FlyPT Mover 3.7.0.23
  1. evgenymcp
    evgenymcp Member
    186Coins
    I would like to express my gratitude to the developer. Today, I tested the Bass shaker in the Mover, and it works. I adjusted it to the engine speed and the road surface.
  2. JCM
    JCM New Member
    125Coins
    Hello @pmvcda
    I know you may have plenty on your plate...I am trying to control a very simple rig on Fly PT using only 3 actuators
    You surely already know it, its a "3 RPS"
    The first joint is revolute -passive
    The second joint is prismatic -active
    The last joint is spherical -passive
    Its very similar to Rotating 3DOF (3RRS) which already exists in FlyPT.
    I was wondering if you had any idea how I could set up this type of rig in your software ?
    Maybe some trigonometric transformation on the Rotating 3DOF rig type could do the trick?
    Any idea for even a quick & dirty solution, this would really help.
    Thank you for your kind help as always,
    Sincerely
  3. pmvcda
    15,932Coins
    I will add it for the next release. It's an easy one i think.
    Meanwhile you could try to add with 3 actuators but i think it's not going to work because you cant limit the motion of the bottom joint.
    But without yaw sway and surge it might work.
    Now you can use two poses on the actuator, one for the rod and one for the housing, use pose just in the rod
  4. JCM
    JCM New Member
    125Coins
    Awesome!!! I will try this hack in the meantime
    Looking forward to your release so I can configure it properly (enter base radius, platform radius, actuators stroke and other parameters)
    Thank you man, you are a legend ! :thumbs
  5. mhsimmer
    mhsimmer New Member
    24Coins
    Thanks for your replies. I am still banging my head against the wall and can't get LFS to link up with Mover.
    I have opened all UDP ports in the firewall and even tried temporarily disabling it; still no luck.
    Thanks for the tip about the patching of LFS I had not done this. I try and it still doesn't work.
    How does Mover know where to patch files? I ask as I had installed LFS more than once and just wondered if a path is wrong somewhere. I also notice that even without LFS installed the patching seems to be allowed even though no LFS files are there, what does patching do and how do I know it has worked?
    Can I ask what version of LFS you are using? I am on 0.7G and mover 3.7.0.21.
    Any help is very welcome. I have my actuator moving with Mover and the noise/loop source so know it works.
    Thanks in advance.
  6. mhsimmer
    mhsimmer New Member
    24Coins
    Also in addition to the message above. I notice in your screenshots when using LFS the Connect/Disconnect button is red. My one is always yellow. What does this mean?
  7. DEMONx
    DEMONx New Member
    159Coins
    3DOF, Motion platform
    Why Flypt mover project doesn't have a Discord?
  8. pmvcda
    15,932Coins
    I have it prepared, but never started because i had no time for it.
    What sections would you like to have in that discord?
  9. pmvcda
    15,932Coins
    When we receive data, a transition is performed and the button becomes red (yellow to orange to red)
    If you are not receiving data but are listening on the port, it's yellow
  10. pmvcda
    15,932Coins
    There where some problems when detecting the install folder. I added some log to the next release to track the errors.
    Mover looks at the UninstallDisplayName to get the install folder. If you have more than one instalation it uses the first found.
    In Live for Speed the UninstallDisplayName is "LFS"
    You can check your location by using the Windows PowerShell
    Type: Get-StartApps | where name -like 'LFS'
    Usually in LFS, we need to edit the cfg.txt file that lies in the instalation folder.
    NOTE: Run LFS at least one time before patching (LFS creates the cfg.txt file when you run it for the first time)
    Open it in the notepad and search for OutSim or OutGauge:
    In that section you need to edit the data to match the above text in blue:
    Code:
    OutSim Mode 2
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 4123
    OutSim ID 0
    OutSim Opts 1ff
    OutGauge Mode 2
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 4124
    OutGauge ID 0
    Now start LFS and it should work unless you have something blocking the port or another software getting the data from that port.
    What I wrote above is what Mover does when patching.
  11. DEMONx
    DEMONx New Member
    159Coins
    1. news (where can wright only you), info about new beta version, any fix, updates.
