FlyPT Mover 3.7.0.24
  1. Andrey Av
    Andrey Av New Member
    75Coins
    Thanks @pmvcda for your work, the mover is becoming better with each update.
    I noticed another issue when started using motion compensation. I set up the motion compensation output, connected it and see that values in the Out column are being updated and looking well.
    But it does not update the memory file (and does not write bytes in the Send line). It only starts doing that if I trigger Type of value to Float and then back to Double - then the MMF Reader and OpenXR MC layer start to get that information properly (and I see bytes in the Send line).
  2. evgenymcp
    evgenymcp Member
    186Coins
    I have achieved good performance of my 2DOF platform in DIRT 2.0, and I used the EMALP filter on the advice of the forum users. This has made the platform run smoothly. I have also tried running other games, such as BeamNG and Aseeto Corsa Rally. I will need to adjust the settings for these games. Thank you to the developer, FlyPT Mover. I am looking forward to the addition of Bass Shaker support. Thank you!
      67.2 KB
      54
  3. DEMONx
    DEMONx New Member
    159Coins
    3DOF, Motion platform
    Where need to put planes name and what proper name for autostart profile?
  4. DEMONx
    DEMONx New Member
    159Coins
    I found the plane name in flypt. thanks
  5. DEMONx
    DEMONx New Member
    159Coins
  6. pmvcda
    15,950Coins
    Mover 3.7.0.20
    Release notes:
    Solved a bug in EMAHPT and EMALPT when the filter time was 0 (no filter).
    Small changes in the INTERPOLATION filter to enhance results (also affects the sources interpolation).
    Corrected a bug when saving graphics. The color change was not detected correctly, causing large files because it was storing all the items.
    Reworked source recording, now synchronization with video is better. Data is saved at high frequency, and video is saved at vsync frequency.
    When recording with video, always use vsync in the games, or you will get poor quality video. Also, disable HDR,
    Windows still causes a big mess with HDR recording.
    Reworked the Player source (still some problems with Phyphox files)
    Solved some bugs in the LOOP filter/operation.
    You can now use operations/filters to define the type of wave.
    The drop-down with the type of wave shows when you select NUMBER (the type of wave depends on value).
    You can now use operations/filters to define the type of IF.
    The drop-down with the type of IF shows when you select NUMBER (the condition depends on value).
    MIDI variables selected in the filters/operations now store the value, allowing MIDI devices with in/out to get the value of the setup.
    Using hotkeys defined in the numeric controls of filters is disabled. There is no way to work around it. Use REMAP(VARIABLE;FROM1;TO1;FROM2;TO2).
    Updated the transducers module to the latest internals and UI . Missing predefinitions and input slider. No module for wheels yet.
    4DOF rig still with bugs
  7. pmvcda
    15,950Coins
    Save the setup as default for Source/Game
    You need to be running the game and have the vehicle selected (showing in Mover)
    A save window shows where you select the source to use, if you want to assign the vehicle to the setup and enable auto load:
    The setup shows on the left of the main window.
    When the game and the vehicle are detected, the setup loads automatically
    That's the idea. Might have some bug...
  8. pmvcda
    15,950Coins
    Bass shaker was added, basic one for now.
  9. pmvcda
    15,950Coins
    Still testing this one. Might be solved on the next release.
  10. Flymen
    Montreal, Canada
    2,491Coins
    DC motor, 6DOF
    Hello ,
    Do you have some news ?
  11. DEMONx
    DEMONx New Member
    159Coins
    One more problem, source can't star the game
  12. Flymen
    Montreal, Canada
    2,491Coins
    DC motor, 6DOF
    Check this .... When you put -800 in (Pitch center of rotation)/ Surge , like a AirPlaine F-18 . The pitch result direction go up ( 7.093) and Heave too ( 98.785) but Surge stay at zero !!!! You must change Sway result for Surge . The others center seem ok !!! {F506A8D4-B087-4FF8-A434-F18242462774}.png
  13. Flymen
    Montreal, Canada
    2,491Coins
    DC motor, 6DOF
  14. pmvcda
    15,950Coins
    Just made some tests and seems they are wrong, most of them... I'm taking a look
  15. pmvcda
    15,950Coins
    I see. I think i might know the problem. Let me check
  16. Erik Green
    Erik Green Member
    475Coins
    Periodically get this error when loading .mover file. Not seen it in last 24hrs. All is working perfectly. Perhaps some of you smart people can determine what the issue might be.
