Question Problem installing
Discussion in 'SimTools DIY Version' started by JRG, Sep 25, 2025.
  1. JRG
    JRG New Member Gold Contributor
    20Coins
    Hello good afternoon, I'm new here, I've made a 2dof simulator with the help of the entire forum, I have everything ready and tested but today I had a problem, I uninstalled the simtools demo to install the pro for which I paid the license and when trying to install it I get an error that doesn't let me do anything, I've tried opening it in administrator, restarting, downloading different files but I can't find the solution, let's see if someone can help me, thanks
    PD:
    File could not be unzipped,
    This is the message I get
  2. yobuddy
    51,551Coins
    Are you using a VPN by chance?
    If so try turning it off for the install and see how it goes.
  3. JRG
    20Coins
    Hello, thanks for helping me. I use a normal connection, just like the first time I downloaded the demo version and without problems. The error came when I uninstalled that version and tried to install the pro version, whichever it is, it gives me an error.
    153,986Coins
    +11,161 / 57 / -2
    You should not have needed to uninstall simtools, just register the Pro license. So can you please explain exactly what you mean by the Pro version and where you got it from.
    Can you also please advise if you are using SimTools v2, or SimTools v3.
    As an aside, a file that will not unzip tends to indicate the downloaded file is corrupted.
    Can you please post a picture of any errors.
  5. JRG
    20Coins
    I made that mistake because I didn't know how to enter the activation code. I've tried the v2 and v3 versions of simtools that they send when you buy the paid license, and neither of them lets me, but I also can't install the demo version that I had previously installed again. I don't know what could have happened to the computer.
  6. Vigis1982
    Vigis1982 New Member
    - 71Coins
    Hi. I have exactly the same problem, I bought a DIY license and I can't install it. "Update file could not be installed". Could it be a problem with the server?
    153,986Coins
    +11,161 / 57 / -2
    This sounds like corrupt files.
    If you can try downloading SimTools v3 to another computer, as I suspect the issue is not SimTools but rather your computer: https://simtools.us/wp-content/uploads/v3_pro/repos_pro/SimTools_Installer.zip
    153,986Coins
    +11,161 / 57 / -2
    What version of Windows are you using?
  9. JRG
    20Coins
    Hi, the problem has been fixed. It seems to be with my internet connection, which is why it wouldn't let me install it on any PC in my house. I checked the connection and ran a couple of tests, and it was fixed. Now I'm trying to get Live for Speed to move the motors. Everything works fine in SMC3 and SimTools, but I can't get the game to move the motors.
    153,986Coins
    +11,161 / 57 / -2
    LFS has to be run in first person mode prior to being patched for motion, so just checking you did that: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  11. JRG
    20Coins
    Thank you very much for the help. I've tried it in first person, a whole race, exiting, entering, and doing it again, but I can't get it to move. Outside, in SimTools and SMC3, they move perfectly without any problem.
    153,986Coins
    +11,161 / 57 / -2
    Did you do that before patching LFS for motion, or after?
  13. JRG
    20Coins
    before and after
    153,986Coins
    +11,161 / 57 / -2
    I would suggest you un-patch LFS, shutdown SimTools, run a race in LFS in first person mode by hitting v on the keyboard, shut that down then reopen SimTools and patch LFS for motion.
  15. JRG
    20Coins
    Hello everyone, I already have the simulator up and running with assetto corsa, but I have just one problem, and that is that no matter how many times I change the values of Pitch, Roll, Sway... the simulator turns as if it were a motorcycle towards the side I turn the steering wheel and it does not simulate the G forces, I have tried a thousand things but it still does not work, does anyone know how to modify it, greetings to everyone and thank you
  16. noorbeast
    153,986Coins
    +11,161 / 57 / -2
    Please post pictures of your rig, so we understand the design, and also of all your settings.
  17. JRG
    20Coins
    Hello, this is my simulator, right now everything works perfectly, but it turns like a motorcycle, not like a car. I have tried to invert the direction in each of the boxes in Simtools. When I do tests in Simtools, they invert when I move the bar to one side or the other, but in the game there is no way to simulate the G forces like a car and I don't know what else to try. I don't know if something can be changed in Assetto Corsa, but it has me desperate because that's all I need to be perfect.
  18. noorbeast
    153,986Coins
    +11,161 / 57 / -2
    Can you please also post a picture of the Tuning Center while running the game.
    Also see the tuning tips in the FAQs, in particular the importance of tuning one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. JRG
    20Coins
    But the tuning center is to control the limits, not the movement it makes, right?
    153,986Coins
    +11,161 / 57 / -2
    The larger the TC value the slower the movement over a greater range and conversely the smaller the value the more immediate the movement, but over a smaller range.
