Question Motors Shut Off, Too Weak? (2DOF)
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by XinnKoda, Dec 15, 2025.
  1. XinnKoda
    XinnKoda New Member
    18Coins
    Hey all! I've been building a motion sim based off of this design in the following video...
    Before I get into my problem here are my specs...
    Arduino UNO R3
    2x IBT_2 Controllers (cooled with PC fan in enclosure)
    24V 40A PSU with 20A fuses going to each motor (tuned down to 20V)
    4 inch CTC Lever (from shaft to bolt)
    25 inch from Seat U-Joint to Motors
    Scooter Motor 24 Volt 250 Watt MY1016Z2 (Unknown what gear reduction it has.... here's the link to the motors on Amazon) https://a.co/d/63paYUm
    Cheap 10k Pots
    My motors shut off as soon as I put any kind of weight onto my rig. I tested a few things out and I think that the IBT2s are overheating and shutting off. It will hold it's own weight for a long time and only pulls 0.5 Amps each motor to hold it's weight. I apply a little bit of weight to it and it starts pulling more amps (I measured 7 at one point) and then it shuts off quickly. I took my temp gun to it and say it as high as 109 degrees Fahrenheit but I think it's very possibly it got hotter than this and that was the temp I could catch. I verified that the IBT2s are receiving 20V power from the PSU but they are not sending it out to the motors. I do have active cooling on the IBT2s with a PC fan blowing over the heat syncs.
    I think the problem is with my motors, they are pretty easy to spin by hand and they are definitely not worm gear. I think this overworks the motor controllers because they do a lot of "jitters" just to keep them on a neutral plane. I'm wondering if these motors just don't have enough holding power and it puts them in a mechanical disadvantage. I did read on these forums though that others have used these motors with success. I know making the CTC level smaller could also help my case but I already only have 7 degrees of pitch at max throw so I'd like to avoid that. The Sine Test I've attached shows the motor shutting off, and that's because the POT went outside the normal bounds, that's a separate issue I'm dealing with and understand that's a problem.
    At this point, I'm willing to upgrade the motors to something better fitted for this design I'm trying to mirror. I'm really lost though on what motors I should get, I see a lot of info about what gear reduction I should get, or if it needs to be worm drive, etc. I thought all worm drive was inherently self-holding but then people say they still spin them by hand? Anyway, any direction would be greatly appreciated!
    153,914Coins
    +11,154 / 57 / -2
    First, congrats on putting your rig together, you did a great job :thumbs
    It would be helpful to know the full specs and ratio of the motors, but the included link seems to be to a different unit.
    Some observations, first was the rig properly balanced with all peripherals attached and you in it, as that is critically important to reduce the load on the motors: https://xsimulator.net/community/faq/find-the-center-of-gravity-to-balance-a-motion-simulator.55/
    SMC3 settings look like refinement is needed, as the Sine test is noisy and poor. At a guess try setting Fpwm to 25, bump Kp to 400, set PWMmin=0, PWMmax=200 and PWMrev=120 and post the results running the Sine test.
    In terms of physics the effective torque utilisation of levers falls off dramatically over about 38 degrees up and down, yours look to be way over that, putting additional strain on the motors.
    Be aware that many members have reported quality issues with IBT2s, even with brand new ones, running them at reduced voltage like you report to be doing is reported to help a bit. While you mention active cooling it was not evident in the video and there may be damage.
    Drilling another hole in the lever closer to the motor shaft will increase the torque available, which is likely worth a shot, in conjunction with the other suggestions here.
  3. XinnKoda
    XinnKoda New Member
    18Coins
    Thank you! I should have researched motors a bit more before purchasing these. They are wheelchair motor model MY1016Z2. After much research I think I've figured out the specs for the motors. The motors themselves have a 9.78:1 ratio and I believe the torque is (from a couple different sources) only around 6nM. Clearly, these motors are the wrong application, even for a seat mover, let alone full frame mover. I've been messing around with SimCalc and trying to figure out what motor I will need. I believe I've input the correct measurements and I changed the CTC lever to be closer to what you recommended. My question is this... when I hit calculate, how do I actually take those calculations and apply them to what motor I need? I see the "Pitch Torque" shows around 16nM and "Roll Torque" shows around 5nM. So does this mean I need to find a motor that has at least that, and probably more? Such as a 20nM motor? Any help would be much appreciated! Also, how does one calculate the weight of myself and the frame of my rig into SimCalc? Thanks!
    153,914Coins
    +11,154 / 57 / -2
    Tools like SimCalc and Motion Visualizer are indicative, rather than definitive guides to the challenges of design Vs physics: https://xsimulator.net/community/faq/motion-visualizer.389/
    A properly balanced 2DOF rig presumes the affect of peripherals and user mass are negligible, of course reality is a whole other ball game, with many variables to consider: https://xsimulator.net/community/faq/find-the-center-of-gravity-to-balance-a-motion-simulator.55/
    Most members tend to go for hardware that is either overkill for the known parameters, or at least in the ballpark where motor placement and lever CTC distance can be adjusted.
  5. XinnKoda
    XinnKoda New Member
    18Coins
    Thanks for your help this far! My plan right now is to go with the PGSAW motors with the 50:1 and mate them with the hall effect sensors. Seems like this would be an appropriate amount of torque while providing enough linear speed (from what I've read)!
