NEMA 23 Stepper Motors
Discussion in 'Electronic and hardware generally' started by Jamie40, Mar 17, 2025.
  1. Jamie40
    Jamie40 New Member
    16Coins
    AC motor
    Hi everyone,
    I know this question comes up from time to time on the forums, but I wanted to ask it again because I have a couple of NEMA 23 stepper motors and the drivers are down. The main factors in making a machine go faster are cutting power (a mix of steppers and milling machines/spindles) and the rigidity of the machine. It seems that when using 76 oz-inch stepper motors, machine speed is limited to around 10-15 mm/sec with a DOC of about 1-3 mm (very material dependent). If you go outside of this, you may lose steps. For a large machine like the LowRider, it would be advantageous to increase the cutting power if the rigidity allows it. I imagine the Dewalt 611 has enough cutting power to reach faster speeds, so the only question left is stepper size.
    I would put a NEMA 23 on the X axis and a dual NEMA 23 on the Y axis. The dual Z axis would remain a NEMA 17 (seems to have more than enough power there).
    Has anyone started retrofitting NEMA 23 stepper motors on a LowRider? I started doing some preliminary design on the board and working on mounting a NEMA 23. I mainly wanted to see what everyone thinks of this and if anyone has looked into it.
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,875Coins
    3DOF, AC motor
    Can you post some photos of your machine? You can do a lot with NEMA23 motors if the software and the drivers perform well. This ugly machine runs at 12m/min with NEMA23 steppers and 10mm pitch ball screws.
  3. samlevy0515
    samlevy0515 New Member
    64Coins
    AC motor
    Sure, I've had good results with the Nema 23 stepper motor from StepperOnline for similar upgrades—might be worth checking out their models for your LowRider.
