What kind of printer do you use?
Discussion in '3D Printing' started by bruce stephen, Feb 12, 2016.
  1. Misanthrop
    Misanthrop Active Member
    1,018Coins
    Depends completely for what you want to use it. But very soon you will reach it´s print volume when you want to print something like an Buttonbox, Dash or similar things.
  2. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    715Coins
    My ancient printer is 6" x 9" x 6" (so something like 150mm x 225mm x 150mm) and it's worked fine for me for most things. I only printed stuff like bearing mounts and gears for encoders though. I don't have the patience for prints that take hours and hours anyway, so stuff like big boxes are easier for me to make out of metal.
  3. samlevy0515
    samlevy0515 New Member
    88Coins
    AC motor
    Honestly, if you're not printing crazy fast or super tall, ditching the Z stepper from the rail is more of a "because I can" mod than a game-changer—your stock remote bowden MK8 is likely still the real bottleneck
    ______________
    Planetary Gearbox Solutions – Built stronger. Run smoother. Last longer.
