Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. noorbeast
    154,322Coins
    +11,179 / 57 / -2
  2. Kevinski
    Kevinski If it doesn't fit, hit it until it does. Gold Contributor
    Australia
    115Coins
    Love the lime green George. Great work on cleaning up your files. Will try and have a tutorial up by Sunday.
  3. Alvaro George Menendez
    Alvaro George Menendez New Member Gold Contributor
    Sydney NSW Australia
    81Coins
    Thanks for the tip Noorbeast. I have tried it in various positions before welding it in place as it lends itself to the best-balanced point with me in the seat. I followed Kevinski's design & advise to have a moveable seat frame (in green with springs to accentuate surge/heave) that I can push forward in the top frame if we find the motors struggle a bit. The genius in this design is that we can slide the green frame (with the seat) forward along the black top frame easily hence closer to the uni joint. Thanks again for the input...
  4. Alvaro George Menendez
    81Coins
    Thanks mate.. It's a father / daughter ADHD project... the green matches her nail poilish .. Hahahahahaha !
  5. Kevinski
    Australia
    115Coins
    @Alvaro George Menendez Better late than never George. Hope this helps with your issues.
  6. Alvaro George Menendez
    81Coins
    Thanks Kevin - appreciate your time and effort to help me through it.. will watch it now and follow the instructions. On another matter... I've been playing around with getting a seatbelt tensioner to work on the motion sim rig. See the photos of my crazy handiwork so far as i only started on it this afternoon ... trying to use the differential changes in latitude between the top frame and the central spine to give me left and right pulling force on the seat belt straps so that it translates into G force sensation. The winch rollers may be required to mitigate losses between vertical and horizontal plane change of the shoulder straps at the top of the seat. The green (with the big Knot ) and Blue rubber straps that connect the bottom of the rig to the seat belt straps are required to get that left and right "pulling" force sensation.  Thanks again Kevin! tensioner IMG_8775.jpg tensioner IMG_8776.jpg tensioner IMG_8777.jpg tensioner winch roller IMG_8778.jpg
  7. Alvaro George Menendez
    81Coins
    Hi Kevin ... It's ALIVE It's ALIVE ! Followed your video as soon as I got home from a field trip this week.. worked first go, but it did surprise me as I didn't have the right values in SMC3 set.. LOL bent a 10mm threaded tie rod a little.. It's a beast of a rig and deserves respect. Again mate - Thank you for your valuable time and effort in helping me out. I also got the chance to finish the seatbelt tensioner.. all for under Aud $100 ( pre loved 4 point harness and 2 x boat trailer rollers ) first trial smc3 settings IMG_8786.jpg first trial smc3  ooops IMG_8784.jpg
  8. Kevinski
    Australia
    115Coins
    I reckon we should discuss this stuff in a separate thread George so we aren’t polluting this thread with unrelated sabretooth specific stuff. I’ll message you and we’ll go from there.
  9. Tricsixty
    Tricsixty New Member
    LAME
    Adelaide, South Australia.
    7Coins
    4DOF
    I am about to lose my s%$#, I can't get the script to upload despite following the step by step. I have two 2 x 60 ST with Uno R4s. I get the following when I try and verify -
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:145:17: error: 'PORTD' was not declared in this scope
    int OutputPort =PORTD; // read the current port D bit mask
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void setPwmFrequency(int, int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:256:13: error: 'TCCR0B' was not declared in this scope
    TCCR0B = TCCR0B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:260:13: error: 'TCCR1B' was not declared in this scope
    TCCR1B = TCCR1B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:278:13: error: 'TCCR2B' was not declared in this scope
    TCCR2B = TCCR2B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void InitialisePWMTimer1(unsigned int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:286:3: error: 'TCCR1A' was not declared in this scope
    TCCR1A = (TCCR1A & B11111100) | (wgm & B00000011);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:287:3: error: 'TCCR1B' was not declared in this scope
    TCCR1B = (TCCR1B & B11100111) | ((wgm & B00001100) << 1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:299:3: error: 'ICR1' was not declared in this scope
    ICR1 = CountTOP; // Set the TOP of the count for the PWM
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void InitialisePWMTimer2(unsigned int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:315:5: error: 'TCCR2B' was not declared in this scope
    TCCR2B = TCCR2B & 0b11111000 | Timer2DivideMode;
    In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/String.h:33:0,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/IPAddress.h:24,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/ArduinoAPI.h:30,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/Arduino.h:4,
    from C:\Users\user\AppData\Local\arduino\sketches\3C58A3BA5EA2888EFC33DE08A0B2F8D6\sketch\SPS_8.2_softstart.ino.cpp:1:
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void MyPWMWrite(uint8_t, uint8_t)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:21: error: 'TCCR1A' was not declared in this scope
    sbi(TCCR1A, COM1A1);
    C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/deprecated-avr-comp/avr/pgmspace.h:38:23: note: in definition of macro '_SFR_BYTE'
