Signal Wire from Pot To Arduino.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Cashmanl, Nov 27, 2025.
  1. Cashmanl
    Cashmanl New Member Gold Contributor
    Industrial Engineer
    Florida
    - 35Coins
    I'm thinking of running 8 wire ethernet out of the control box to the potentiometers. I'd split them out on the rig and run a cable to each of the potentiometers. This will keep the connection at the box to one instead of 3 by using 5 of the 8 wires coming out of the control box and slitting off, one for each potentiometer. So my questions......
    1. Can run the 5v and signal wire in the 1 cable coming out of the box. Or will I have a distorted signal problem from the 5v EMF to the signal wire.
    2. Would the twisted pair mitigate EMF.
    3. Would shielded make it acceptable to do.
  2. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Hi. This is a very technical question. Unfortunately, I can't answer it, but I can only advise you on this type of thing that eliminates interference by installing it on your cables.
  3. Cashmanl
    Industrial Engineer
    Florida
    - 35Coins
    You are right! This dives deep into the electronic engineering field. After doing some online reading, it seems the PWM signal can tolerate noise, but creates noise. And, the 5 VDC is sensitive to noise, but doesn’t create noise.
    If PWM crosses over to the 5v lines it could cause jitter on the wiper output creating unstable readings through analog fluctuation.
    This is not a real diffnitve answer but a good explanation of what could happen. So. I think I'm going with your suggestion as a precautionary measure, CAT 6A S/FPT, shielded pairs and outer.
    Thank you for responding.
  4. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    With pleasure. And thank you for this interesting clarification. Good luck with your research and your race.
