Question 4 DOF Pivot point sim first build.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Hammered_Again, Nov 3, 2025.
  1. Hammered_Again
    Hammered_Again New Member
    82Coins
    Hey Brains Trust.
    Let me introduce myself, I am 36 work full time have 3 kids. Live between Sydney and Newcastle NSW Australia. Added location in case anyone live in area. Been looking at car building a Racing sim for a few years, reading threads and forums from the Shadows. Never starting my own project to now. I have seen the wealth of knowledge available here, read days of threads and forums. Never starting my own project to now. It will be a DIY budget build so please keep that in mind, In saying that when an upgraded components are recommend I will Upgrade. I dont have the Time to spend days trouble shooting MM's etc.
    now even with reading all the information I can be confusing so below are the material I thought would work, happy to be told otherwise and directed down a different path. I have also Drawn a Cad drawing of the concept but unable to share until I have posted 3 times I believe so will upload when able. (not the best drawing but I am not a Pro CAD drafter.
    After using the SimCalc, I believe the below would work for my build.
    Motors: Worm gear ration around 25:1 to limit regen current issues. self holding as well
    Power 200W
    RPM 100
    Torque 10Nm
    Voltage 24V
    Level arm 100-150mm
    Positioned 800mm from the pivot point
    I found NMRV040.80ZYT02M
    Power supplies: Meanwell has I have had zero issues in the past.
    Meanwell 350W 24V - (24 volt to limit current in circuit and interference)
    Smarts:
    Arduino R3
    Motor drivers:
    IBT-2 (BTS7960)
    (have seen the Sabertooth but not sure if the added cost is worth it)
    Potentiometer:
    Haven't decided yet model - I did see a magnetic Pot setup but couldn't find the thread again to revisit that idea.
    Anyway that is it for now.
  2. Hammered_Again
    82Coins
    Attachments - Purple high light area if for the front motors. - Like am not great at autocad. still learning.
    the base layer I plan on bending 50x50mm 2mmwall square tube, still working out how and without spending thousands. I will be calling local Fabricators before build a DIY bender.
    for the Yaw I plan on using tranfer bearing on the first layer nylon 45mm rated to 180KG each. 4 on the large arch and 2 on the smaller one. this will keep the rig as low as possible.
    for the surge on top of layer 2 will be using linear rails with 6 HGH20CA bearing block
    the U joint I have already purchased a tail shaft for Toyota town ace. $156au and has 2 U joint assemblies. Guess I will need to build a second. (Brother of the year Pending)
    154,783Coins
    +11,217 / 57 / -2
    You mention 4DOF but what you plan seems to be a 2 DOF + traction loss, with the later being different from yaw. Yaw rotates around a central pivot point while traction loss pivots somewhere near your feet.
    Down Under we have the advantage of Motion Dynamics, where you can locally purchase a range of motors, like these:
    https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    IBT-2s are cheap, but be aware members ave reported quality control issues, even with brand new units, and keeping voltage a few points below 24v seems to help longevity. The Sabertooth is like the Rolls Royce of robust alternatives, but there are others:
    https://www.xsimulator.net/community/faq/reasonably-priced-100a-motor-controllers.412/
    180 degree Hall sensors are easy to direct mount, are precise and robust, plus won't break if over rotated, something like these specs are available locally, but can be cheaper elsewhere:
    https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
    While not totally necessary I use a PSU per motor, as our rigs can generate high level power spikes in fast reversals.
  4. Hammered_Again
    82Coins
    Right. Yes Traction loss, Thank you for the correction. With Surge. I thought that made it 4 dof?
    I called Motion Dynamics last Friday about these exact motors. the issue is stock looks like next march, and I am not a fan of the shaft aswell (is it best just to weld the rod to these?). I read wiper motors are great but are slower in reverse and thought that would take away from the experience.
    Thank you for the link to motor controller alternatives. (I will Start reading.)
    thank you for providing direction around the pot. did you read about the magnetic pot in one of these threads? do you think that is more hassle then it is worth?
    I was thinking of using 1 PSU per motor as well. Great to know one of the greats does the same.
    154,783Coins
    +11,217 / 57 / -2
    It's a bummer Motion Dynamics has a current supply issue, historically that has not been the case.
    Wiper motors have limited capacity and torque, and rely on a great amount of inherent design leverage. Personally I would consider more reasonable spec alternatives if possible. Additionally wiper motors generally need ground isolation mods:
    https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    A magnetic pot is a form of Hall sensor, and you can purchase a suitable Hall sensor off the shelf, which in my book is easier unless you have a specific design criteria that would preclude it.
  6. Joe Cortexian
    1,688Coins
    Ibt-2 have a deserved bad reputation but they are so cheap. I have a rig that has been running the same 2 rbt-2 for 2 years without a snag. I think that the issue is half (or more) of them don’t work or work for briefly and quit. At $5 you can buy ten of them and still be under the cost of a better driver. I bought a well recommended 100 amp driver for like $50 and it died in five minutes with a dead short as it filled the role of a space heater.
