Spaceship Simulator
Discussion in 'DIY Motion Simulator Projects' started by Dude, Oct 3, 2025.
  1. Dude
    Dude Simonaut
    81Coins
    Hello everybody
    Finally, after more than 6 Months of planning and ordering, testing and drawing, i'm able to start my Spaceship Simulator project.
    Earlier this year, i already showed my main joint design here: https://www.xsimulator.net/community/threads/show-me-your-universal-joints.13026/page-4#post-256511
    First, some basic informations:
    Motivation:
    My 11 years old daughter started to be interested in space and space-traveling. Mostly after watching the movie "Apollo 13" and a visit in a space history museum, she wanted to make her own cockpit made of cardboard.
    I got instantly triggered to do this better, and i told her if she's interested in doing it right. She was (and still is)!
    So i planned something special.
    Not a copy or even near the Apollo Command Module, or the Gemini Cockpit, but it's definitely inspired by these missions.
    And yes... of course... i make this simulator also for myself, a dream comes true since i was a kid. In the 90s, I played StarWings on SNES and always dreamed to have something like that.
    Basic concept:
    • Using an euro-pallet as a solid base, a pallet lid as platform floor.
    • One main joint under the seat, two motors with levers for 2-DOF motion.
    • The Spaceship is a closed cabin on top of the pallet lid.
    • A lot of switches for different systems like climate control, power control, fuel management, communications and guidance.
    • Apollo-like Master Alarm system with real time monitoring of all systems, including air quality (co2 measurement) temperature and all subsystems
    • Flight controls: 2 Joysticks and 2 foot pedal-switches for 6 axis flight
    • Ubuntu based Computer with an RTX 3070 GPU
    • A 23" Screen is used as a "front window"
    • Audio-Effects for steering Jets, basic noise and engine noise
    Software:
    Space Engine by Cosmographic Software
    - There is no interface for motion control as far as i know. but it doesn't matter to me. Because we're in space, g-force is relatively predictable. Therefore i'll use the steering inputs to recreate the needed motor motions.
    Hardware:
    2-DOF Motion Hardware:
    • 2x ASME-MRB 400kg/cm Servo Motors
    • 2x Mean Well LRS-600 27V Power Supply
    • 2x Brake resistors 1500W 1.0 Ohm
    • 2x Circuit Braker 0-42V 50A
    • Arduino Leonardo
    Main Joint:
    • 4x Heavy Duty 20mm Ball Bearings
    • 2x 20mm x 200mm stainless steel shaft
    • 1x Pilar cross fixing clamp
    Motor Joints:
    • 100mm Stainless Steel Plate as a Lever (60mm travel)
    • 250mm rod wth ball bearing nozzles
    Computer Hardware:
    • 1x ASUS Mainboard
    • 1x Intel CPU
    • 1x ASUS Nvidia Geforce RTX 3070
    • 2x 16GB DDR4 RAM
    • 1x PCI Harddrive
    • 1x 23" EIZO HD-Monitor
    Other Hardware:
    • A plenty of Toggle Switches 2 & 3 Positions for in-Capsule Operations
    • 2x Push Buttons for PC reset and on/off switch
    • 1x Heavy Duty Battery Kill Switch used as "Abort Switch" to bring the capsule into a leveled position and turn off the motors
    • 1x Emergency Stop Button for real Emergency Shutdown
    • 4-6 (to be defined) Backlit LCD Displays 2 Lines / 8 Symbols
    • 1x Push Button Panel 4x4 Buttons for Guidance Verb/Noun input. This triggers Autopilot to pre-defined Space-Objects, landing sequence and so on
    • 2x Arcade 4-Axis-Joysticks with two buttons
    • 2x Foot-Switches
    • 2-6 (to be defined) Arduino UNO for Sub-System Controls
    • 1x Arduino MEGA for Master Alarm system
    • 1x MPU6050 3 Axis Analog Gyroscope for live-Leveling Calibration
    • 3-6x (to be defined) Arduino MP3-Player for in-Capsule Audio Effects
    • 2-4 (to be defined) 2W mini-Speakers for 3d Audio-Effects
    • 1x High Power 6 inch car Subwoofer for basic and engine noise
    • 1x Wireless car back drive camera with night vision and wireless Display for remote supervision of the Pilot
    • 1x Wireless HDMI Video Transmitter for remote Gaming Screen Mirroring
    • 1x Mean Well LRS-350 5V Power Supply
    • 1x Radio-Communications device (to be defined) to communicate with ground control (someone outside)
    I hold myself back to list the physical hardware, most of the material will obviously be mentioned during the construction.
    As you can see, there is plenty of hardware just for the simulated cockpit feeling. It's important to not just play a game inside a box that shakes a bit. it shall be a Spaceship where everything is trimmed to be a spaceship even without playing one second of SpaceEngine on the screen.
