2Dof Motorcycle project help
Discussion in 'DIY Motion Simulator Projects' started by 204flightsinmotion, Oct 22, 2025.
  1. 204flightsinmotion
    204flightsinmotion Member
    209Coins
    So ive got it running. Took me a few days to get the controls all figured out but things are coming along. But im having an issue with one of my motors going passed the limits. Ive set the clip limit to the max and ive massively reduced the limits in simtools and for some reason only one side goes passed and then stays stuck there. I uploaded a video to show what’s happening. Also any tips at all willl be appreciated.
    I got some 100 lb shocks to add to this project just havnt figured out where to put them yet. Also any advice on that would be appreciated.
  2. Joe Cortexian
    1,537Coins
    Your video is private. Set the protection to “only with a link” or public.
  3. 204flightsinmotion
    209Coins
    I’m so embarrassed. Lol ok I fixed it
  4. Joe Cortexian
    1,537Coins
    Wow sweet setup. I didn’t see you popping any wheelies though.
    I noticed that your lever arms are almost vertical at times. I suspect that is overshoot and the impact of sudden moves. I had that problem for a while and then I figured out if I had a good solid hard stop at 80 or 85 degrees it was fine.
    I also have limit switches but I don’t know how much they do. The for sure cut power to the motor but the motor should be going the other direction. You can set it up so you cut power in one direction.
  5. 204flightsinmotion
    209Coins
    thank you so much for your reply, so in your opinion, I should extend the arms slightly so that the lever when the bike is level is lower correct? Should I also move the mount on the lever closer to the motor farther away or keep it where it is.
    153,758Coins
    I think what @Joe Cortexian means is that your levers are almost vertical at times, like at 0.18 in the video, which puts a huge strain on the motors and risks exceeding limits.
    The levers should aligned with the floor when the bike is in its default level position, and efficiency will be greatly reduced with lever movement over about 38 degrees in either direction.
    • Old Old x 1
  7. 204flightsinmotion
    209Coins
    This photo shows my resting position. I did more tinkering in smc3 and I noticed for some reason motor 1 (right motor in pic) when I set my clip limits the top clip limit does not work. If I move the motor to the bottom clip limit it bounces it back up as it should but if I go to top clip limit it goes past it and will not correct. I believe that’s what’s happening here. So I assume it’s either my arduino or motor IBT2. I ordered the 100A motor shield that I noticed people talking about on this forum and a new arduino just to be sure that I do this right once and for all. In your opinion should I do any of the following:
    1. Should I extend the arms so that the lever on the motor is more parallel with the frame?
    2. Should I move the bike forward two inches and extend the arms so that the angle on the arms is increased. (or move the motors farther back )
    I thought about doing this but it will be a little difficult to move the motors as they will have to be mounted behind the frame and the frame slightly extended to acomoda-te the motors. Or I could add another one or two of those 1 inch by 2 inch tubing and move the u joint forward?
    I really really appreciate all your assistance!
  8. Joe Cortexian
    1,537Coins
    Ideally extend the arms. I don’t see any reason to move anything else.
    I don’t think the problem that you described has anything to do with the length of the arms. So if the arms are already as long as they can get maybe wait until you fix the root electronics problem. If it’s a simple adjustment I would extend them.
    Can you reproduce the issue in SMCUtils? If so then you can see where the sensor line actually is. I suspect you are relying on the mechanical position not any feedback. I had a pesky issue which would reproduce with the “motion” test. The abrupt changes in direction would trigger my error in like two minutes.
    If that green line goes outside the limit the motor will shut off and you have to repower the Arduino to get it back on.
  9. 204flightsinmotion
    209Coins
    So if I move the motor to the top clip limit it won’t push back down the way the bottom one does. It just goes passed it and stays there. So it’s easy to reproduce
  10. Joe Cortexian
    1,537Coins
    Both motors or just one? Can you post a screen shot of it in a fault state? The whole window not just the graph. I have never seen anything like this.
  11. 204flightsinmotion
    209Coins
    Yes so it’s only motor 1 that’s doing it and only on the top not the bottom. I will post a screenshot Sunday or Monday. Just out of town till Sunday night.
  12. Joe Cortexian
    1,537Coins
    Now I am thinking motor driver.
  13. 204flightsinmotion
    209Coins
    here is that photo
    153,758Coins
    Try setting Fpwm to 25.
  15. Chris_Beeves
    2,164Coins
    Cool project!
  16. sam poole
    sam poole Active Member
    midlands
    31Coins
    I noticed your steering doesn't look natural
    Can I recommend opposite steering direction as that's actually how it work on a real bike when you lean and maybe less travel on bars for full lock?
  17. Chris_Beeves
    2,164Coins
    Steering is one of the biggest challenges when it comes to motorcycle simulation. Inverse steering does make more sense at corner entry, but after that it feels like you’re in Tokyo drift. So it’s a compromise challenge you can’t really win.
    And anyway, 95% of people that get on a bike rig will steer it like they would a tricycle.
    To get realistic output and input there aren’t really any solutions available out there, especially since the directsteer functionality of ‘GP-bikes’ stopped working.
    In any case, I agree that a little less travel would probably be a positive thing!
  18. 204flightsinmotion
    209Coins
    So I finally am at the finish line with this motorcycle sim build. The sabertooth are all wired and working. Everything seems good in smc3 but for some reason when I’m playing a game within a minute my motors start shaking like crazy. Motor 1 will just start pulsing and I have to hit the kill switch. I can’t figure out why it’s happening.
    153,758Coins
    Can you please provide pictures of all your SMC3 and SimTools setting.
    Additionally, can you provide any further context other that time as to when the oscillation starts, have you hit anything, is it in the same spot, does t seem to have any consistent basis as a trigger, like thermal issues?