  7. Hammered_Again
    82Coins
    So far I have sourced & bought:
    motor controllers to try (2 for $55aud delivered). DC Motor Driver Module, Dual PWM DC Motor Driver Module, Replacement 9V‑30V 60A High Power H Bridge Motor Driver Module with Heat Sink : Amazon.com.au: Computers
    Motors: 200w 24vdc RPM90-110 torque 14.6Nm ($630aud Delivered)
    12v/24v 200w Dc Worm Gear Motor With Rv30/rv40 Gearbox For High Torque And Reversible Rotation - Buy 24v Dc Worm Gear Motor 12v Dc Worm Gear Motor worm Drive Gear Motor Dc high Torque Dc Motor 200w Speed Regulating Motor With Turbine Gearbox high Torque 12v Dc Motor high Torque Motor 24v Dc Electric Motor dc Worm Motor brushed Dc Worm Gear Motor dc Worm Gear Motor Product on Alibaba.com
    Elegoo uno R3: ($20aud delivered)
    ELEGOO UNO R3 Board ATmega328P ATMEGA16U2 with USB Cable Compatible with Arduino IDE : Amazon.com.au: Electronics
    Power supply: meanwell 350w 24vdc ($45 delivered)
    Mean Well LRS-350-24 AC/DC Switching Power Supply 350.4W 24V 14.6Amp Single Output Provided by KAINSC Products: Power Supplies: Amazon.com.au
    Racing seat frame: ( bought this instead of welding upper frame) ($404aud delivered)
    Cheap And Good 8040 4080 Black Anodized Extrusion Aluminium T Slot Profile Home Use Sim Racing Rig Cockpit Driving Simulation - Buy Sim Racing Simulator sim Racing Rig Flight Simulator Cockpits aluminium Frames 4080 8040 Kit Racing Game Simulator Sim Racing Cockpit Custom Aluminum Cockpit Sim Racing driving School Simulator airplane Cockpit car Driving Simulator ps4 Driving Simulator cheap And Good 8040 4080 Black Anodized Extrusion Aluminium T Slot Profile Home Use Sim Racing Rig Cockpit Driving Simulation Product on Alibaba.com
    Hall effect Pot (2 pots $76aud delivered)
    6127V1A180L.5FS BI Technologies / TT Electronics | Mouser Australia
    rear tail shaft (for uni-joint $157aud delivered) only need one end
    Rear Drive Prop Shaft Driveshaft Tailshaft for Toyota TownAce KR42 RWD 1997-2007 | eBay Australia
    Someone I know is giving me a WRX carseat.
    I choose to go to a racing frame because the 4080 ali extrude allows the platform to be adjustable easily for the driver. 3 kids means 3 different positions. and this kit was still cheaper then buying the ali in australia and designing, cutting the frame myself.
  8. Hammered_Again
    82Coins
    upload_2025-11-18_9-50-31.png upload_2025-11-18_9-51-50.png I am having trouble finding a lever arm for the keyed rv30 shaft. anyone know what it is called or where to find? attached is a photo form the2jakes build DIY 4DoF motion simulator with Traction Loss , I am after something like that doesnt need to be exactly that. I was hoping for a lever length of 100-150mm.
  9. Joe Cortexian
    1,688Coins
    If I did it again I would weld the lever arms etc to the shaft. Aka 14mm hole in my 1/8 Steele and a jig to hold it perfectly square and weld it. If there is any slack it will be noticeable.
    I ended up machining flats (big pain very hard steel), drilling holes and using angle brackets. Works now but welding would have been less work
    154,783Coins
    +11,217 / 57 / -2
    I am pretty sure those levers are from Simukit, but they have been shutdown for ages: https://simukit.com
    Alternatively you could make levers, please see the FAQs here: https://xsimulator.net/community/faq/how-to-attach-lever-crank-arm-to-motor-shaft.182/
    154,783Coins
    +11,217 / 57 / -2
  12. Hammered_Again
    82Coins
    still making slow progress while I am waiting for the parts to arrive, while I was planning to use the aduino uno r3, I have come across the upgraded Uno r4 wifi - I can't seem to find posts on here. has anyone tried these out? has there been any reported issues?
  13. noorbeast
    154,783Coins
    +11,217 / 57 / -2
    My view is that it is safest to use the specific Uno model the code you intend to use has been designed for and tested with.
  14. Hammered_Again
    82Coins
    Slow progress continues:
    I was able to wire these cheap motor controllers, and they seem to be working, they don't require the 5v or ground from the Arduino. other points that need to be noted is they aren't rated for the 60A listed. They just fit 2.5mm2 or 13AWG cable, I am only using them for 1 motor per controller and the motors are only 200W 24Vdc pulling 8amps. I wouldn't use these for anything over 20A.
