Potentiometer reversing
Discussion in 'Electronic and hardware generally' started by Bagof.stupid, Jan 31, 2026.
  1. Bagof.stupid
    Bagof.stupid New Member
    57Coins
    Hello everyone.
    A friend of mine gave me some hall effect potentiometers that are 360 rotation.I was planning on using a 2:1 gear reduction to get full resolution, what I’ve noticed is they can’t be reversed by switching the power and ground. Is there a way to reverse one in the software or does it need to be reversed mechanically.?
    Cheers,
    153,830Coins
    +11,151 / 57 / -2
    The polarity of motors can be changed, which is likely your issue, and additionally the direction can be independently set in SimTools by how the DIR boxes are checked in Axis Assignments.
  3. Bagof.stupid
    57Coins
    Thanks for your reply. So does it matter in smc3 if the line for the pot goes down on the graph even if the motor travels up? I can just switch directions in Sim tools, then?
    Cheers.
    153,830Coins
    +11,151 / 57 / -2
    You could do that, but if you reverse the wires on the motors I would expect the direction in SMC3 would be correct, and that makes SimTools setup easier in terms of existing information/guidance.
    But if you want to leave it as it is you can set the Axis Assignment direction as you want in SimTools using the DIR check-boxes, which can determine which way each axis moves.
  5. Bagof.stupid
    57Coins
    Ok the only reason I ask is because these potentiometers are ccw rotation is up but i have my rig set up for cw is up using traditional pots,I was hopeing not to have to re Design, my brackets as space is tight. But if there’s no issues with me running it upside down or inverted then that will be the route I take.
    Cheers.
    153,830Coins
    +11,151 / 57 / -2
    It can be made to work, whatever path you choose, as ultimately SimTools can set, on the software side, which way an axis moves, via the DIR settings.
  7. Bagof.stupid
    57Coins
    Ok perfect, thanks for clearing that up for me. much appreciated
    cheers
  8. Gadget999
    12,132Coins
    you could read the value of the pot and double it in the smc3 code to recalibrate the pot !
  9. Bagof.stupid
    57Coins
    I’m using a 2:1 ratio to get full pot resolution it was the direction I was concerned about as these pots can only be wired one way. Can’t just flip the power and ground.
    Cheers
