Question Need some help for my 2dof setup
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by qqqwewqe123, Jan 16, 2026.
Tags:
  1. qqqwewqe123
    qqqwewqe123 New Member
    50Coins
    Hello everyone, I am trying to build a 2DOF system, but I have encountered some problems and I don’t know what to do.
    The components I am using are a 24V 50 RPM protected windshield wiper motor with the following specifications:
    • Operating Voltage: 24V DC
    • Power: 245W
    • Speed: 50 RPM
    • Current: <40A Max
    • Torque: 28 N·m
    I am using an Arduino Uno, an IBT-2 motor driver, and a 0–360 degree analog rotary Hall sensor as the position sensor (VCC = 5V, Vout = 0–5V).
    As a power supply, I have one with input: 200–240 VAC, 8A, 50/60 Hz and output: 24V DC, 33.3A, Po = 800W.
    For software, I am using SMC3, and for now I am testing through SMC3 Utils.
    The problems I am experiencing are:
    1. I don’t know how I should mechanically connect the motor shaft to the sensor shaft. What kind of coupling or gear mechanism should I use, and what gear ratio should it have? I really have no idea about this part.
    2. Another problem is that in SMC3 Utils, when I slightly move the right-hand slider upward, the motor starts rotating endlessly. Eventually, it reaches the sensor limit within the 0–5V range and then stops itself. I couldn’t find a solution to this infinite rotation issue.
      In the videos I watched, when they move the right slider, the motor only rotates a small amount, but in my case it keeps trying to rotate endlessly.
    I also have no idea what values I should set in SMC3 Utils.
    Please help me, I am having a lot of trouble and I can’t figure out the cause.
    153,884Coins
    +11,154 / 57 / -2
    While a 180 degree Hall sensor would have given a slightly better resolution a 360 will work fine and can be direct mounted/driven and will not break if over rotated, see the FAQs for some ideas: https://xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
    Most wiper motors require ground isolation: https://xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    If you are running IBT2s at 24v please be aware that other members have reported quality control issues, recommending dropping the voltage a little.
    Please post pictures of your SMC3 setting and explain at what step in the setup you experienced issues: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    8. Set Kp to about 400
  3. qqqwewqe123
    50Coins
    First of all, thank you very much for your answers, I will definitely try them.
    How much should the size difference be between the motor gear and the sensor gear? Should they be the same size?
    During the initial setup, I center my sensor exactly in SMC3 Utils and then start the system. The green center line moves toward the upper and lower red lines, and when it touches those upper or lower lines, the motor shuts itself off.
    What is the up-and-down adjustable area on the right side of the monitoring screen in SMC3 Utils?
    In a video I watched, they were able to move the motor as they wanted and with small angles by moving this right-hand control back and forth.
    153,884Coins
    +11,154 / 57 / -2
  5. qqqwewqe123
    50Coins
    When I try to move the motor in SMC3 Utils, even a small position command makes the motor spin continuously in one direction until the sensor hits its limits. I think as the motor rotates, the 360° Hall sensor output also keeps increasing, so the feedback never catches up with the target and the controller continues to drive the motor endlessly. I'll send a screenshot in a few hours. Thanks in advance for your replies.
  6. Joe Cortexian
    1,537Coins
    Is your direction correct? This is a symptom of the motor going in the wrong direction looking for a set point.
  7. qqqwewqe123
    50Coins
    These are the values I entered, but when I try it in SimTolls LFS, the motor doesn't move. What could be the reason?
  8. qqqwewqe123
    50Coins
    I can currently move the motor a little, but it doesn't register every right or left turn; it only detects sharp turns.
  9. qqqwewqe123
    50Coins
    These are the results I get when I feed in sine wave.
  10. Joe Cortexian
    1,537Coins
    That’s exactly the way it should look. I can’t imagine how the motor isn’t running right. Maybe something with the sensor? Could it somehow be the sensor is in a mode lit number of bits of something? I guessed something fixed running in one direction? How did you fix that?
  11. qqqwewqe123
    50Coins
    I haven't actually done anything much, but I don't know if it's due to the values in sm3utils, but when I enter LFS and do a few test drives, I notice that there's a noise coming from inside the engine, but the engine doesn't move. What could be causing this?
  12. Joe Cortexian
    1,537Coins
    If it rattles that’s kinda normal. If it more of a whine it means the motor is trying to move but doesn’t have enough power. I see you have max speed at 200 so that should be enough. Make some max speed adjustments.
  13. noorbeast
    153,884Coins
    +11,154 / 57 / -2
  14. qqqwewqe123
    50Coins
    I haven't encountered any problems with smc3Utils, only when I increase the ki and kd values does my motor start to vibrate. I have no idea how low I should lower the input limits. In my sine wave test (as shown above), and when I tested the interface for simtools, my motor moved smoothly, but in-game, there's a buzzing sound coming from inside the motor. When there's no buzzing, the motor moves, but the roll movement isn't 100% accurate. Normally, I expect it to turn in the direction I turn the steering wheel, but I've observed that it doesn't turn with every turn. Could this problem be due to the values I've given in sm3Utils?
    153,884Coins
    +11,154 / 57 / -2
    You can think of it this way, SMC3 sets the control parameters for your hardware and you tune it to have the best controlled responses.
    SimTools allocates and mixes the game telemetry, making use of the tuned hardware, and a SimTools motion profile is refined to create the desire motion, it is not there to control the setup of that hardware.
    A buzzing/whining sound tends to be hardware, SMC3 frequency control settings, and/or interference.
  16. Joe Cortexian
    1,537Coins
    In the standard SMC3 software ki and I’d don’t work correctly. There is an updated sebastian2 version which fixes this. Noorbeast knows where it is exactly.
    I do not worry about the grinding. Mine grinds sometimes of if I a, it racing and it’s grinding I estop to make it stop because the noise is annoying.
    As for your other problems that’s likely SimTools setup.
