FlyPT Mover 3.7.0.21
  1. Fors
    Fors New Member
    53Coins
    Please check the acceleration/deceleration in different directions on the ground.
  2. Fors
    Fors New Member
    53Coins
    screenshot 1 (longitudinal acceleration) heading 114 in value (3.314)
    screenshot 2 (longitudinal acceleration) heading 289 in value (-2.836)
    Why did the values become negative?
    screenshot 3 (longitudinal acc with gravity) heading 111 in value (6.920)
    screenshot 4 (longitudinal acc with gravity) heading 293 in value (-3.350)
    The same. Why do the acceleration values become negative when I turn the plane 180 degrees? 1.png 2.png 3.png 4.png
  3. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,858Coins
    DC motor, 6DOF
    Definitely a bug.
    Variables acc-x acc-y acc-z (had gravity as well as cor-correction included)
    @pmvcda they should be picked by Mover under “accel. with gravity” unaltered without any math. “y” seems to be vertical.
  4. J-1775
    J-1775 Aviator
    1,618Coins
    This would be great! Especially if the War Thunder Source Module does not work with Aces of Thunder (which finally should be released in a couple of days, on February 3rd). Actually I hope telemetry support goes beyond the rudimentary data of WT!
    Gaijin finally abandoned the 'free to play' model, so just holler if you want us to buy you a copy! ;)
    EDIT: Can now confirm that the WT Source Module can be used for AoT (Aces of Thunder), too.
    Hey @pmvcda Pedro, is that another of your magic? Reading in the telemetry slots dynamically?
    After migrating my old WT profile to Mover 3.7.0.17 I see alot more data than before! For pitch, roll and yaw we now have not only speed, but also acceleration! Still missing are longitudinal and lateral acceleration and ─ most unfortunately ─ all Z-axis (Heave) data.
    Of the values shown in WT source module all but the ones for flap and gear turbulence seem to be filled with realtime data!
  5. JCM
    JCM New Member
    113Coins
    Hi folks
    Any one has any idea how I could control this kind of rig within FlyPT ?
    There are only 3 linear actuators mounted on a revolute joint (bearing)
  6. Flymen
    Montreal, Canada
    2,479Coins
    DC motor, 6DOF
    Hi @pmvcda, do you have any news? thanks ( see next post here )
  7. Flymen
    Montreal, Canada
    2,479Coins
    DC motor, 6DOF
    thanks !
  8. DEMONx
    DEMONx New Member
    93Coins
    3DOF, Motion platform
    I can't save "Use scale" option in Actuators settings. By stock there 0.500 but for my 3DOF need at least 1.000. I did save settings but this parameter after restart move back to 0.500.
  9. DEMONx
    DEMONx New Member
    93Coins
    I found in Source WitMotion WT901C. I have this device, can I use for motion compensation? Someone can help me for explain how connect and use that?
  10. evgenymcp
    evgenymcp Member
    179Coins
    I ran LFS on my 2DOF platform today. It seems to be working. However, I need to understand the settings. Is there a general setting to reduce sensitivity like in SIMTOOLS? When I make sudden changes in direction, my platform jumps off the ground.
  11. J-1775
    J-1775 Aviator
    1,618Coins
    Usually a Lowpass filter should do the job. you can start with a value of 300 and decreas or increase as necessary. Add more filters in the chain, as needed. A very big factor is whether you work with position or acceleration input.
  12. J-1775
    J-1775 Aviator
    1,618Coins
    Quick question: Anyone using the DCS source module in 3.7?
    It won't connect and receive data with me. Anything changed since 2.6? The .lua in the zip looks the same as ever.
  13. DEMONx
    DEMONx New Member
    93Coins
    I'm using dcs with last version of FlyPT
  14. J-1775
    J-1775 Aviator
    1,618Coins
    Thanks DemonX for your feedback. That is version 3.7.0.17?
    I really don't check it. I use the same (default) port 4124 as for v 2.6, which works fine as before 2.5. But 2.7.0.x does not.
    However I see some differences, 2.7 e.g. now sports the vehicle's name (bottom of values).
    Would you check whether you really use the .lua version that says it's from 27 08 2021 and for FlyPT version 3.5.2?
  15. DEMONx
    DEMONx New Member
    93Coins
    3.7.0.17, Now you don't need to update LUA manually. Just do Patch the game and lua will be updated automatically. For this version all games like that
  16. DEMONx
    DEMONx New Member
    93Coins
    for example
  17. evgenymcp
    evgenymcp Member
    179Coins
    When is the bass shaker planned to be launched in version 3.7?
  18. DEMONx
    DEMONx New Member
    93Coins
    Hhm have a update for 3.7.0.18. What new there? What different from 17
  19. Chris_Beeves
    2,184Coins
    There is some info in GitHub.
  20. DEMONx
    DEMONx New Member
    93Coins
    Release notes for 3.7.0.18 (03-03-2026)
    Many internal optimizations and changes
    UI scale with some things to do yet, also for dark mode
    MIDI is not 100%, but in/out working
    Added some sources and reworked others for better speed
    Corrected bugs in rigs (several)
    Some new filters like WASH/WASHR (go back to zero slow) and EMALPT/EMAHPT (EMA based in time not samples)
    Custom UDP source still WIP
    Many small bugs solved