    System.Net.Sockets.SocketException (10048): Only one usage of each socket address (protocol/network address/port) is normally permitted.
    at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
    at Mover.Utils.UdpSourceFast.Start()
    at Mover.Sources.Car_games_and_sims.LFS_UDP.Connect()
    at Mover.UI.SOURCE.TryToConnectDisconnect()
    at Mover.UI.SOURCE.UpdateInterface()
    at Mover.Main.Main.UpdateInterface(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, UInt32 msg, WPARAM wparam, LPARAM lparam)
    System.Private.CoreLib
    Assembly Version: 10.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Private.CoreLib.dll
    Mover
    Assembly Version: 3.7.0.20
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\Mover.dll
    System.Runtime
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Windows.Forms.dll
    System.ComponentModel.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.ComponentModel.Primitives.dll
    System.Windows.Forms.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Windows.Forms.Primitives.dll
    System.Private.Windows.Core
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Private.Windows.Core.dll
    System.Private.Windows.GdiPlus
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Private.Windows.GdiPlus.dll
    System.Drawing.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Drawing.Primitives.dll
    System.Collections.Specialized
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Collections.Specialized.dll
    System.Diagnostics.Process
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.Process.dll
    System.Runtime.InteropServices
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.InteropServices.dll
    System.Threading
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Threading.dll
    System.Collections
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Collections.dll
    System.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Linq.dll
    System.Drawing.Common
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Drawing.Common.dll
    System.ComponentModel.EventBasedAsync
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.ComponentModel.EventBasedAsync.dll
    System.Xml.XDocument
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Xml.XDocument.dll
    System.Private.Xml.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Private.Xml.Linq.dll
    System.Private.Xml
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Private.Xml.dll
    System.Memory
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Memory.dll
    Microsoft.Win32.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\Microsoft.Win32.Primitives.dll
    System.Threading.Thread
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Threading.Thread.dll
    System.Collections.Concurrent
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Collections.Concurrent.dll
    Accessibility
    Assembly Version: 4.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\Accessibility.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.ComponentModel.dll
    System.Numerics.Vectors
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Numerics.Vectors.dll
    Microsoft.Win32.SystemEvents
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\Microsoft.Win32.SystemEvents.dll
    System.ComponentModel.TypeConverter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.ComponentModel.TypeConverter.dll
    System.Net.Http
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.Http.dll
    System.Net.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.Primitives.dll
    System.Diagnostics.Tracing
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.Tracing.dll
    System.Diagnostics.DiagnosticSource
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.DiagnosticSource.dll
    System.Net.Security
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.Security.dll
    System.Security.Cryptography
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Security.Cryptography.dll
    System.Resources.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Resources.Extensions.dll
    System.Drawing
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Drawing.dll
    Microsoft.Win32.Registry
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\Microsoft.Win32.Registry.dll
    Microsoft.Windows.SDK.NET
    Assembly Version: 10.0.26100.38
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\Microsoft.Windows.SDK.NET.dll
    System.Collections.NonGeneric
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Collections.NonGeneric.dll
    System.Diagnostics.FileVersionInfo
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.FileVersionInfo.dll
    System.Security.Principal.Windows
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Security.Principal.Windows.dll
    System.Security.Claims
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Security.Claims.dll
    WinRT.Runtime
    Assembly Version: 2.2.0.0
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\WinRT.Runtime.dll
    System.Private.Uri
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Private.Uri.dll
    System.ObjectModel
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.ObjectModel.dll
    System.Linq.Expressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Linq.Expressions.dll
    System.Management
    Assembly Version: 11.0.0.0
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\System.Management.dll
    AxInterop.WMPLib
    Assembly Version: 1.0.0.0
    Interop.WMPLib
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\Interop.WMPLib.dll
    mscorlib
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\mscorlib.dll
    Interop.WMPLib
    MathNet.Numerics
    Assembly Version: 6.0.0.0
    System.Runtime.Numerics
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.Numerics.dll
    Mover
    System.DoubleNumerics
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\System.DoubleNumerics.dll
    System.IO.Ports
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\System.IO.Ports.dll
    Mythosia
    Assembly Version: 1.2.0.0
    netstandard
    Assembly Version: 2.1.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\netstandard.dll
    Mythosia.Integrity
    NWaves
    Assembly Version: 0.9.6.0
    System.CodeDom
    System.IO.Ports
    System.Management
    WinRT.Runtime
    System.Configuration.ConfigurationManager
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Configuration.ConfigurationManager.dll
    WindowsFormsIntegration
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\WindowsFormsIntegration.dll
    PresentationFramework
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\PresentationFramework.dll
    PresentationCore
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\PresentationCore.dll
    WindowsBase
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\WindowsBase.dll
    System.Xaml
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Xaml.dll
    System.Net.HttpListener
