Amicos 3DOF from 3DPrinter Parts
Discussion in 'DIY Motion Simulator Projects' started by Jon Amico, Jan 26, 2026.
  1. noorbeast
    154,762Coins
    +11,199 / 57 / -2
    Cool creative mod ;)
    Jokes aside, as I also have the DD2 you have got me thinking that I should consider cable strain relief.
  2. Jon Amico
    Jon Amico Member Gold Contributor
    501Coins
    Lol. Yeah. Not sure if its my bad or Fanatec cheap solders or something.. But in Fanatecs defense the wire was rubbing a bit on my old rigs monitors post.. When the FFB was high or a crash thst thing shook... Maybe even more than the new motion rig... It happened a few times before my upgrades but thought I secured it good with Zip ties... I.did do a race tonight with No issues!!
    Back to this... lol My solution..
    https://youtube.com/shorts/o9eaFh-iG7I?si=-CyqIn-tf4gL-uoL
    154,762Coins
    +11,199 / 57 / -2
    Please do detail the parts used, as that is a genuinely creative approach I have not seen before.
  4. Jon Amico
    501Coins
    Its 4 of the 2 inch actuators, 4 Black hinges, a two way switch, wire terminal and wiring.. I cut them from Extrusion Rail and used the rail hardware to mount.. I cut them a little shorter than the powered up Neutral position. With the corner cut off at 45 degrees they can squeeze under the frame.. Felt pads on top..
    Now it ill only drop 1/4 inch or so when powered off.. I had 2 actuators already. Ordered two more to finish the Mod..
    Links to Actuators and Terminal..
    https://a.co/d/0hD7Vi1g
    https://a.co/d/01BetDnH
    3 way 6 pin Toggle
    https://a.co/d/02FdFTi5
    154,762Coins
    +11,199 / 57 / -2
    Added to the FAQs with credit to yourself: https://www.xsimulator.net/community/faq/actuator-chocking-of-back-driven-rigs.417/
  6. Jon Amico
    501Coins
  7. Jon Amico
    501Coins
  8. Jon Amico
    501Coins
    Been Messing around with the Tuning center Settings but not convinced I have them perfect.. Or even close. Manually Entering, Roll + - 23, Pitch + - 19, Heave + - 20, Yaw + - 120, Sway + - 20, Surge + - 25 and Extra 1 (TL) at + - 9
    I was trying to lower the Auto Capture Numbers to hopefully feel a little more in certain areas.. But feel I lost more in others..
    Is it just better to do a Start Capture till all the Fields change and do a save? Then lower Traction Loss by Half?
    Is it better to to a capture on clean laps or running curbs, Bumps and crashing to get Higher Values?
    These are with some crashes but not all fields Filled.. Should Numbers bee in the 100's? Yaw is showing 179 and sway 126... Normal?
    Having Fun Though.
  9. Jon Amico
    501Coins
    AI Suggests...
    1. Reset: Click "Reset" in the Tuning Center.
    2. The Hot Lap: Click "Start Capture." Drive 2 laps of your favorite track/car combo at 100% pace. Clip a few curbs, but do not crash.
    3. Stop & Save: Click "Stop Capture" and then "Save New Settings."
    4. The "20% Rule": Usually, the captured numbers are still a bit "safe." If the motion feels too weak, manually lower the Max/Min numbers by about 20%.
      • Example: If Sway captured at 20, try setting it to 16.
    5. Traction Loss (Extra1): You mentioned halving it—that's a common tactic. If you want TL to be "snappy" so you can catch a slide, it usually needs a lower number than the other forces. If it captured at 10, try 5 or 6.
    4. Addressing your "100s" Question
    Should Numbers be in the 100's? Yaw is showing 179 and sway 126... Normal?
    No. For a standard car in iRacing, Sway and Surge usually land between 10 and 30. Seeing 126 suggests the "Capture" was running while you were spinning out or the game sent a weird telemetry spike. Those high numbers will make your rig feel "dead."
    Its been Wrong on many things so figured I would ask the Pros.. (Noorbeast) lol
  10. Jon Amico
    501Coins
    After 1.5 laps at Nordschleife fast and bumping curbs this is all I got for Min / Max; Roll 17.51, Pitch 9.37, Heave 4.92, Yaw 179.9, Sway 4.66, Surge 3.02, Extra 1 (Traction Loss) 4.81
    All wack..
    154,762Coins
    +11,199 / 57 / -2
    Do be aware that refining a motion profile is part personal preference, part honing settings, and part black magic where all that intersects. Refining profiles takes a good amount of time, but does get easier with practice, knowing your rig better and understanding what all of the settings do.
