FlyPT Mover 3.7.0.24
  1. Chris_Beeves
    2,196Coins
    Actuator behaviour on 4Dof Linear is not changed in this version?
    Yaw and roll still moves all the actuators. Roll should only move the fronts and yaw only the rears, right?
  2. pmvcda
    15,944Coins
    Sorry for not posting here.
    Been really busy with Mover. Some updates coming in the next weeks.
    This release was posted to allow some users helping me to deep test some features. Still BETA!
    3.7.0.18 has some problems! In linear hexapods, please disconnect FK:
    This is WIP to get forward kinematics.
    If you want to you can test it. Check the box and in a pose change it.
    You can compare requested pose with pose calculated with FK (bottom = FK pose)
    This is going to bring some interesting features soon. Calculation seems fast enough, but still with some errors.
    Some other features in deep work are the MIDI controls. This is now bidirectional and I will post info on the next release when i will get it bug free. Any checkbox, button or numeric control can be adjusted using it, a joystick or a keyboard key. For earlier tests, try to right click in one of those controls:
    Some hardware using it:
  3. evgenymcp
    evgenymcp Member
    186Coins
    Please help me or share a working config for a 2DOF rotation platform. I have set up a Mover with SMC3. I have defined the geometry of my platform. Everything is fine. However, when I run a game, the platform behaves in an inappropriate manner. The movements are too abrupt and have a large amplitude. I want to achieve a smoother motion. SIMTOOLS provides a general sensitivity slider.
  4. pmvcda
    15,944Coins
    Share the setup you made please. I will take a look.
    For bass shaker I have some WIP with many changes. Not ready yet.
  5. pmvcda
    15,944Coins
    DCS Lua is new for Mover 3.7
    Like it was said, use the patch function to generate the new LUA file.
    Adding vehicle names allows you to make setups for different planes and save them as default for those planes (you need the game running witht the plane to save them)
    With this Mover can auto load the setup when the plane is detected.
    Should work for all games and when we have vehicle name, for all vehicles also
  6. pmvcda
    15,944Coins
    Mover 3.7.0.19
    Updates in Midi, optimizations and cleanup.
    Keys in MIDI had to be changed!
  7. evgenymcp
    evgenymcp Member
    186Coins
    I'm currently watching a video on how to set up a 6DOF hexapod. Similarly, I've set up Pose from suspension and applied the filters as shown in the video. The suspension works as expected. However, the other movements are too abrupt. I believe I need to apply filters to other sources. I'd appreciate a detailed guide on how to set up a 2DOF platform with rotation axes for DIRT, Asseta Corsa, or BeamNG car simulators, along with examples.
  8. evgenymcp
    evgenymcp Member
    186Coins
    I have now applied the following settings. Acceleration and braking work fine. Climbing and descending work fine. However, driving over bumps, potholes, and humps is too jerky. My head tries to detach when I drive over a small bump.
      67.5 KB
      61
    • Old Old x 1
  9. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,870Coins
    DC motor, 6DOF
    Put one, or two EmaLP (smoothing) on every single input. Vertical accel. as well. No wonder it sends you to the moon if you leave the signal unfiltered.
  10. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,369Coins
    Just wondering if Elite dangerous is now seeking pointers online ?
    cause it does not seems to work currently.
  11. Tean33
    Tean33 Member
    255Coins
    I've been using Mover 3.5 for a few years now and it has served me well, but I thought it was time to get with the program and have a go at re-creating my setups and hopefully improving them in 3.7. Maybe I might even be able to give some useful feedback.
    One problem I find is that in 3.5 I made extensive use of the pose "from noise generated by value" to create things like stall buffeting in planes and translational lift in helicopters. This type of pose is not apparently available in 3.7, so what is the suggested workflow for creating conditional shaking effects?
    Thanks in advance.
  12. Chris_Beeves
    2,196Coins
    Do you have any plans to correct the 4Dof linear? Or is it me doing something wrong in the setup/misunderstanding?
  13. J-1775
    J-1775 Aviator
    1,624Coins
    The 'Save as' function is actually a 'Save as copy' ─ the name of the current profile does NOT change.
    This is a bit tricky. When later making a 'save' the old profile is overwritten, not the one I believe to be the latest one. Unfortunately I'm not sure when I noticed that the first time.
  14. hexpod
    berlin
    7,870Coins
    DC motor, 6DOF
    I guess another feature (more advanced and flexible) will be available in filters (loop with incorporated noise) for this functionality.
    Currently we have a bug inside but let’s hope for a quick fix in the next update.
  15. Tean33
    Tean33 Member
    255Coins
    Thanks for the input @hexpod
    I've tried the Loop & Noise source but I can't see any way to control this with telemetry from the sim. I see that Loop is available as a filter but it seems a bit flaky and I can't get it to work. Is this the bug you refer to? Noise does seem to work as a filter so I guess I can use that for now.
    The Loop filter does look like it could be pretty cool if it can be made to work. I can imagine some interesting effects with it.
  16. pmvcda
    15,944Coins
    Sorry, been busy. I will correct
  17. hexpod
    berlin
    7,870Coins
    DC motor, 6DOF
    If you wanna play with it right away you have to downgrade to 3.7.0.17 or wait for the next one. If we’re lucky it will get a fix.
  18. Tean33
    Tean33 Member
    255Coins
    Just had a play with the loop filter in version 17. Looks really useful. Thanks @hexpod
  19. pmvcda
    15,944Coins
    Just solved the bug in LOOP.
    It was caused because I wanted to allow the use of operations/filters to select the type of loop (same in IF)
    Now both are working and it will be on the next release
    This is useful since it allows you to assing a hardware control to change those values (or any other value)
  20. Tean33
    Tean33 Member
    255Coins
    Thanks @pmvcda That's brilliant.
    And a more general thank you for all your effort in creating this software. I hope I've already said that somewhere in the past, but if I haven't then I'd like to correct that now.
