3dof sim project for flight and space gaming
Discussion in 'DIY Motion Simulator Projects' started by SaintFrank, Jul 28, 2025.
  1. SaintFrank
    SaintFrank Active Member
    Proces operator
    Nederland
    232Coins
    Hi Everyone ,
    It has been a while since my 2dof project.
    https://www.xsimulator.net/community/threads/2-dof-flight-race-build.16924/
    Last 2 years I didn't do much with my 2dof rig, because of serious back injury.
    While recovering I came up with the idea of a building a new simulator.
    The 2dof build was built with simple tools, so upgrading some tools was my first mission.
    I build a workbench and bought a vice and a drill press.
    Then came the idea of building a cnc milling machine, that took over 6 months to complete.
    But I got it to work and it does cut aluminium.
    Needed to learn basic CAD/CAM, I use Autodesk Fusion, got the basics under control so I can make parts for the new rig.
    Now it's finally time for new simulator ideas.
    A 6 dof stewart platform would be great, but with the cnc taking a large part of the budget.
    I wanna try and make a 3dof with heave first.
    I really like sebastians sim
    https://www.xsimulator.net/community/threads/my-3-dof-with-heave.18449/
    And Codac version of the same approach
    https://www.xsimulator.net/community/threads/f1-like-3dof-simulator-with-heave.18845/
    The 500Watt motor with gearbox they use in their simulator look powerful and budget friendly.
    I ordered 3 of them with the same gearbox of Sebastian and start building the 3dof simulator.
    With the experience of the first build, better tools and the help of this forum,
    I’m looking forward to a new simulator adventure.
    I will post regular updater and lots of questions.
  2. SaintFrank
    Proces operator
    Nederland
    232Coins
    Started with the design for the simulator base , 120° angles between motors.
    I will use 4040 aluminium profile and standard corner brackets .center and corner plates will be made out of 6mm aluminium.
  3. SaintFrank
    Proces operator
    Nederland
    232Coins
    I Got started on the simulator base. It got a bit bigger then planned:grin. (1mtr x 1mtr)
    I had some 12040 aluminium left from the cnc machine project , and made use of that.
    Wanted 120 degree angles between the motors.
    So Cut the 60° connectors on the side out of 8mm aluminium with help of the cnc.
    Waiting for more alu. to arrive, to make centerplate and make motor mounts for the other motors
    the mounting plates for the motor are also 8mm thick , hope this will be sturdy enough.
  4. SaintFrank
    Proces operator
    Nederland
    232Coins
    update:
    2 motor levers made , out of 20mm aluminium. they fit nicely but have some play , I have to deal with that later.
    made 8mm holes at 60-80-100mm distance to the shaft.
    As spacers I use steel threaded inserts , that I use to clamp down material on my cnc machine.
    The Y-shape constuction is next , most use 4040 extrusion with m8 thread to connect the rod ends with bearings,
    But was thinking of getting m8 steering rods like these. with a length of approx. 180mm
    Has anyone tried these before , will 6 (2 per motor) be strong enough for around 110 kg weight on top?
  5. SaintFrank
    Proces operator
    Nederland
    232Coins
    I managed to get some work done.
    Motor levers are done en made the Y-shape connections on them .
    The top bar is made out of 2 stacked, 4mm alu corner profiles.
    It feels pretty solid , I cut put some 4040 alu profile underneath if needed.
    On the bottem connection ,
    I used M8 threaded rods ,So 6x m8 bolts most hold the full weight , seen it used on other rigs but still not sure if this is strong enough
    on top I used M12 rods , they look pretty solid
    I was thinking the whole y-shape rotate and sway to the left and right on the rod.
    But it can only rotate.:o:
    next up is the upper part , is it better/stronger to make a triangle on top or another Y shape like the bottem?:nerd
  6. SaintFrank
    Proces operator
    Nederland
    232Coins
    Update time
    I recieved the motor controllers and the fuse hub.
    Connected meanwell 1500W psu and tested the motors with the buttons on the controllers.
    everything worked fine but they run at fullspeed of approx. 60rpm
    When jogging a motor repeatedly , the psu cut out.
    probably from overcurrent /regenerative current.
    after lot of reading on the forum about shuntregulators , schottky diodes and more.
    I made the decision to go for batteries (2x12V in serie)
    managed to get my hands on 2xVarta AGM 12V 95Ah (They are big and heavy) for only 50 euro.
    This is the setup for the electronics for now.
    Have question about recharging the batteries with the PSU.
    but will post them in my question thread.
    next up is the arduino and hall sensor part .
