Oasis Drive (Hp Reverb ) and OpenXR or OpenVR MotionCompensation .
Discussion in 'News' started by Flymen, Nov 27, 2025.
  1. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hello everyone!
    @pmvcda
    @SilentChill
    I have HP Reverb G2 headset and recently installed with Oasis Driver.
    My problem is that before updating (Windows 24H2), everything worked fine with SteamVR, but my computer hadn't been updated for a year.
    So I waited until the Oasis Driver came out the spring... and now Oasis driver works very well, but it's not compatible with OpenXR ( the image is not stable) or OpenVR Motion Compensation. I have no communication with it, and the three-colored crosshair doesn't move to center itself with my chair (FlyPT Mover).
    I'm looking for solutions... Am I the only one?
    Solutions:
    1 - Change headsets $$$$
    2 - Revert to a previous version of Windows... no way
    Thanks !
  2. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Hi.
    Just like you, I'm stuck with an HP G2 sink because of the Windows update. I switched to the Quest 3 to avoid the hassle, but I really liked my G2. Good luck.
  3. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    I also have the hp reverb g2.... updated pc from win10 to win11 24h2 mid sept after oasis driver release and have had no problems with any of it.
  4. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I also installed Oasis and it works, which is great because it's the nicest headset to wear: light and comfortable. However, I can't connect the controllers.
  5. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    The controller are bluetooth now !
    https://steamcommunity.com/app/3824490
  6. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Oasis work very well !! the problem is the Motion with 3 axe , ( sway , Surge and Heave ) others are ok !!
  7. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hi! Thanks so much for this link! Nice!
  8. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
  9. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    @Wagnard
    @pmvcda
    @SilentChill
    Good news for HP reverb with Oasis drive !
    Mr. Wagnard, from Canada (Quebec), shop.wagnardsoft.com, has released a new version OpenVR-MotionCompensation with this fix.
    Merci !!!hug:
    For now, you must only use the controller as your reference tracker, because after some testing, FlyPT Mover tracker (with the red and blue cross) doesn't seem to work.
    You must disable your antivirus software to download the link.
    https://www.wagnardsoft.com/OpenVR-MotionCompensation_0_3_8.exe
  10. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hey Flymen, thanks for the link and for following up on Oasis. You're awesome!:thumbs
  11. pmvcda
    15,702Coins
    Are you using the new (3.7) or the old Mover?
  12. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Very good question.
    I installed Oasis about ten days ago, so I imagine it's the latest version. I'll check it out tomorrow.
  13. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,293Coins
  14. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hello Pedro !!
    Yes , old version 3.5.3 .
    @Wagnard
    But Wagnard doesn't use the PTMover (output Motion) version that I liked (with the red and blue cross). Maybe you can check with him and I could confirm if it works like it did before (during COVID time) ;) .
    Everything works perfectly as before (moving crosses and filters) with a new up date . It's just missing a little something for communication, which unfortunately isn't my area of expertise.:(
    I don't know what Mr. Mathieu Bucchianeri did to bring the old HP Reverb......but is back from the dustbin, with they're more powerful, with no skipping and higher FPS.:thumbs
    {779A5C76-CF40-49D6-B6D1-7198B403CFFE}.png {D04CA8BB-0CE3-4F8F-BB7B-DDB01A2BFEFC}.png
  15. Wagnard
    Wagnardsoft
    5,293Coins
    I didn't toutch the code related to the PTMover tracker.
    Try again with the latest update I did. I know that the srs one worked, someone tested that with latest version.
  16. Wagnard
    Wagnardsoft
    5,293Coins
    I tried the OVRMC with PTMover today with the virtual tracker (red/blue/green cross) and it work.
    So it must be something on @Flymen side.
    Tested with Mover 3.5.3
