DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. Alex410
    Alex410 New Member
    22Coins
    @Radje748 It seems to be written in many places that the main thing is power, if so that would mean they are equal.
    At the same time, I think that the higher the voltage, the lower the current, and thus the less the heating... but this reasoning might be flawed. Aren't all hoverboard motors for at least 42V? I bought a motor separately, and I don't know what voltage it's for. Although I've just looked at it more carefully, it says 36V, that's strange.
    So it turns out I bought a 48V power supply for nothing...
  2. Radje748
    Radje748 Member
    275Coins
    Just try it... what I mentioned, I have a 24v power supply running on 20v. So in your case...48v Power supply with a 56v board and a 36v motor... I would say... try it on 30-35V and test it.... Assuming that you have an adjustable power supply...
    The DD-Wheel is very...very strong...you will never use it on 100%... or your name must be popeye ;)
    I am running it on 40% and it is already very strong....
  3. maxcodl
    maxcodl New Member
    47Coins
    hi i had a doubt
    why did you get the 56v version? will it work with a 24v powersupply?
    gemini said that i should buy the 56v version of the board instead of the 24v to be safe because it thinks that higher voltage means the board wont get fried or shorted out during some crazy event
