Question Motor just continually souns
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by 68Jay, Dec 28, 2025.
  1. 68Jay
    68Jay New Member
    - 10Coins
    IMG_3474.jpeg IMG_3473.jpeg Just built a new 2dof and have had issues getting the motors to work.. working with Arduino Uno and 2-IBtT-2 drivers.. with Wheelchair motors 24v..I have replaced the drivers as I was getting no movement at all.. replaced the drivers and now just spins.. have followed the instructions with putting everything at “0” then 255 on clip and limits but still spins.. any help would be greatly appreciated!
    153,716Coins
    Keep in mind that other members have advised as to IBT2 quality control issues, even with brand new units.
    That said, at what point of the SMC3 setup do you encounter issues: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Initial Setup
    Strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    Disconnect the motor power supply
    Make sure Simtools is not running – we’re not ready for that yet!
    Wire up the Arduino (with SMC3 installed) to your H-Bridges and connect to your computer via USB
    Run the Windows SMC3 Utility software and make sure it communicates with the Arduino (There is no need to set baud rates, they are not configurable)
    Set the Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 for ALL motors (This will make sure the motors don’t move)
    Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    Turn on the power to your motors – nothing should move at this stage!
    Set Kp to about 400
    Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
    If it is then that motor and feedback is wired correctly - proceed to test other motors.
    If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning.
    Do the above for each motor
  3. 68Jay
    68Jay New Member
    - 10Coins
    As soon as I power up the motors after setting everything to “0”
    153,716Coins
  5. 68Jay
    68Jay New Member
    - 10Coins
    yes mode2 was entered
    153,716Coins
    Have you tested the IBT2s?
    As an aside the pots do not appear to be centered in the SMC3 picture.
  7. 68Jay
    68Jay New Member
    - 10Coins
    I have centered them multiple times.. but turning on motors they go back out of whack
    153,716Coins
    What specifically have you been doing?
    If you disconnect wiring/power to the motors when they are in what should be their middle position, open SMC3, disconnect the pot to the motor then rotate the pot shaft by hand, its green line should move and be positioned in the middle of the SMC3 graph. You can then carefully reconnect the pot to the motor while mainlining its central position. You then reconnect power to the motors.
    If that does not work there is something very wrong and more detailed testing of your hardware and wiring is required.
  9. 68Jay
    68Jay New Member
    - 10Coins
    Aa
    that is what I have been doing.. I have just those Aduino connectors could that have an issue?.. should I be soldering?
  10. Joe Cortexian
    1,537Coins
    Is the direction correct?
    I would disconnect the pots and set them at zero. If the motor moves at all when you power it up the motor is wired wrong. The motor should not move but when you move the pot the motor should move until you move the pot back. More that it should move the right direction.
