Help a newbie set up a home-made 6DoF platform
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Geoff M, Sep 14, 2025.
  1. Geoff M
    Geoff M New Member
    Australia
    23Coins
    Hi folks,
    I'm setting up a 6DoF platform and am completely lost when it comes to the electronic side of it.
    I am trying to use AS5600 Hall effect encoders with Arduino r3 controllers.
    For clarity I intend to use 3 Arduinos and 3 Dual H bridge drivers to drive 6 24VDC 500W motors via a lead acid (car) battery setup.
    These are my sticking points:
    1) I have no idea on how to set up the encoders. I am aware there is a couple of ways to set it up (I2C or PWM). I have no idea which is preferable, or if there is even a choice!
    2) After determining the encoder setup, Do I need to run end stops (eg micro switches), or does the encoder always know where "home" is? Are the limits set in the Arduino code?
    3) How do I wire the AS5600's to the Arduinos for whichever mode is the best. Does someone have a wiring diagram I can reference?
    4) Is there a depository, or downloadable file for the arduino code somewhere?
    Can anyone point me in the right direction as I am keen to get on with the project. I have no programming experience and very basic understanding of electronics, but am trying to wrap my head around it.
    Any help will be greatly appreciated!
  2. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
  3. Joe Cortexian
    1,519Coins
    If you are using the little square AS5600 ceramic PCB you have to remove a resistor for PWM to work. I think it’s R2 it’s not hard. Also you will need a low pass filter. Literally one resister and one capacitor. This will smooth out the PWM signal. They will always know where they are unless you use multi turn. They 360 degree devices.
  4. Geoff M
    Geoff M New Member
    Australia
    23Coins
    Thanks for the info! The thread recommended above mentions removing R1 and R2, which I have done. I am currently bench testing one channel, hopefully all goes well...
  5. Geoff M
    Geoff M New Member
    Australia
    23Coins
    Thank you so much for the reply! This guy's thread is very helpful. I'm working my way through it now...
  6. long16652
    long16652 New Member
    - 220Coins
    I think you can try the Thanos controller, which uses servo motors made in China. The control effect is very good and relatively safe. DIY like this is very prone to malfunctions and unexpected incidents
  7. Joe Cortexian
    1,519Coins
    That depends on the motor. Thanos works with AC pulse direction motors. Pulse direction AC servos have internal encoders and are typically applied to ball screw linear actuators.
  8. Geoff M
    Geoff M New Member
    Australia
    23Coins
    I'm playing with the motors now. I can see how it can be dangerous, especially if an encoder gets knocked (ask me how I know)....
    I'm going to play with the Arduino sketch with a view to adding some safeguards / soft starting, etc.
  9. Joe Cortexian
    1,519Coins
    There are varies of the sketch some included soft start. The key is to have an e-stop or kill switch. For nothing else to protect the equipment. In my experience DC gear motors are fine for lever arm systems. AC motors are better for ball screw systems.
  10. sam poole
    sam poole Active Member
    midlands
    31Coins
    What parts have you got? Any photos?
