SMC3 Utils & INO file-Need to run 3rd motor @ 25kHz
Discussion in 'Miscellaneous' started by Eli Wizard, Feb 16, 2026.
  1. Eli Wizard
    Eli Wizard New Member
    Ottawa
    40Coins
    Hi All,
    my third motor is exclusively for heave and SMC3 UTIL 'motor3' only gives 4 or 31 kHz as options. Can I simply edit the file to 15 kHz? "Timer2FreqkHz = 15" And have all motors on 15kHz. Failing that my other option is to swap my least motor stressed to 3 as the heave axis is the one most stressed.
    Tks
  2. Gadget999
    12,307Coins
    No, its because of the arduino board
    Uee another board, or 2 arduino uno boards
  3. Eli Wizard
    Ottawa
    40Coins
    Thanks for your reply.
    Could you give an example of "another board" (mega?), and or point me to a guide on using two Arduino?
    Is the second board "Interface B"?
    What is the limitation of the Uno?
  4. Gadget999
    12,307Coins
    just use 2x arduino - simtools can use more than one board at a time
    2 motors on one and 1 on the other
    alternatively look for a comnpatible board with more pwm pins - you may need to make chages to the code
  5. Eli Wizard
    Ottawa
    40Coins
    For now I'll just swap motors around. Motor2(roll) has the least load kp=150 maxpwm=200 compared to the needs of heave kp=380, maxpwm= 200. These are puny Honda wiper motors.
    I'm looking at the Arduino DUE and guess that I'll have to tune using SMC3 then use IDE to write frequencies into the code.
    I know I can use two arduino I'd like to avoid another long USB cable. Would a powered USB hub handle the Wheel and the two Arduino providing individual com ports?
    Thanks for your input.