    Operations of the system is essential, it should feel real and integrated. For example: to power the module up, you have to really start up the different systems in a right order, so that all will operate correctly. Or if the temperature inside the capsule gets too high, Master Alarm will trigger so you have to react to it and activate the fans to cool the cabin down. (Climate control). Same for air quality inside the cabin (co2 measurement)
    Therefore there will be checklists for almost anything:
    • to power up the module
    • to power down the module
    • basic operations
    • navigation operation
    • Guidance module operation
    • Master Alarm handling
    • Emergency handling
    All this should emerge the feeling to really operate a spaceship of the 60s-80s with a futuristic touch.
    Building process:
    Now to the interesting part.
    Basic platform:
    I started with a standard Euro Pallet and a Pallet lid. Trimmed the "nose" of the pallet lid to make it a bit more interesting than just a box from outside view. Also every gram that can be saved shall be saved.
    First step: installing the main joint.
    To spread the weight to the whole pallet, i mounted it on two 20x20mm aluminium rails. The motors are mounted with a metal angle, spared out a bit of the wood of the pallet, so that it still will be possible to move the simulator with a pallet truck.
    The pallet lid gets the same treatment, aluminium rails for stability, main joint positioned directly under the seat position.
    Sawing two notches for the 2-DOF steering rods.
    Looks nice so far. Here some details of the motor positions and of the lever:
    Testing the seat position:
    Then I added a floor "rug" and the basic aluminium framing:
    That's the effort of 3-Days work so far (about 22h)
    next step: installing the seat and adding the fixtures for the 2-DOF rods.
    *to be continued*
    153,824Coins
    +11,150 / 57 / -2
    A great start and I am looking forward to seeing further developments.
    I am not sure how the servo motors will go, I guess time will tell.
  3. Dude
    Dude Simonaut
    81Coins
    I'm also a bit curious about that, but at the same time i'm relatively positive. They're specified as 400kg/cm @ 28V. My lever is 6cm, therefore i get about 60kg force per motor. The main weight stays on the main joint, so i stay positive about that. Still have the option to add couter weights and/or adding a supportive gas spring
  4. Dude
    Dude Simonaut
    81Coins
    Placed the suspensions and mounted the actuator rods:
    Seems to be stable so far, waiting for the brake resistors to arrive so i can test the motion.
    In the meantime, i'll continue to mount the seat, power supplies, wireing and also start building the cabin.
    153,824Coins
    +11,150 / 57 / -2
  6. Dude
    Dude Simonaut
    81Coins
  7. Dude
    Dude Simonaut
    81Coins
    Hey guys
    got some work done in the past weeks. Finally got the braking resistors delivered, so i was able to test the motors in motion. Following work is done by now:
    - Reposition of the main joint to get the rig better balanced
    - Wired the motors and positioned the brake resistors, circuit brakers and power supplies
    - Mounted the seat and started with the build up, things are getting serious now!
    On this^^ last image, you can see the "front window" of the simulator. Two acrylic-glass slices simulate a double glass window, and behind this, i'll mount the screen.
    On the left and right of the window, i'll install the switcher panels to operate the simulator's basic controls for environment, system power and alert system.
  8. Gadget999
    12,132Coins
    I have seen those servo/gearmotors for sale
    are they powerful enough ?
    look like a neat solution
  9. Dude
    Dude Simonaut
    81Coins
    First of all: i took the reinforced, 400kg/cm version of these Servos. Manufacturer claims that these Servos deliver those 400kg/cm @ about 27V. Look close at the tech specs, there are several different Servos out there from 100kg/cm all up to 400kg/cm.
    That said, these servos are deffo on the lower edge for such a project. I use a lever of 6cm, therefore the resilience "shrinks" to about 60kg per motor.
    You can't stand on the front end of the simulator, the motors will give in.
    I already ordered some gas springs to support the motors and to stabilize the whole platform.
    But i'm still positive to use them in my well balanced environment using a powerful main joint.
  10. Gadget999
    12,132Coins
    you may be able to use 2x motors together to double the power ;)
  11. Dude
    Dude Simonaut
    81Coins
    Wouldn't it be a real mess to synchronize the motors?
  12. Gadget999
    12,132Coins
    No, send the same data to both of them
    Should be simple as long as the position calibration is the same for both
  13. Dude
    Dude Simonaut
    81Coins
    Hmm, as long as the motors get the exact same resistance, this would be right. But i'm too afraid of a discrepancy over time, up to the point where the motors are fighting each other and they rip something apart. Also there is almost no room for two more motors. It would also mean to double up the power supplies and brake resistors, doubling costs and room.
  14. Dude
    Dude Simonaut
    81Coins
    Some further outer frame work is done and already mounted the screen behind the double plexiglass.
    What to do next?
    - Installing the Joysticks, pedal controls and the Arduino Leonardo to connect it to the PC and motors?
    or...
    - Switches, buttons, gauge-displays and Arduinos for Capsule Controls?
