VR base stations loose track with motion rig on. EM interference problems?
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by TheTakerPL, Jan 11, 2026.
  1. TheTakerPL
    TheTakerPL Member
    198Coins
    I'm experiencing weird problem with Pimax Crystal Light with Lighthouse faceplate and HTC base stations. It looses tracking constantly when rig is turned on.
    How it behaves: When rig turned off I can do everything with my headset, lift it to peek to the screen, take it off, put to the side, tracking is very good.
    With rig turned on it works mostly when I don't make large head movements, when I touch it with my hand to lift it slightly and peek to the screen tracking jumps suddenly somewhere and screens go black, until I put it again and stay still. WTF?!
    I've done everything mentioned in this guide:
    https://luisblando.medium.com/how-i-solved-the-emi-problem-in-my-simrig-3ea6c0907609
    Grounded everything, installed expensive EMI filter, installed ferrite rings everywhere, installed expensive Brennenstuhl brand power strips with RFI/EMI filters, NOTHING HELPED!!
    After a year of work and thousands of dollars spent I'm loosing my mind.
    Left station is connected to the same outlet as rig power supply. Right station is at the PC outlet. Both outlets go from the same line, same ground from same circuit breaker.
    My rig: 6DOF hoverboard actuators with 3x ODrives
    https://www.xsimulator.net/community/threads/wip-6dof-on-hoverboard-motors-and-sfu-gearboxes.19564/
    My power supply for rig 48V 1500W switching power supply form Aliexpress:
    EMI filter:
    What else I can do?
    (Pimax inside out tracking is out of question - it's useless crap)
    153,884Coins
    +11,154 / 57 / -2
    Have you tried a solid window curtain?
    I say that because while EMF can be an issue, so too can any sort of reflective surface.
    It is an easy test, just temporarily hang some solid material like a towel.
  3. TheTakerPL
    TheTakerPL Member
    198Coins
    Covered, and nothing changed
    153,884Coins
    +11,154 / 57 / -2
    The pretty much confirmed EMF or occlusion.
    Loss of tracking when using your hand to adjust the HMD is likely sensitive occlusion.
    Have you tried the base stations on the shelf just in front of the rig.
  5. TheTakerPL
    TheTakerPL Member
    198Coins
    I found a reddit thread with exact same issue.
    https://www.reddit.com/r/Fanatec/s/bE0vcbgzjZ
    He posted a link to proper type ferrite cores that solved his problem. I ordered a few from Conrad to wrap the VR cable the same way. Hope this will work.
  6. TheTakerPL
    TheTakerPL Member
    198Coins
    In a stroke of genius I came out with a simple method to verify which part of the system gets interference.
    Is it HMD lighthouse faceplate that fails to look for base stations,
    or
    is it base stations getting EMI from power supply through the outlet?
    just run them from a 12V battery...
    And it... works,
    and there's no interference...
    stable tracking...
    no disconnection...
    no greying out screens...
    I can touch HMD now, nothing changes.
    I guess I'll just buy larger 12V batteries for them or look for better 12V power supplies for them.
  7. TheTakerPL
    TheTakerPL Member
    198Coins
    [UPDATE]
    I was celebrating too early, and didn't check with rig's 3 USB cables plugged in PC. There was still interference with all 3 plugged, but today I got large proper material (type 31) ferrite cores.
    I made this with VR cable near the end and so far EMI is gone
    My friend said that he will nominate me for a Nobel Prize when I solve this :D
  8. TheTakerPL
    TheTakerPL Member
    198Coins
    [UPDATE]
    VR cable looped 8 times around 4 large ferrite cores.
    But the best results were when I shielded all power cables and rig's 3 USB cables with aluminium tape, and grounded them to single point. No interference at all, no noise in throttle/trim knob signals. I can touch VR headset, nothing happens.