    2. separate secrions for 2dof, 3dof and other platform. Users can talk about platforms, designe, how to make it and etc.
    3. Issue, if some one have a problem with Flypt.
    for start I think that's enough. If need later can make new section.
  12. mhsimmer
    mhsimmer New Member
    24Coins
    Hi Pmvcda,
    Thank you so much for your time on this.
    You have fixed it for me - the issue was the OutSim Opts not being set to 1ff, it was set to 0. All the other settings I had correct and could see data in wireshark on the correct ports.
    After setting the OutSim Opts to 1ff everything is working as expected.
    Cheers!! Happy simming!
  13. J-1775
    J-1775 Aviator
    1,624Coins
    • Q & A (restricted to Pedro)
    • roadmap (restricted to Pedro)
    • A differentiation between flight sim, racing sims and other sims might be useful as they have their own specific issues (e.g. 'ground' & 'air' in flightsims).
    • a thread for motion compensation
    • a thread for filters ─ in fact a seperate thread for EACH filter could be useful. You pin the description and after that users may talk about their experience, problems and use cases.
    • issues and problems (as already suggested)
    • suggestions
    • a section/thread for hardware discussions
    • general discussion of mation platform solutions and theories
    Random thoughts ─ and I'm not sure about the hierarchy of all that. I think some thinking and planning ahead of creating the channel may be worth the effort.
  14. DEMONx
    DEMONx New Member
    159Coins
    I have one interest problem with Dirt Rally 2.0. I'm playing sim games in VR only. When start game from FlyPT, game start without vr but Motion platform working. When start game from Pimax Play or Steam, starting in VR but no Telemetry in FlyPT. I havr two options vr or motion platform((
  15. pmvcda
    15,932Coins
    The problem is in the patch, we have to patch the VR separated from the normal one and i missed it, sorry.
    Dirt Rally 2 generates one cfg for vr and one for normal.
    Go to the folder “...Documents\My Games\DiRT Rally 2.0\hardwaresettings”.
    Edit the file: “hardware_settings_config.xml” ) go to this section that should be patched like this:
    Code:
        <motion_platform>
            <dbox enabled="true" />
            <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
            <custom_udp enabled="true" filename="MoverCustomUDP.xml" ip="127.0.0.1" port="20777" delay="0" />
            <udp enabled="true" extradata="3" ip="127.0.0.1" port="29373" delay="1" />
        </motion_platform>
    copy the line (the patch):
    paste that line in the “hardware_settings_config_vr.xml” file to replace the line:
    <custom_udp enabled="false" filename="packet_data.xml" ip="127.0.0.1" port="20777" delay="1" />
    If you are using a port different from 20777, change it in the lines
    For example if you have a patch line of another software, you can add a new one but with different port
    Note: When Mover patches it also adds a motionplatforms folder in the parent folder of that location with the MoverCustomUDP.xml file
  16. DEMONx
    DEMONx New Member
    159Coins
    Thank you, now all working!
  17. DEMONx
    DEMONx New Member
    159Coins
    oops sorry. There UDP, for LMU and RFactor 2
  18. pmvcda
    15,932Coins
    Next release, i had to update the plugin and the connection.
    Hope this week...
  19. pmvcda
    15,932Coins
    Hope to have the new release this weekend.
    Lost to much time to make the TCP stream output work, but i think it's finally done.
    Just a preview of what it can do:
    Those are HTML dashes that can be feeded by the TCP stream.
    Here's the link to them: https://flyptmover.github.io/Dashes/Example1.html
    Can't connect yet, you have to wait for the new release, but just say that the dashes where made by AI, so you can do it also easilly and customized to your taste
    Changing the patching in sources is also causing a delay on the release. I changed the logic from storing the paths and testing them to detect the path when patching and opening games... let's see if it works better.
    Old idea was to have a fast opening, now we get small delay, but I think it's tolerable.
  20. Erik Green
    Erik Green Member
    463Coins
    Emergency: ACEvo's MMF locations have changed? I am getting no motion data.
