Disabled search for non registered users
Discussion in 'Forum and Website' started by RaceRay, Aug 30, 2010.
  1. RaceRay
    Hamburg, Germany
    23,892Coins
    Hi guys,
    i had to disable the search function for non registered users, because the cpu load grew too high in the last weeks. Everytime this happens, the forum is programmed to disabled the search function automatically.
    I hope that reduce the load enough to keep the searchfunction alive for every member.
    If you watch any more, that you cannot use the searchfunction although you are registered, please post it here, so i have to find more settings i can adjust.
    Regards
    René
  2. BFBCAcid
    BFBCAcid New Member
    - 38Coins
    Just an F.Y.I. I just recieved this message.
    Sorry but you cannot use search at this time. Please try again in a few minutes.
    I am a registered user and was logged in at the time this message appeared.
  3. RaceRay
    Hamburg, Germany
    23,892Coins
    Thanks, you are right. Obviously i have to spent more time in that issue.
    Br
    René
  4. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    maybe you could add a google search for the non registered users, this way they still have the possibility to easy search.
  5. RaceRay
    Hamburg, Germany
    23,892Coins
    Yes, i can do that, but i would not solve the problem with the cpu load. I have to examine whats wrong. Estimate the database keyword search index with about more than 800.000 entries is the bottleneck which blows the load.
