Question Adding a linear actuator to 2DOF with classic motors
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Miszor, Dec 13, 2025.
  1. Miszor
    Miszor New Member
    100Coins
    I'd like to ask if it's possible to add a linear actuator to an existing 2DOF project with 250W, 75 rpm motors (from a wheelchair) to simulate traction loss.
    Basically, I'm looking to combine two different types of devices in Simtools.
    If so, which axis plugin should I use in Simtools? Maybe the generic 2D standard (which is what I'm currently using) and add the actuator as a third axis?
  2. Joe Cortexian
    1,537Coins
    I just use the same SimTools settings. Since a ball screw might rotate 50 times that’s the key. So the SMC3 software has to scale the SimTools input so that 512 SimTools units is 50 turns. There may be another solution but that part was easy to do.
    I ran into two difficult problems. Finding a multi turn encoder solution for SMC3 and dealing with ibt-2 issues when the motor is running at 5000RPM. Due to these issues I changed to AC servos and that is working with my own custom software. There are several SMC3 like AC servos projects you can grab here and use.
    The software problem was supporting a multi turn encoder in SMC3. I was already using Hall effect sensors in PWM mode. There isn’t time to use these in I2C mode and the wrap in analog mode is problematic. The wrap doesn’t go from 1023 to 0. It goes from a high random number above 980 to a low random number less than 50.
    The ibt-2 problem is a hardware issue. Maybe a better driver or maybe a better motor. It was either back EMF or a power spike. The motor would stall even when it was not under load in the SMCUtils “Motion” test. Either way it didn’t seem like a good solution to future linear actuator projects.
