Question Traction loss settings?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Joonas Temonen, Feb 11, 2026.
  1. Joonas Temonen
    Joonas Temonen Member
    107Coins
    Can someone help me how To get traction loss to work? My two motors are connected to one arduino Uno, and traction loss motor To another. Arduino Uno.
    How To set up number 2 interface to work?
    154,762Coins
    +11,199 / 57 / -2
  3. Joonas Temonen
    107Coins
    Now i noticed what is the problem! Motor is too weak or lever is too long for traction loss.
    I think the motor has some kind of self shut down etc. When I took the motor off from the rig, it works like it should.
    Tomorrow i will try to shorten the lever and try again.
    I have been thinking and testing the motor with 2 different arduinos and now i think i found the problem!
    Will be back again when i find the solution for my problem.
    154,762Coins
    +11,199 / 57 / -2
    That would certainly do it!
  5. Jon Amico
    Jon Amico Member Gold Contributor
    501Coins
    What Motors are you using? Not that I'll have an awesome answer for you.But curious and we should all know?!
  6. Joonas Temonen
    107Coins
    My motors are 2 wheelchair motors In front and 1pc 350w24v geared motor To traction loss. Im going To change that traction loss motor soon, because its too weak. But that earlier problem (shutting down) was fixed with shortening the lever on motor.