    #define _SFR_BYTE(n) (n)
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:17: note: in expansion of macro 'sbi'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:29: error: 'COM1A1' was not declared in this scope
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:50: note: in definition of macro 'sbi'
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:29: note: suggested alternative: 'COM1'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:46: error: '_BV' was not declared in this scope
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:46: note: suggested alternative: '_B'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:344:23: error: 'ICR1' was not declared in this scope
    top = ICR1; //Timer1_GetTop();
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:347:29: error: 'COM1B1' was not declared in this scope
    sbi(TCCR1A, COM1B1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:347:29: note: suggested alternative: 'COM1'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:353:9: error: '_SFR_MEM16' was not declared in this scope
    _SFR_MEM16(regLoc16) = tmp; //(tmp*top)/255;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:353:9: note: suggested alternative: '__REV16'
    __REV16
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void setup()':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:393:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:399:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:406:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:419:16: error: 'PORTD' was not declared in this scope
    OutputPort=PORTD;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:9: error: 'ADCSRA' was not declared in this scope
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:5: note: in expansion of macro 'sbi'
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:9: note: suggested alternative: 'ADC_0'
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:16: error: 'ADPS2' was not declared in this scope
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:453:16: error: 'ADPS1' was not declared in this scope
    cbi(ADCSRA,ADPS1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:75:51: note: in definition of macro 'cbi'
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:453:16: note: suggested alternative: 'ADC_1'
    cbi(ADCSRA,ADPS1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:454:16: error: 'ADPS0' was not declared in this scope
    cbi(ADCSRA,ADPS0);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:454:16: note: suggested alternative: 'ADC_0'
    cbi(ADCSRA,ADPS0);
    Multiple libraries were found for "Sabertooth.h"
    Used: C:\Users\user\Documents\Arduino\libraries\Sabertooth
    Not used: C:\Users\user\Documents\Arduino\libraries\8127a25499541b9f64b53ae8c9261ffb-0ef79203ed4b02940acc17d47e0953b
    exit status 1
    Compilation error: 'PORTD' was not declared in this scope
  10. Tricsixty
    LAME
    7Coins
    4DOF
    Disregard my post. I was using a new R4 Arduino which is not compatible with the script.
  11. Michail
    748Coins
    Could You please tell me, what CTC length is and how long in cm the Surge Travel is? Thank you very much.
    By the Way, Pimax has build in motion compensation for long time in Pimax Play. BUT it is very poor, because of the jidder and no filter options. I am using OpenXR MC.
  12. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    614Coins
    Hi, I tried to use OXRMC but I didn't be able to configure it correctly. I tried to use Pimax Play MC but as you say, it is not good. Are you using OXRMC along with other software? FlyPT, SRS, SimHub, DOF reality....
    I'm using Simtools does not implement any option of MC (sadly), I was aFlyPT user when my 2DOF but when I jumped to the 3DOF it becomes unstable and dangerous so I switched to simtools. I even tried Simhub and SRS without getting a good experience in OXRMC so I left it.
    Thank you
  13. Michail
    748Coins
    I am using Simhub, it has FlyPT virtual tracker function.
  14. Josh_Possa
    Catalunya
    614Coins
    Thanks, I'll take a look to see if it is easy to switch from simtools to simhub and adqiure MC function.
  15. Alvaro George Menendez
    81Coins
    I don't have it running atm as we are currently moving house ... but from memory ... The CTC in the trolley system is 66.5cm with a linear surge travel of 210mm+ .... for an exact measure please contact Kevinski in this trail to measure his one as its the original. Kevinski also has just started a new Discord group for builders of his motion simulator. Also his YouTube videos as Dr ADHD are full of useful information
  16. Michail
    748Coins
    I mean the CTC of the motor lever.
  17. Kevinski
    Australia
    115Coins
    @Michail I’ll get that measurement for you after work today. Cheers
    • Friendly Friendly x 2
  18. 204flightsinmotion
    204flightsinmotion Member
    227Coins
    Love this forum. Just got my sabretooth 2x60 and am looking to see if anyone has a diagram on how to wire the resistors to it to prevent backfeed
    154,322Coins
    +11,179 / 57 / -2
    I don't use the Sabertooth but my understanding, as per their official advice, is that you "need to use a battery or at least put a battery in parallel with a DC supply" rather than resistors, with the latter being for 32s: https://www.dimensionengineering.com/products/sabertooth2x60
  20. 204flightsinmotion
    227Coins
    Unfortunately I’m running 24v so a little trickier. Any battery suggestions
