Question How to load /preset profiles on a 6DOF platform
Discussion in 'SimTools Pro & Entertainment Version' started by KSN, Feb 5, 2026 at 21:42.
  1. KSN
    KSN New Member
    64Coins
    Hi guys,
    new here and new to simtools V3. I got a 6dof linear platform with a USB AMC NANO interface. So far so good. I'm able to test the rig on each axis but there are no standard axis assigned to the various motion options (pitch, roll etc....) Are there standard profiles out there? AI created some XML files with all presets but NO idea where to put those file or how to import them? Does anyone have some ideas? If I connect it to XP12 the platform is only give a kind of vibration but no corresponding motion outputs.. "
    Any help will be appreciated!
  2. Silas
    Silas New Member
    52Coins
    DC motor, 6DOF
    In SimTools V3 you usually don’t import XML presets, you manually map the 6 actuators in Axis Assignments (Pitch/Roll/Heave/Yaw/Sway/Surge) and verify Interface Settings. If XP12 only vibrates, the plugin is likely fine but your axis mix isn’t set yet, so start with Pitch/Roll/Heave first and build from there.
    153,830Coins
    +11,151 / 57 / -2