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.HttpListener.dll
    System.Text.RegularExpressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Text.RegularExpressions.dll
    System.Resources.Writer
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Resources.Writer.dll
    System.Runtime.Serialization.Formatters
    Assembly Version: 8.1.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.Serialization.Formatters.dll
    System.Reflection.Metadata
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Reflection.Metadata.dll
    System.Collections.Immutable
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Collections.Immutable.dll
    System.Formats.Nrbf
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Formats.Nrbf.dll
    System.Reflection.Emit.ILGeneration
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Reflection.Emit.ILGeneration.dll
    System.Formats.Asn1
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Formats.Asn1.dll
    System.Security.AccessControl
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Security.AccessControl.dll
    System.Reflection.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Reflection.Primitives.dll
    System.Xml.ReaderWriter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Xml.ReaderWriter.dll
    UIAutomationProvider
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\UIAutomationProvider.dll
    UIAutomationTypes
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\UIAutomationTypes.dll
    System.IO.Packaging
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.IO.Packaging.dll
    System.Diagnostics.TraceSource
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.TraceSource.dll
    ReachFramework
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\ReachFramework.dll
    DirectWriteForwarder
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\DirectWriteForwarder.dll
    System.Net.Requests
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.Requests.dll
    System.Net.WebHeaderCollection
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.WebHeaderCollection.dll
    System.Security.Cryptography.Xml
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Security.Cryptography.Xml.dll
    System.Windows.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\10.0.1\System.Windows.Primitives.dll
    System.IO.IsolatedStorage
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.IO.IsolatedStorage.dll
    System.Net.WebSockets
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.WebSockets.dll
    System.Runtime.Loader
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.Loader.dll
    System.Text.Json
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Text.Json.dll
    System.Text.Encoding.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Text.Encoding.Extensions.dll
    System.Threading.ThreadPool
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Threading.ThreadPool.dll
    System.Net.Sockets
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.Sockets.dll
    System.Threading.Overlapped
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Threading.Overlapped.dll
    System.Net.NameResolution
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.NameResolution.dll
    System.Runtime.Intrinsics
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.Intrinsics.dll
    System.Text.Encodings.Web
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Text.Encodings.Web.dll
    System.Reflection.Emit.Lightweight
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Reflection.Emit.Lightweight.dll
    ScreenRecorderLib
    Assembly Version: 1.0.9460.42248
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\ScreenRecorderLib.dll
    System.Runtime.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.Extensions.dll
    System.Diagnostics.Debug
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.Debug.dll
    System.Runtime.CompilerServices.VisualC
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Runtime.CompilerServices.VisualC.dll
    System.Net.WebClient
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Net.WebClient.dll
    NWaves
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\NWaves.dll
    Mythosia.Integrity
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\Mythosia.Integrity.dll
    Mythosia
    Location: C:\Users\erik5\AppData\Local\Temp\.net\M3720\osm2RYukOgP7\Mythosia.dll
    System.IO.MemoryMappedFiles
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.IO.MemoryMappedFiles.dll
    System.Diagnostics.StackTrace
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\10.0.1\System.Diagnostics.StackTrace.dll
  17. J-1775
    J-1775 Aviator
    1,624Coins
    One thing you may not be aware of, @pmvcda , but which is a bit irritating:
    In my localized Win11 the 'Saved Games' folder is named 'Gespeicherte Spiele'. Until recently I had the .lua there (in the //Hooks folder) ─ together with all custom missions, liveries, tech folder etc. etc. However when I have the .lua exported from the source module you create a new 'Saved Games' folder (with subfolders).
    I currently have .lua copies in both folder structures, but as already said, it's irritating. Also I often encounter a disconnection of the source module, especially when I pause DCS (luckily not with 'active pause') or leave the flight/mission. Sometimes I can reconnect (Alt+S), but more often not. However I suspect this might be a problem of DCS?
  18. mhsimmer
    mhsimmer New Member
    24Coins
    Hi pmvcda,
    Amazing work on FLyPT Mover. I am a new user and getting to grips with it.
    I am testing my setup with 3.7.0.20 and have come across an issue with Live for Speed.
    I notice in the sources there are two identical LFS entries both of which are UDP fast.
    Does it matter which I use?
    When I tried either I get no data from the game; is this something you have seen before?
    I checked with Wireshark and can see the data packets UDP on 4123 and 4124 but don't get data updating in the source window of FLyPT Mover (with either of the two LFS sources both with 4123 and 4124 matching ports in FlyPT).
    Any idea what is wrong? or stopping comms between the applications (all on the same machine)?
    Many thanks in advance.
    I tried Asseto Corsa using MMF and that works fine.
    Cheers,
    Rog
  19. pmvcda
    15,950Coins
    The LFS sources are the same, I will remove one on the next build.
    I have it working on my side.
    Did you apply the patch? To do so, click on the button with the pen.
    If not working, did you allow it on the firewall?
    When you run Mover the first time, windows asks permission to do it.
    Also, you can only access the data from one software, not from two. For that you need to forward the data to another port and read it on that port.
  20. pmvcda
    15,950Coins
    Might be on Mover... I wiil test. I will also look at a better place to put the lua file (that works)
