6DOF FlyPT project for sale
Discussion in 'Marketspace - Marktplatz' started by Gabor Pittner, Nov 3, 2022.
  1. Gabor Pittner
    Gabor Pittner Active Member
    Szekesfehervar Hungary
    1,395Coins
    The base and the moving platform are not inkluded sorry.
    These are some pictures about items.
    20240929_152608.jpg 20240929_152615.jpg 20240929_152635.jpg 20240929_152700.jpg 20240929_152705.jpg 20240929_152711.jpg 20240929_152717.jpg 20240929_152724.jpg 20240929_152730.jpg 20240929_152734.jpg
  2. Gabor Pittner
    1,395Coins
    Here is a small video about it:
  3. Mech1
    Mech1 Member
    182Coins
    I want to buy asap. Please, answer in PM.
  4. Deleted member 38270
    I'd like the dimensions of the lower base, please.
    Do you have the dimensioned drawings?
    Best regards,
    Tadek
  5. Deleted member 38270
    I'm from Poland, so I prefer local pickup.
    Best regards,
    Tadek
  6. Mech1
    Mech1 Member
    182Coins
    Sorry man, im buying this. And i will buy it 110%. I allready conact with seller some time ago and we are in proces ;) It was so long time here and nobody interested. Now sorry, it is mine :)
  7. Deleted member 38270
    Hi Mach1
    You're not going to buy it anyway
    You're just talking
    Best regards
  8. Mech1
    Mech1 Member
    182Coins
    Interesting, I didn't know you're in charge of my wallet. Don't warry, when i get platform, I'll send you a postcard from the cockpit.
  9. Gabor Pittner
    1,395Coins
    Sorry I didn't follow the topic nowadays.. We just talked PM with Mech1 :thumbs
    Its sold out. Thank you so much! :cheers
  10. Mech1
    Mech1 Member
    182Coins
    Today I received the package from the seller. Well... even when buying from such sites, you have to be very careful!!!
    4 out of 6 actuators are broken at the base. It’s impossible not to notice this before shipping.
    Apparently, that’s the main reason why they were sold — the bases can’t handle the load and keep breaking. The 3D-printed actuator bases just crack apart.
    This is a very dangerous thing, and if I hadn’t checked it first, who knows what could have happened if someone tried to use it…
    The seller clearly knew about this issue. I’ll try to attach some photos here if possible.
    But I’m really disappointed — it feels like money thrown away.
    Even if I reprint these parts and replace them, the same problem will happen again soon, since the bases are already cracked in the same places on two more actuators — it’s only a matter of time before they break as well.
    In short — don’t trust anyone! I’m sure the seller won’t want to refund me, because there’s no way he didn’t know about this defect from the start and just hid it.
    Now I’m going to write to him…
  11. Mech1
    Mech1 Member
    182Coins
    More photos
  12. Gabor Pittner
    1,395Coins
    Oh my God, I can’t believe this! I packed perfectly intact, undamaged actuators. They must have been damaged during shipping.
    The 3D-printed parts can easily withstand that level of stress. It would never be my intention to deceive or mislead anyone.
    I’m offering to reprint those parts.
  13. Deleted member 38270
    I think it would be best to make these supports out of metal.
    Best regards,
    Tadek
  14. Deleted member 38270
    Hi, maybe you want to sell them?
    Best regards,
    Tadek
  15. Aerosmith
    Aerosmith Active Member
    self employed
    2,735Coins
    3DOF, AC motor
    The design of the actuators look actually quite good and solid. The location where the U-joint brackets cracked seems to be the only weak spot. I'd try to re-print them 90° rotated. That will require support material since the upper half of the fork will be floating. But it means the printing layers will be aligned to the direction of the pull force instead of a right angle which caused de-lamination.
    If that still doesn't help you could divide the part into two errr... three pieces and insert a metal plate in the middle. This would easily withstand a lot more force.
  16. Deleted member 51784
    Do you have the STL file or drawing file for these parts. I'm curious if there is stronger cost effective alternative to using 3d printed parts.
  17. Gabor Pittner
    1,395Coins
    Yes I have, but now I try to find someone who can make it from alu with CNC.
    And we have different idea too. The buyer is thinking about alternate ball joint solution. I will pay for it of cource
  18. Gabor Pittner
    1,395Coins
    Now I can see what happened but I have never checked those parts with make force, ... so Honestly I have not known about it. :(
  19. Mech1
    Mech1 Member
    182Coins
    Is it possible to use some different program with normal interface and with no patches every week? I just want to play DCS. That everything I need. Please someone can give me the way how to do it ?! SimRacingStudio was perfec program, now i understand how perfect it was. I was tginking that most problem with 6dof actuator platforms is constuction and materials.... but the most problem is soft. I almost not want to try to set it up. My advice to everyone- buy normally dof platforms, not DIY sh#@t of you have money. It is most bad way to have fun- 6 dof diy platform. It is not fun it is all time only problems from all the ends. Buy dof reality and be happy. No fun. No way how tk set it up. Wasted a lot of time and money...., better wqs buy dof reqlity H6. Do not repeat my faults.
  20. Gabor Pittner
    1,395Coins
    When something doesn’t work out despite all the hard work, it can be really discouraging — but believe me, you can do it, and the platform will bring you joy too in the end. Dont give it up.
