Amicos 3DOF from 3DPrinter Parts
Discussion in 'DIY Motion Simulator Projects' started by Jon Amico, Jan 26, 2026.
  1. Jon Amico
    Jon Amico Member Gold Contributor
    195Coins
    Or inspired by 3D Printers anyway.. (Click Bait) I had 2 old printers that were doing nothing and I figured I would use as many of the parts as possible.. Then started accumulation of parts moths ago..
    I used most the V Channed Extrusion Rail for the bottom frame
    The 8 pin Wire arrays and the 2 electrical housing boxes, and 1 of the power cords...
    [​IMG] [​IMG]
    Salvaging some parts from 2 of these..
  2. Jon Amico
    195Coins
    The V Channel rail Rail Beginnings and Embed test 2.. I had to buy 2 4 packs of longer 1200mm V channel Extrusion rail..
  3. Jon Amico
    195Coins
    Made the roller wheel mounts with tabs from International Metal Supply.. Was going to do 3 in the back but settled for 4..
  4. Jon Amico
    195Coins
    Using 2 600watt Power Supplies,
    2 Arduino Unos (1 for the Motion and the other for Wind, Pedals Shakers)
    1 Arduino Mini for a LED flag Matrix)
    1 5 Amp 24V power Supply
    2 100 Amp Dual Channel Motor Controllers
    3 24v 120RPM Wheel Chair Motors
    Emergency Cut off
    Simsonn Pedals
    Fanatec DD2 QR2 with Multiple Wheels
    Load Cell Hand Brake
    Fanatec Shifter (POS) might get a new
    V Channel Extrusion Rail for the Bottom Base and the Middle Traction Loss Section
    T Channel Extrusion Rail for the cockpit
    Then tons of hardware to keep all the aluminum extrusion Rail stiff... Hopefully!
    2 Dayton Bass Shakers with a 2 channel usb Reciever.
    I have a 4th mini usb monitor running a dash from SimHub as well.. I had the monitor form a past raspberry pi project so it ended up on the OG rig and now onto the new..
  5. Jon Amico
    195Coins
    Here is my current rig.. Eventually Bass shakers and pedal shakes are not enough... I need More!!
    I Did find a lighter seat.. I hope the DD2 isnt too heavy for it.. Weighs 22lbs on its own...
  6. Jon Amico
    195Coins
    My existing Monitor stand has to go as well... It wont work with the motion rig so went with this stand that I will modify to attach to my bottom base somehow..
  7. Jon Amico
    195Coins
    I had some issues with the 100 Amp Dual Cannel Motor Controllers. I had to go back to Mode 1 in the SMC3 and Swith one of the motors positive/negative because it was a fix to a Continuously spinning motor...
    Here is a link to that thread
    https://www.xsimulator.net/community/threads/100-amp-motor-driver-wiring-help-3dof.19819/
    The motors did not work with the normal wiring for some reason but AI said that it only happens with some of the 100 Amp Chinese motor controllers so that might not be necessary for everyone..
  8. Jon Amico
    195Coins
    Getting deepinto the wiring.. Alot more.work than I originally anticipated... Lots of wires and soldering..
  9. Jon Amico
    195Coins
    The tear down of my first rig has started.. It was hard to pull the plug on this one. Im already jonesing for a race.. Im not looking forward to the down time and trying to get as much done today as possible.
    Time to get everything mounted on the cockpit to find my center.. Had to make a few brackets so parts connect to the Extrusion Rail with easy removeability..
  10. Jon Amico
    195Coins
    Final wiring Happening as well..
  11. Jon Amico
    195Coins
    With the Traction loss section and Tilt Motors.. Still have to figure out Motor mount arm Positions...
  12. Jon Amico
    195Coins
    The Cockpit is together and ready for mounting on the Traction Loss..
  13. Jon Amico
    195Coins
    I got it up on frame with some help and found somw issues.. The Peadals mount is a too wide and needed modifications.. And I need to move the pivot point up one inch and the center mount 2.5 inches..
  14. Jon Amico
    195Coins
    Buttons and E Cut off all installed and ready to plug in..
    My Apartment is a mess but getting closer... So much for Compact build... The new monitor mount is huge and maybe over kill... I feel I need bigger monitors now.... lol
    Bottom is all wired Up.. I just have to 3d print a box for the button array board and a new Hall sensor mount as I broke one of them.. Keep thinking Im close till Im not.. Hoping to plug it all in this weekend.
  15. Jon Amico
    195Coins
    Damnit... The 3 monitor stand says "Up to 32 inch curved and 34 inch flat screens".. It didnt give a min but it sucks for 27"....
  16. Jon Amico
    195Coins
    I did cut the pedals mount plate down to make room for the movement motors and I think I can keep them where I mounted them. I added support at the foot end to help with motor arm placement and adjustability.. A few more Extrusion Rails to cut for that... Happy I bought extra.. [​IMG]
    And wires are still adding up.... [​IMG]
  17. Jon Amico
    195Coins
    I should rename this thread to "Way Too Big For My Apartment 3DOF"
  18. Jon Amico
    195Coins
    New Name.. "I Broke the Bank DIY 3 DOF Build"..
    This thing is now getting expensive.. All the damn Hardware... And Extrusion Rail... Adds up quick.. After more corners brackets and some more rail, I now know where the arms will attach..
  19. Jon Amico
    195Coins
    Its almost time to plug it all in and pray to the Sim Gods that SimTools set up goes smoothly..
    I feel I might have problems with my motor mount arms as they don't have woodruff keys.. Or the slots for them...
    Ill bet this will be my next issue.. I was hoping I could lock washer and impact them to the shaft?!
  20. Jon Amico
    195Coins
    Up on 3.25 inch blocks that will hopefully be the park position. Seat height will about 22 23 inches high.. I couldnt stand the monitors being so small on the 3 monitor mount.. I ordered 32" G5s..
    New thread name... " I Definitely Broke the Bank DIY 3 DOF Build"..
