FlyPT Mover 3.7.0.17
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,782Coins
    DC motor, 6DOF
    Ur Comanche team could have taken „LOADFACTOR SEMIBODY Y“. I would check in your place in simconnect if you don’t have a coherent value for heave from this variable.
  2. TheTakerPL
    TheTakerPL New Member
    118Coins
    Hi, I'm building 6DOF motion rig with hoverboard motor actuators. I've built first actuator for a try, and I'm stuck at connecting ODrive 3.6 with it. I managed to send data and it works in serial mode, but moves very erraticaly few rotations per time for small movement of slider. Sometimes it stops working completely, with no errors. I'm not sure what to type in serial window - p 0 <Axis1a><R0.A1.T><13> is it OK? I cannot find any tutorials, all of them are outdated. I don't understand what i need to type there, and "start", "stop" lines.
    I have ODrive 3.6 with firmware 0.5.6. Encoder is AMT10E2 with 20480 cpr. ODrive PID is configured.
    I have also built FFB stick (FFBeast firmware) and rudder with the same ODrive, encoder and motor, and it works perfectly.
  3. TheTakerPL
    118Coins
  4. Marco Annunziata
    919Coins
    I'm a bit confused about how the IF operations work. I can't quite understand what the Mover is supposed to compare — maybe an IN value? Or perhaps some telemetry data? It seems that the IF condition can compare one filter with another, but it's unclear.
    I thought that by leaving the "VALUE" parameter active, it might compare the IN value to an integer. However, this doesn’t seem to work, and if the integer is too small, the Mover doesn't even allow it to be entered.
    It would be great if the IF condition could compare things like acceleration, speed, or position — for example, comparing the heave value from a POSE (either IN or OUT). Just a thought, but maybe it could expand the flexibility of the system.
  5. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Hi, I've been running Mover 3.6.0 beta for years with no issue. I'm now testing Mover 3.7.0.9. I've created a generic profile for testing.
    In 3.6.0, the connection button when clicked shows Starting and then Disconnect. Clicking again: Stopping, Connect.
    In 3.7.0.9, the button only ever shows Connect, Starting or Stopping. I'm trying to connect to
    FT232R USB UART and Silicon Labs CP210x USB to UART Bridge. It appear to fail to connect to any COM port on my PC. The VR motion compensation also only shows Starting and Stopping. Never connected or "Disconnect".
    I've set up the serial connections identically to 3.6.0.
    What could I be missing? Thanks!
  6. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Adding any sources immediately breaks all serial port connections. Removing all sources immediately restores connections. Is that a bug or feature?
    [update] An added SingleWave module was preventing serial ports connections. Removing it restores connectivity.
    I had the occurrence of an instant reboot when clicking the Connect button for a serial connection. It hasn't reoccurred after the reboot. But haven't been stress testing it.
    I presume all these issues have been well-documented in these forums.
    Anyway, keep up the fantastic work.
  7. Opast
    Opast Member
    Chicago, USA
    172Coins
    3DOF, Arduino
    For DIY arduino uno, ibt2, 3DOF motion rig should I start with stable or latest beta version? Also, are there any video tutorials you can recommend?”
  8. tadeusz
    tadeusz New Member
    28Coins
    I'm a fan of the FlyPt program.
    I have a stupid question.
    Can we use the amazing FlyPt to build an FFB joystick?
    Is it possible for an input parameter like Speed to cause the force on the motor to increase, not the position?
    Best regards,
    Tadek
  9. hexpod
    berlin
    7,782Coins
    DC motor, 6DOF
    Yea, we Need an update.
  10. PavelF
    PavelF New Member
    186Coins
    The author hasn't appeared in the topic for a long time. The thought crept in that the program was abandoned. But today, unexpectedly, the program reported the presence of update 3.7.0.11
    My happiness knew no bounds! FlyPT - thank you very much for remembering us. May God grant you health and happiness!
  11. hexpod
    berlin
    7,782Coins
    DC motor, 6DOF
    I would advise to clear the registry in mover options and start a new config from scratch with this version.
  12. PavelF
    PavelF New Member
    186Coins
    Thanks for the warning.
    The previous version works stably on my tasks. I'll leave it on the main machine for now. I'll wait for more stable versions. I updated to the new one on the test machine. I'll experiment.
    The project is not dead - that's the main thing. Let's wait.
  13. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    I am very happy to see this news
  14. Marco Annunziata
    919Coins
    Hi Pedro, how are you? We received the update from the application, and we appreciate it a lot, but we haven't heard from you for a while. We hope you are well
  15. SimbaFlyer
    SimbaFlyer New Member
    10Coins
    Hi Guys, I am working on a 2DOF with DIY Actuators like @pmvcda design and ESP32 sketch at:
    https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/#post-139682
    I am currently bench testing the setup and can't seem to get the motors to turn. I setup FlyPT, and it reads the telemetry motion from LFS as I can see the 3D viewer movement. I have set up the string as per information in this thread and also changed bits to 15 for the actuators. Has anyone got this working with the ESP32 arduino sketch per Pedro's design with the newer version 3.7.09 of FlyPT? Any assistance is appreciated. Thanks!
  16. pmvcda
    15,659Coins
    Everything ok, just to much work. Can't even come here to post the updates.
    Trying to make it more stable and I will post here when I can trust it more. Stay tunned. The updates should show automatically in the menu.
    • Friendly Friendly x 2
  17. pmvcda
    15,659Coins
    .. just some new looks:
  18. mm982566
    mm982566 New Member
    US
    56Coins
    3DOF, 4DOF, 6DOF
    A very beautiful new UI, looking forward to the new version.
  19. pmvcda
    15,659Coins
    Mover 3.7.0.14
    New release update, many changes...
    Download here: https://github.com/FlyPTMover/Releases/raw/refs/heads/main/Mover 3.7.0.14 BETA.zip
    Trying to solve many problems. It's not stable and some UI scalling glitches, but here for who wants to try
    Some of the changes:
    -Better detection of devices
    -More features on conrolling UI with external devices, specially midi
    -Dark mode
    -UI scalling
    -Some new sources like wreckfest2 and Farming Simulator 19 22 25
    -Devices can be variables or even custom variables, allows adjustment on the fly of filters with a knob in your joystick or midi
    -Updates from the UI
    -Many bugs solved...
  20. dzq_stone
    dzq_stone New Member
    3Coins
    Hi
    I am try to move the motor use the odrive 3.6 and AMT102 encoder, when connect to the flypt system , i find the motor move tiny , my setting as the screenshot shown , if could would you mind tell me how to set to make the move large, thanks a lot.
