Question motores off en smc3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Toño, Oct 13, 2025.
  1. Toño
    Toño New Member
    30Coins
    Hello. I am testing my 3DOF simulator with loss of traction, but when configuring it with SMC3, only one of the motors is on. When testing, I see that if I move the Hall sensors, I can now turn the motor on and I manage to move it, but it won't let me do anything else and it goes back to off. Can you help me?
  2. Toño
    Toño New Member
    30Coins
    I think I found the solution, I reversed the wiring of the motors that were not working for me.
  3. Toño
    Toño New Member
    30Coins
  4. Toño
    Toño New Member
    30Coins
    Can you help me with the configuration of the traction loss motor?
    I have the SimHub connected to my PS5 to get telemetry for the F1 24 game, but when I start the Arduino, the traction loss motor doesn't do anything. The other two do move. SimHub does let me move the motor manually. I don't know if I need to add something to the Arduino program? Or do I have something wrong with SimHub?
    152,700Coins
    +11,092 / 56 / -2
  6. Joe Cortexian
    1,369Coins
    Try it in LFS or Assetto Corsa. F1 may not support traction loss.
  7. Toño
    Toño New Member
    30Coins
    I tried it with Gran Turismo 7 and the traction loss doesn't work either. Could it be because I have the free version?
  8. Toño
    Toño New Member
    30Coins
    SIMHub and SMC3 configuration
  9. Toño
    Toño New Member
    30Coins
    In the end I bought the full license with the simulator but it doesn't work.
  10. Joe Cortexian
    1,369Coins
    Most people here use SimTools 3 which is free. It might works with SimHub but I can’t help you there.