    The motor controllers use Mode 1 of Rufus Dufus SMC3 code. please see attached the wiring diagram. Pretty straight forward. (Tutorial - SMC3 Arduino 3DOF Motor Driver and Windows Utilities)
    To keep things easy I decided to use ribbon cable and IDC 8 pin connectors for the motor controllers. these connectors don't required tools and provides additional friction for these connectors better connection (less chance of wires coming lose).
    I am not a fan of using single Dupont for arduino connections and like the screw shields shown in the image below. again, no special tools required.
    Still waiting for the frame to build.
  15. Hammered_Again
    82Coins
  16. Hammered_Again
    82Coins
    OK I am at it again, still waiting for my top frame to arrive. I decided to play around with AS5600 magnetic encoders. the stl files created can be download from the link below. the cable hole is 6mm. the slot seen ontop is for a small cable tie (Zip lock) and will lock cable into place. I have tested and can confirm all working in SMC3. I needed to change some of the code to limit the angle of rotation in SMC3 and disabled the motor cutoff disable function so SMC3 allowed the motor 1 to turn on. (this just means motor turns off when exceeds limits doesnt disable, when the motor is back within limits it starts working again. is only disabled by the // at the front of line. easy to undo)
    Please see below code. this is for motor 1 and code line for version 1.0 starts at line 1639. the AS600 now acts like a 180 degree Pot like above. I tested side by side they appear to have identical movement now. for motor 1 AS5600 and 2 180pot.
    I wired the AS5600 following the youtube clip attached. not sure why this works without removing the resistor like the other posts do. but it does.
    STL file:
    AS5600 RV30 Mount by Hammeredagain | Download free STL model | Printables.com
    Code change:
    // Check and Update Motor 1 drive
    Feedback1 = analogRead(FeedbackPin1);
    if ((Feedback1 > CutoffLimitMax1) || (Feedback1 < CutoffLimitMin1)) { DisableMotor1(); }
    PWMout1=CalcMotor1PID(Target1,Feedback1);
    if (Disable1==0)
    SetOutputsMotor2();
    else
    PWMout2=0;
    To:
    int raw = analogRead(FeedbackPin1);
    Feedback1 = map(raw, 256, 768, 0, 1023);
    // if ((Feedback1 > CutoffLimitMax1) || (Feedback1 < CutoffLimitMin1)) { DisableMotor1(); }
    if (Disable1==0)
    SetOutputsMotor1();
    else
    PWMout1=0;
    Youtube for AS5600 wiring all credit goes to AdrooFroo:
    A great cheap encoder -- the AS5600
  17. Nailson Roveta
    Nailson Roveta Nailson
    Retiree
    Serra, Espírito Santo, Brazil
    103Coins
    Congratulations on the project. I'm almost finished improving the electronics in my cockpit. I already use the AS5600 with its analog output, and now I'm modifying the program to use the AS5600 not as a potentiometer, but using the I2C digital output. It's already working on the bench with SMC3 Utils and SIMTOOLS itself. I struggled a bit to establish the communication, but it seems to be working very well. The expectation is that this will eliminate any noise and vibration in the motors and also provide more precision in movements. Since the AS5600s use the same address on the I2C bus, I'll use the TCA4598a, which is an I2C multiplexer. As soon as I validate all the steps, I'll document and post them on the website. Best regards and good luck with your projects.
  18. noorbeast
    154,783Coins
    +11,217 / 57 / -2
    Added to the end of the FAQ pot attachment section with credit to yourself: https://xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
  19. Hammered_Again
    82Coins
    Slowest progress ever but hopefully now will get into the motion, Frame finally showed up after 5 months. before people look at the photos and start telling me the Logitech G920 is no good, I know there is better steering wheels and pedals. I am trying to get the frame up and running before I upgrade those. It was fine for the setup I had.
    Seat is from an old WRX drivers seat, donated by a mate.
    The area I am designing the setup for is the lounge room (I one that fight lol) 2000mm by 1400mm is the space for sim. the photo ending in 'a19' has the transfer bearings in 17mm form ply. this is to keep it low to the ground, It is louder than I wanted but will finish with the transfer bearings before looking at different options. that is the layer for the traction loss.
    I picked up the RHS 75x25x2.5mm steel today to make the next layer for the surge. this will be where the rear drive shaft U-joint will be welded and all electronics will be installed. the RHS will be placed on the linear rails..
  20. Hammered_Again
    82Coins
    Just a quick update after some real progress.
    *I learnt how to mig weld in 1 day please be nice.
    I have attached the linear rails to the ply base and have started to weld the sub frame where the front motors will mount. Once completed I will provide all measurements and a more detailed update.
