Question Problem installing
Discussion in 'SimTools DIY Version' started by JRG, Sep 25, 2025.
  1. JRG
    JRG New Member Gold Contributor
    20Coins
    But the problem I have is that they should turn in the opposite direction when I turn the steering wheel. In terms of response and speed, the simulator works perfectly. The only thing that is strange is turning as if you were doing it with a motorcycle.
    153,812Coins
    +11,150 / 57 / -2
    It could be that you have the Dir settings for sway misconfiguration, sway should lean away from a corner.
  3. margolle
    margolle Member
    104Coins
    Hello
    (I'm using Google Translate)
    I've been playing with SimTools v2 for several years. I want to play iRacing, but v2 doesn't work with the plugin. I decided to upgrade to SimTools v3 with my v2 license.
    Bug after bug and error (unzipping and GUI).
    I formatted my PC and installed all the Windows and Intel updates.
    Windows 11 25H2 12th Gen Intel(R) Core(TM) i9-12900H (2.50 GHz), 32GB of RAM, 3080 Ti. I can't even install v2 anymore; my sim is lost. I'm so sad, please help me!
    153,812Coins
    +11,150 / 57 / -2
    Did you follow the earlier advice in this thread:
  5. margolle
    margolle Member
    104Coins
    Yes, I read everything before writing to you. My connection is wired. I have fiber optic.
  6. margolle
    margolle Member
    104Coins
    The 7_custom folder is missing from my downloads.
    153,812Coins
    +11,150 / 57 / -2
  8. margolle
    margolle Member
    104Coins
    identical result
    153,812Coins
    +11,150 / 57 / -2
    Something on your computer is likely interfering.
    Try uninstalling, then temporarily disable the firewall and antivirus, reinstall and try running.
  10. Vigis1982
    Vigis1982 New Member
    - 71Coins
    Hello, i thing that I am solved this when i disabled in windows function "user account management" like this picture in below. Try it.
  11. margolle
    margolle Member
    104Coins
    How do I access this setting?
  12. margolle
    margolle Member
    104Coins
    no
  13. margolle
    margolle Member
    104Coins
    Using another computer with Windows 10 22H2 and disabling everything as described above, it produces the same error.
    153,812Coins
    +11,150 / 57 / -2
    Perhaps @yobuddy can provide some insight into how to further troubleshoot what is something odd in your particular setup.
  15. margolle
    margolle Member
    104Coins
    I reset Windows Defender's settings to default, left it all day, and now it works!
    I don't understand it at all.
    I'm not celebrating too soon because I still have to configure everything. I'll come back and let you know how it goes.
  16. margolle
    margolle Member
    104Coins
    I can confirm that everything is working fine even though I haven't changed anything.
    I don't have any concrete answers to give other than waiting for certain Windows Defender updates to be offered 24-48 hours after formatting my PC.
    I have two technical questions.
    -1* I would like manual tests to be very slow, how can I adjust this?
    -2* I have two DIY licenses and I only use one. Is it possible to give you both licenses to get a single Pro license?