  7. SaintFrank
    Proces operator
    Nederland
    232Coins
    I finally got some time , working on the electrical side of my simulator.
    I added a switchpanel that is normally used on boats
    it has a voltage meter (so i can moniter it coming from the PSU
    usb ports , I intend to use as charge port for my VR set
    2x 24V-100a relais
    one to switch power from PSU to battery, and the other to switch power to the sim .
    put an emergency switch in serie with it
    KWS DC200 -100A volt/amps meter.
    this to moniter voltage, amps and Watts of the sim.
    schematic
    I building it in a cabinet that will stand besides the simulator it self.
    Still work in progress , will add some pictures later.
    set voltage of the PSU to 25.6V the diodes and relais have some voltage drop over them , leaving 25.2V after them to the batteries and rig.
    So all the 24V wiring work is done , motors working great, when pussing manual buttons on the cryton controllers.
    Next up is finishing the wiring of the arduino side, will use 3 arduino boards one for each motor.
    it should work with 2 but with 3 it looks more symmetrical with the cryton drivers.
  8. SaintFrank
    Proces operator
    Nederland
    232Coins
  9. SaintFrank
    Proces operator
    Nederland
    232Coins
    Busy with tuning motors with smc3 , first one works fine, but with multiple arduino's how do you make that work?
    I keep getting connection error when trying to get the second on to work.
    do you have to make 3 arduino folders on you pc , one for each motor.
    and each it's own com port.
    153,830Coins
    +11,151 / 57 / -2
    Each Arduino will have its own com port, check in Device Manager.
  11. SaintFrank
    Proces operator
    Nederland
    232Coins
    yes i checked in device manager and changed it in the ini file , everything checkes out.
    but smc3 is not connecting.
    Motor 1
    PWM pin 9
    Dir pin 2
    pot pin A0
    do you have to use ?
    Motor 2
    PWM pin 10
    Dir pin4
    pot pin A1
    do you have to use different pins per motor even if you have 3 arduino's
    because they use different com ports same pins should be no problem was my guess
    153,830Coins
    +11,151 / 57 / -2
    No you should not need different pins per motor if using individual Arduinos, you just have to treat them as individual in SMC3 to set each up, ensuring the IDE com port is correct for each.
  13. SaintFrank
    Proces operator
    Nederland
    232Coins
    ok very strange
    loaded same code to second arduino, same wiring.
    I made 2 folders on the pc ,one for motor #1 and one for #2
    each folder contains a smc3 exe and the ini file.
    changed com port in the ini files so thay match the COM ports
    But when i try to open SMC3 for teh second motor , it doesn't work , the pop up comes to stop ,retry or ignore.
    for motor 1 the file looks like this
    # SMC3Utils.ini
    UDP_PORT=20017
    COMM_PORT=4
    IMG_PATH=c:\temp
    motor 2
    # SMC3Utils.ini
    UDP_PORT=20017
    COMM_PORT=7
    IMG_PATH=c:\temp
    153,830Coins
    +11,151 / 57 / -2
    Check and if needs be set the Arduino IDE com port via Tools->Serial Port menu.
  15. SaintFrank
    Proces operator
    Nederland
    232Coins
    Thanks noorbeast ,
    I found the problem , the shield on the arduino had some bad connection.
    Got all 3 motors working on smc3.
  16. NickD
    NickD New Member
    143Coins
    Your project is very similar to mine in design and I'm actually at the same stage as you. I am almost ready to update my page (https://www.xsimulator.net/community/threads/g-seat-racing-sim.17132/#post-258177) with my test of all three motors too. I was curious why you chose three separate arduinos for each motor instead of using one for all three?
  17. SaintFrank
    Proces operator
    Nederland
    232Coins
    Your build looks great, really solid and rigid .
    I use Cryton MD30C drivers , and Sebastian https://www.xsimulator.net/community/threads/my-3-dof-with-heave.18449/page-2 in his build ,had problems with the 3rd motor , the third motor in smc3 only works on 4 or 31kHz.
    31Khz might blow up the driver and 4Khz gives noticable noice.
    he went for 2 arduino's , I could have done the same. it works fine.
    I went for 3 just cosmetics reasons , and I had plenty of arduino's
    If you use IBT-2 drivers, I think you'll be fine using one arduino.
  18. sam poole
    sam poole Active Member
    midlands
    31Coins
    It's always nice to have a spare output from an Arduino incase you want to add a new Dof or accessory
    Great looking build btw
