IRacing No Motion
Discussion in 'iRacing' started by xFFBx Tearier, Dec 6, 2025.
  1. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    232Coins
    have been usung the iracing plugin for weeks now. But today when i log on and try and load up iracing in the sim rig, i get no motion. When i click "test motion" everything works as it should. But once in game, i get nothing.
    I have tried a full restart, redownloading the pluggin, and messing with the Min/Max settings.
    I am at a loss, and just want to play iracing... can anyone help?
  2. xFFBx Tearier
    232Coins
    Also, I am able to get motion in other games. its currently just iracing that i cant
    153,716Coins
    Has there been an iRacing update?
    Which version of SimTools are you using?
  4. xFFBx Tearier
    232Coins
    no update that I know of. and v3 for simtools.
    I have narrowed the problem down to a program called "trading paints" used to see, and equip custom paint jobs.
    when trading paints is active, i am not able to get any movement. once turned off, all movement comes back.
    anyone else have any issue like this? or may know a fix?
    153,716Coins
    My guess is the additional program creates a port conflict, as 2 programs can't use the same port at the same time.
    The only way around that is if you can port forward between them, does "trading paints" have that functionality?
  6. dryas123
    dryas123 New Member
    - 130Coins
    It's not a port conflict but a conflict on access the shared memory to read out the motion data from the sim. For whatever reason it works when you start trading paints after you have activated simtools.
    Best,
    Ben
  7. xFFBx Tearier
    232Coins
    This is the fix.
