Source Code for Atmel USB attack on PS3
Discussion in 'Off Topic - All other stuff here' started by RaceRay, Sep 2, 2010.
  1. RaceRay
    Hamburg, Germany
    23,892Coins
    http://www.heise.de/newsticker/meldung/ ... 70859.html
    With the available Source Code PSgroove and the AT90USB-Microcontroller USB development board it is possible to run uncertified software on the PS3 (firmware 3.41).
    I don´t care about the software PS3-Jailbreak to run game copies, but it could be possible to grab memory data of GT5 ;)
    http://github.com/psgroove/psgroove
  2. MaxDamage
    MaxDamage New Member
    - 28Coins
    It would be awesome if it was possible to read memory data and send it in UDP packets to X-sender... :)
    Or we can ask to Poliphony to make GT5 sends UDP packets with telemetry data by default via ethernet port...
  3. RaceRay
    Hamburg, Germany
    23,892Coins
    Think you mean sending data to the profiler and use a form of x-sender on the PS3 ;) I hope that it is possible to do it.
    I would give away my PS3 to Sirnoname if he is willing to give it a try ;D
    I asked Sony in the past about a api or similar to obtain access to motion data but no response. Any response had make me wondered :)
  4. Frakk
    Frakk Active Member
    328Coins
    I have a good feeling that X-Sim will be the first solution for a PS3 based simulator. Sooner or later more hackers will have access to it, it is just a matter of time.
    Hopefully Sony will realize this potential and release something for the public. They know if they don't, it will be broken anyways. :D