    Please do review the tuning tips in the FAQs as a starting point: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Make sure you initially do an axis at a time, disabling the others, then combine and refine.
    Can you please check and confirm that sway is set to lean away from a corner and roll is set the opposite of sway. In the video it looks like the rig leans into a corner: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  12. Jon Amico
    501Coins
    Damn.. I do think something was backwards and now I messed it all up.. HAHA! I will have to trouble shoot later as its way too shaky/loud in my apartment at 10:30 PM...
    But inside your link says "Both boxes will be either checked or unchecked for surge and pitch, while only one will be checked for sway and the opposite one will be checked for roll." Mine was not like that... I made it like that but something still might be backwards! Its loud and shaky!!
    The Slider for Sway and roll in output testing do the same thing on the rig even though the Axis assignments are opposite Dir.
    My brain will understand it one of these days.... But off to sleep and a long day of work... Thanks for the links Boss!!!
  13. noorbeast
    154,762Coins
    +11,199 / 57 / -2
    What DIR boxes need to be checked, or not, depends on how your rig is wired by default.
    As per the provided link this is what SimTools expects in terms of axis configuration, but it is no big deal to accommodate alternate configurations, you just need to keep that in mind when adjusting to suit the need to consider other standardised recommendations when making adjustments: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  14. Jon Amico
    501Coins
    The Link helped allot again!! TY I didnt know you had to be in game for the Virtual Axis to work.. I though the sliders were not working!! lol I do think I got it all right now.. Now its time to get all the Levels Right.. Every thing but the Roll (Curbs?!) feels good..
    154,762Coins
    +11,199 / 57 / -2
    As I mentioned sway should be set to lean away from a corner and roll is set the opposite of sway. Tweak them each individually, then combine and refine from there.
    Keep in mind that with a curb it is not just roll involved, you pitch up and then down hitting then rolling off the curb, plus there is a heave effect in there as well over the corrugated curb surface. It does take some tweaking, but that gets easier with practice.
  16. Jon Amico
    501Coins
    It was so difficult to get the feeling right.. The Direction Boxes make no sense to me.. In the end I had to do them all one by one.. I took each force turn it up to 45% in assignments then 7 in the tuning center with the others on 0%...
    Only then could I tell / See what was really happening.. And I had it in my head that if you were turning left the motor should be going down on the left.. But the motion is trying to make you feel gravity. So it's opposite.. duh!
    And because I bought my motors at different places. I think one of them is wired internally wrong. So it's backwards than the other two... I ended up putting that one on the traction loss. But long story short, it is rocking now! Feels really good with no more motion sickness.. i was worried that these motors wouldn't give up enough movement but Its plenty.. Even at ninety percent to not annoy the neighbors works great.. i will post a new video shortly. But I think I got it this time..
    Here is a new video of the parking brake. I added lights and a micro switch because I kept leaving them up when I started racing..
  17. Jon Amico
    501Coins
    Here are the settings I landed on... I'm sure there is room for improvement..
    The Settings Dancer!
  18. Jon Amico
    501Coins
    Sooo Power at the building went out today.. A few hours after it turned back on I started smelling a burning smell... i came over and touched the controller for Motor C, Traction Loss.. It was hot enough to burn my fingers..
    The wires are fried.. Its wierd because nothing ever got hot before. The motors never got more than warm and never noticed any hot wires or smells.
    The motor seems to be siezed as well. It will no longer spin with no power.
    Is this a thing with these motors? When they fail they seize?
    But as of now it seems I need a new Controller and a new Motor?! What happened? Things were fine before a sudden power outage..
    Note- I was on the sim when the power went out but not racing. I didnt turn any switches off.. Maybe this was bad?! I have maybe 7 or 8 solid hours with motion and no issues or smells...
  19. Jon Amico
    501Coins
    After closer daylight inspection its seems the motor got super hot ad spit out grease or something out of the screw hole.. It smells of burning.. it also melted the 3D printed sensor mount enough for the belt to slip off.
    I guess next time I remember to cut all power to the rig before the power goes back on next time?! But Ill have to order another motor and controller!
    Im wondering why this tractionloss motor? Its not always under load as the other two. And its the dual controller with only one motor. The power supply for this one also has the lighter load.. Only 1 motor for a 600w power supply..
    Any Ideas how I can avoid this from happening again?
  20. Jon Amico
    501Coins
    Damn!! Burnt to hell on the inside... this was the odd ball motor that had to be wired backwards.. wondering if that had something to do with it... i've never felt this motor even slightly warm. Even after long thirty minute races..
