Question Help wit NJMotion Compact EVO
Discussion in 'Commercial Simulators and Peripherie' started by deckard, Nov 27, 2025.
  1. deckard
    deckard New Member
    40Coins
    I bought a 2DOF seat mover, NJMotion Compact EVO, few days ago. It was hard at the begining to make it work with Simtolls v3, using a PRO license. Every time I restart the PC, Simtools fails to detect the njmotion.
    The error I get is that Interface could not be started. I have checked all programs/services and no one is taking control of COM3, the one used by the motion. In fact, when using Simhub, I told Simhub to do not scan COM3 port and in UDP Relay (also in Simhub as this feature is now gone in Simtools) I set to forward data to 4123 UDP port
    In 8 days I have played only 2 days, and I still do not the reason for those 2 days to be successful. This is driving me crazy and even thinking about selling the motion for another one
    What can be preventing Simtools to connect with the NJMotion?
    153,890Coins
    +11,154 / 57 / -2
    In your explanation you mention both SimTools and SimHub, are you running both at the same time, as that may be creating a port conflict?
    Being a commercial rig have your sought help from the vendor?
  3. deckard
    deckard New Member
    40Coins
    I uninstalled Simhub and the issue remains, Interface cannot start. I contacted the manufacturer but they are not aware of connecting issues and adviced to contact Simtools
    I have been using it for one full day with no issues, in many games, having even Simhub opened at the same time. Today I restarted my PC and did not get it to connect
  4. deckard
    deckard New Member
    40Coins
    I uninstalled Simtools and installed again. Going through the process of setting it up, I cannot pass it, I do not get the green check
    153,890Coins
    +11,154 / 57 / -2
    While community members here may well try and help, given you have paid for a rig the direct responsibility for support is with the manufacturer.
    As I said my guess is a port conflict, so try rebooting the computer and an alternate USB port. @yobuddy may have further insights.
  6. deckard
    deckard New Member
    40Coins
    I have rebooted several times, changed USB port.... and one time it succeded to connect. I have been playing for a while. Then I have rebooted the PC and since then I have not managed to connect again
    153,890Coins
    +11,154 / 57 / -2
    Temporarily disconnect any other USB peripheral, reboot and see if is stable or not.
  8. deckard
    deckard New Member
    40Coins
    Fingers crossed but I think the solution has been to change one COM3 by COM12 in Device Manager, as there were two COM3
    153,890Coins
    +11,154 / 57 / -2
    That sounds like a port conflict!
