Question ODESC V4.2 + Hoverboard Motor - Voltage Question
Discussion in 'Direct Drive Wheels' started by maxcodl, Dec 18, 2025.
  1. maxcodl
    maxcodl New Member
    47Coins
    hi im Max
    so basically i’m starting my journey to build a DIY Direct Drive wheel using a hoverboard motor and an ODESC V4.2 board. I’ve been researching the setup, but I have a doubt regarding the board voltage versions
    I was advised to go with the 56V version of the ODESC instead of the 24V one to be "safe and future-proof," with the idea being that a higher voltage rating prevents the board from frying during high-torque peaks or "crazy events."
    so my question is
    1. Is it true that the 56V board is safer for a 24V system, or does it not matter?
    2. Im planning to buy a 24V 20Amp power supply ready will the 56V board handle this fine?
    3. Does the higher voltage rating on the board help with back-EMF (electricity sent back by the motor) during fast steering?
    Well i already ordered the 54v version but was having second thoughts
  2. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    I have the 56v version and it works perfectly, I have no problems. I'll send you a link to a channel that shows you how to assemble and configure it.
  3. maxcodl
    maxcodl New Member
    47Coins
    oh thats great, thank you
    i got the main boards and everything
    now im looking for the correct wheel for the base
  4. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    I'll show you my steering wheel. In my case, I have a separate circuit board for the pedals and steering wheel buttons. I designed a 3D printed case just to cover the electronics.
    If you have a 3D printer and are interested, let me know and I'll send you the STL file so you can modify it to your liking.
    upload_2026-1-6_14-11-40.jpeg upload_2026-1-6_14-12-20.jpeg upload_2026-1-6_14-12-20.jpeg upload_2026-1-6_14-12-20.jpeg
  5. maxcodl
    maxcodl New Member
    47Coins
    oh damn, that looks really good. do you have any game play video uploaded on some social media? i would like to see
    how much torque are you getting out of it?
    and yes i do have a printer and i was thinking of making an enclosure that looks like moza r5 ;p
    i still havent the right motor for my build and everything i saw is just 2kg so less torque according to ffbeast
  6. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    Hey bro, I haven't actually made a video of it working, but I use it at 30% power and that's enough. A 10-lap race leaves you completely exhausted, so it's probably just a matter of getting used to it. The first time I tested it, I used 50% and it was really tiring; I was practically kicking the kerbs like crazy.
    It's piqued my curiosity to see how much power it can deliver. I'll do a test and make a video this weekend and send it to you.
    I'll share the info with you anyway.
  7. maxcodl
    maxcodl New Member
    47Coins
    oh damn... that's crazy
    so maybe I don't need a powerful motor too I guess? whats the weight of your motor btw, if it's 3kg then it can deliver around 15NM and the only ones i found was 1.8kg which has around 5 or 6NM if i remember correctly. i still haven't found any that's above 2kg
    I'm looking forward to seeing your soon
  8. maxcodl
    maxcodl New Member
    47Coins
    hey man, were you able to record the video and test the power?
  9. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    Hi maxcodl, sorry for the delay, but work has been intense. I'm sending you the STL file for my hoverboard steering wheel design. I'm also sending you another design I'm working on that might interest you; it's the Moza R21 design. It's a nice design, and I'm going to adapt it to the hoverboard motor.
    Hope this helps!
  10. maxcodl
    maxcodl New Member
    47Coins
    damn thanks a lot
    my main parts for the wheel has arrived in my city now I need to buy the wheel motor and psu
    I'm looking in every options I can find
