Showroom Gravideck GT35 simulator... with pitch & roll axes above the user
Discussion in 'Commercial Simulators and Peripherie' started by JCM, Oct 22, 2025.
Tags:
  1. JCM
    JCM New Member
    113Coins
    Greetings
    We presented this new motion simulator concept in the Sim Racing Expo 2025 and many professional pilots who tried it absolutely loved it.
    The goal of the whole architecture is to put the pitch & roll axes above the user's head, in order to eradicate inverted motion cues during transient pitch & roll maneuvers.
    Check here to see it in action : https://www.youtube.com/shorts/7fyYT8dI-Fs
    Cheers
    Sam
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,927Coins
    3DOF, AC motor
    LOL, I had a similar idea about a year ago. The basic idea of the pivot point above the pilot is not all that bad. It combines the surge/pitch and roll/sway cues in the right directions as opposed to a U-joint below the seat.
    But IMHO this only makes sense for DIY projects with very limited budget where you're forced to limit the number of axes to 2 or 3. Your rig is so big it doesn't fit into any of our living rooms. So I assume it's targeted to commercial customers like amusement parks. The big servo motors and gearboxes look quite expensive. I guess you could get six smaller motors for the same money.
    So what is the advantage compared to a standard Stewart platform?
  3. JCM
    JCM New Member
    113Coins
    The goal was to move an entire 200kg cockpit/passenger along pitch (+- 20 degrees) roll (+- 20 degrees) and heave (+- 250mm)... while having the pitch/roll axes of rotation natively centered around the head of the user.
    I reasoned that those DOFs were the most sollicited for a GT style driving experience, ie driving a fast car on a slightly sinewy road. Same goes for most flight simulation sequences
    The axes of rotation near the user vestibular system were the non-negotiable requirement of my design. Inverted motion cues that happens when the axes of rotation are placed well below the users head are realism killers.
    Stewart platform can create a "synthetic" center of rotation at a higher position, it comes at the cost of quickly degrading the usable workspace due to :
    1) Actuator length limitation
    2) joint angle limitation
    3) Ceiling height limitation
    So I went to a simpler 3RRS architecture instead, with axes natively positioned above the user. It can work with full extension under a ceiling of 2m10.
    Certain Stewart platforms have adopted the "suspended cabin" approach, but they have to be truly massive to avoid the suspended cabin from colliding with the actuators
    My current design footprint is about 2m x 2m. I could certainly make it smaller, but the pitch, roll angles could not be as large, even if I use curved arms instead of straight ones.
  4. Doon1
    Doon1 Member
    403Coins
    I like it.
