Too much movement.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Bagof.stupid, Jan 22, 2026.
  1. Bagof.stupid
    Bagof.stupid New Member
    57Coins
    Hello everyone. I’m just starting to test and set up my 2dof sim setup. I’m using some 24v wheel chair motors. I’m just wondering how to make my setup less violent. It’ll go up and down so hard. It’ll jump off the floor or if you spin a car out it’ll just about Chuck you out of the seat. How do I tone it down a little i’ve been playing with the settings, but nothing really seems to help tone it down. Does anybody perhaps have some settings for Gt7 that I could try?
    cheers.
    153,758Coins
    Can you please post pictures of all your settings.
  3. Bagof.stupid
    57Coins
    I will when I’m back home. I’ve got it mostly sorted now. Had to turn the setting in sim tools down a lot and it’s good now. Would like to be able to turn down the shift surge also so need to figure that out.
    153,758Coins
    Using higher values in the Tuning Center should soften the shifts, you just have to experiment to dial into whatever you prefer. Different Max/Min settings has a significant effect, see the the FAQs here: https://xsimulator.net/community/faq/snappy-gear-change-motion.121/
  5. Silas
    Silas New Member
    46Coins
    DC motor, 6DOF
    Your motors are probably too strong for the default settings. Try lowering overall gain and reducing acceleration/jerk limits, and add some smoothing. For GT7, start with lower force feedback and increase gradually.
