 180kg the sim will weigh 350kg.
    • as i said in my post the Sim will be used for the Airforce Force Cadets to , Fly in's, and other charity events, this will allow people to experience motion flight without leaving the ground.
    • The budget would depend on what type of equipment is available for me to look at and mount to the aircraft without too much modification, I’m a retired Pilot and I want people to experience what it’s like to fly.
      We are most likely going to do most of the work at our local Aircraft Museum the plane will be mounted to a purpose built trailer, so it is easy to take to shows.
