N-Labs Simulator - Brasil
Discussion in 'DIY Motion Simulator Projects' started by Nailson Roveta, Jan 13, 2026.
  1. Nailson Roveta
    Nailson Roveta Nailson
    Retiree
    Serra, Espírito Santo, Brazil
    57Coins
    This topic was created to document/show the development of a simulator.
  2. Nailson Roveta
    Retiree
    57Coins
    Assembling the stand for the 3 monitors.
  3. Nailson Roveta
    Retiree
    57Coins
    Seatbelt actuation. I made a bracket to attach to the seat itself and I'm using SIMTOOLS to move them. It turned out very well. Later I'll upload some videos to YouTube and post the link here.
    153,830Coins
    +11,151 / 57 / -2
    What are the motors you are using?
  5. Nailson Roveta
    Retiree
    57Coins
    For the seatbelt mechanism, I use two automotive power window motors. They aren't as powerful as windshield wiper motors, but they're strong enough to operate the seatbelts.
    I used an Arduino and two BTS7960 43A H-bridges. I configured the Sway and Surge motion. This way I have control of the individual belts; in a curve, for example, one motor tightens and the other loosens. During braking, both tighten, and during acceleration, both loosen.
  6. Nailson Roveta
    Retiree
    57Coins
    This video gives you an idea of how the seatbelt mechanism works and the intensity of the wind depending on the car's speed. Sorry the audio is in Portuguese. Best regards.
  7. Nailson Roveta
    Retiree
    57Coins
    Hi everyone!
    As someone who cares about maintenance, now that everything is working, I decided to do things right. I started organizing everything on a suitable panel so that everything is tidy. I'm going to eliminate those individual pins connected to the Arduino board that have a high chance of bad contact, I ordered some shields, and I'm going to use a terminator for the wires. I also modeled and printed the supports for the bridges and the Arduino. In addition, I ordered some temperature sensors (less than $2 on Aliexpress), even though I don't have a problem with temperature, I want to monitor it. I'm even going to configure the fans to only turn on if they reach a certain temperature, to reduce noise when it's not necessary. I'm assembling everything without touching the cockpit, so it will continue to operate while I make these improvements. As I progress, I will post updates. Have a great weekend.
